Track saphhire
#201
You could Andy just................ put them on the wifes credit card!!! then work 6 in the morning till 9 at night to pay them off!!! LOLGetting fed up with the money now just want to get an 550 engine like yours!!! and rip up fordfair
#210
Well I relay pleased as to day the grp A 355 6 pots turned up today.And for once there in good nick and the pads are new as well,cleaned them up a bit with break cleaner and tfr to remove the grime and dust but all is good
And the 909 front anti roll bar cross member
#220
Hi all went over to scs today to see Jimbo about some GRP A head lights and pick up my stage 3 rear beam off rainbird, Had a nice chat to them about an engine!!!
Rear beam
Well now I can really get on with the car and can't wait to get it all together
Rear beam
#226
Andy I am still looking for them,I know a man with a mag set but at £1200 and need painting I think it would be better to get a set of reps off martoon like in the pic ...look as good to me?
#227
Got a pair of Grp A carbon fiber mirrors today off Matt will get pics up soon but the miss don't know I bought them!!!
But as for the car... I not done bugger all to it lately bit sick of it will get some motivation soon I hope??Got most of the bit now so need to get on with it
#232
Motivated again by the white track car escort on the spec-r stand I have two days off work to work on the cossie and a heap of parts to fit and make up
So can't wait now
So can't wait now
#233
Hi all had a couple of days off work so had a play with the cossie
test fit of the carbon rear quarter things
Rear number plate surround
And the cover for the plug leads
Then went to fit the oil filter relocation and cooler,found that the chassis engine mount fouled the take off :BangHead:
So need a different type!!
Test fit of the carbon grp A mirrors
need to bond them on to the door
Cut some carbon to mount the motec dash in the clocks and got some leds to use as warning lights oil/battery/high beam/ECT
Test fitted the rear beam
cleaned and painted the diff and drive shafts
Finished the near side front suspension
Got to make a spacer to lift the steering will do that near the end
#237
Today I fitted some grp A 14mm wheel studs that I had made up and new wheel bearings
Carriers and drive flanges I shot blasted and painted.I cut off the stranded rear caliper mounting lugs to allow the fitment of the rear grp A brake brackets
#239
#240
Mocked up a rear corner.Brake is all on OK rear shock on then........ trouble!!!!
The wheel offset is wrong nearly hit the arm of the 6 deg bear on ET30
Never goes smooth!!!
new wheel needed now
