Mk6 JWRC fiesta cosworth
#2962
I wanted to start sorting the boost and water hoses for the car now as i need these in place along with the alternator and belt etc before i can work out where my laminova can be mounted and where the 2 remaining -10 oil lines can be run,
First up was the turbo compressor housing to intercooler hose, i noticed when looking at hose prices that the normal cossie style hose which is "?" shaped may well fit but is just over £90 delivered from most places and that seems a bit excessive to me so tohught if i could get a 90 bend put on the housing then i could just use a straight hose from compressor housing to intercooler instead?
So off with the housing
![Name: 696E5CCD-BE2D-4F1A-B507-DD3A2CAB227F-8089-00000B0E27DDF4C7_zps84a312a1.jpg
Size: 105.5 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/93429d1501528187-mk6-jwrc-fiesta-cosworth-696e5ccd-be2d-4f1a-b507-dd3a2cab227f-8089-00000b0e27ddf4c7_zps84a312a1.jpg)
And out with the grinder which leaves me with this
![Name: 8FFD1771-2EA0-4E60-B8A2-4F84C4478854-8089-00000B0E37DA3C68_zps9a03790c.jpg
Size: 106.7 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/93430d1501528187-mk6-jwrc-fiesta-cosworth-8ffd1771-2ea0-4e60-b8a2-4f84c4478854-8089-00000b0e37da3c68_zps9a03790c.jpg)
Made a call to cr turbos and ordered up a cast 90 degree elbow but it needed to be shorter to line up properly so got the grinder on that too
![Name: 33D9D9C5-8660-49F8-AA94-79181E54687D-8089-00000B0E419E2BDF_zps1d39af84.jpg
Size: 107.4 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/93431d1501528187-mk6-jwrc-fiesta-cosworth-33d9d9c5-8660-49f8-aa94-79181e54687d-8089-00000b0e419e2bdf_zps1d39af84.jpg)
Quick mock up of where it needed to be
![Name: 78E998F9-4550-40A4-8D38-DBD26B8B918B-8089-00000B0E52EDE9FC_zps53134b1d.jpg
Size: 103.1 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/93432d1501528187-mk6-jwrc-fiesta-cosworth-78e998f9-4550-40a4-8d38-dbd26b8b918b-8089-00000b0e52ede9fc_zps53134b1d.jpg)
Now being alloy there was now way i could weld it as i do not have the equipment for that so had to hold it in place so i could take it to be welded by my good friend/fabricator Karl, so used some black electrical tape and wrapped it round just leaving a small gap big enough to weld a good tack which will hold it while the rest of the tape is removed and then it can be welded properly
![Name: FF6EC77B-0F9B-4603-933A-AD9BB9F4336E-8089-00000B0E88A4B6E2_zpsa9979be7.jpg
Size: 90.5 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/93433d1501528187-mk6-jwrc-fiesta-cosworth-ff6ec77b-0f9b-4603-933a-ad9bb9f4336e-8089-00000b0e88a4b6e2_zpsa9979be7.jpg)
So with that done i got it to Karl's and told him what i needed doing but also told him i wanted the weld built up around the edge so you can't see the big step in size, no problem he said and got it done and it turned out a lot better than i hoped as at one point after i had cut the compressor housing then got the bend i thought it was going to be a total abortion as the bend was not exactly the same size due to me cutting back the compressor end beyond the round hose end piece
All done
![Name: 3201AB72-F334-4E02-ACD4-45317D2A6117-2129-000002B42D59202B_zps1964e562.jpg
Size: 96.4 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/93434d1501528187-mk6-jwrc-fiesta-cosworth-3201ab72-f334-4e02-acd4-45317d2a6117-2129-000002b42d59202b_zps1964e562.jpg)
![Name: 85D9E0B1-5145-44FC-B400-4C14A4DCD77E-2129-000002B425770760_zps0e0d7e34.jpg
Size: 95.3 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/93435d1501528187-mk6-jwrc-fiesta-cosworth-85d9e0b1-5145-44fc-b400-4c14a4dcd77e-2129-000002b425770760_zps0e0d7e34.jpg)
Well happy with it![Top](https://passionford.com/forum/images/smilies/smile011.gif)
But.............. nothing is ever without it's bloody issues and neither was this it seems!
When i attempted to re fit it back to the turbo it appears that the heat has distorted the shape by a very minor amount! but it seems luckily that it has not distorted the flat face as when put on a piece of glass (which is about the flattest thing you will find most likely) it made full contact but somehow the machined hole was off! so it must of been where i asked him to build the weld up to make it look better it took too much heat and that caused it so next time a big piece of brass will be used to weld on to soak up the heat along with shorter weld periods. Anyway after a bit of very careful rubbing with paper and a few million trial fits it is all good and seats good again thank god![Top](https://passionford.com/forum/images/smilies/smile011.gif)
So after that long winded story, more pics
Got some hoses from viper performance hoses which is all i could get short notice to test fit this weekend to work out sizes i need to get a custom 1 piece hose made instead of the 2 hoses and metal joiner in the pics, but i will be changing them to roose items as i like there logo better lol, also with get a slightly longer hose from tb to cooler from roose as well then sell these ones
Here's is the test fit up
![Name: 401EEB9B-3671-455E-B0AA-55A5A8D6E719-2129-000002B4153DCD75_zps5a783ba9.jpg
Size: 136.9 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/93436d1501528187-mk6-jwrc-fiesta-cosworth-401eeb9b-3671-455e-b0aa-55a5a8d6e719-2129-000002b4153dcd75_zps5a783ba9.jpg)
![Name: 8F03D52E-5D39-4937-B524-82E36CD52F54-2129-000002B41E7C3EF4_zps20f64a04-1.jpg
Size: 119.8 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/93437d1501528187-mk6-jwrc-fiesta-cosworth-8f03d52e-5d39-4937-b524-82e36cd52f54-2129-000002b41e7c3ef4_zps20f64a04-1.jpg)
![Name: 45DCBE74-AE39-430C-8C70-F5450915CBC3-2129-000002B3FC035C04_zps7ad3d384.jpg
Size: 152.3 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/93438d1501528187-mk6-jwrc-fiesta-cosworth-45dcbe74-ae39-430c-8c70-f5450915cbc3-2129-000002b3fc035c04_zps7ad3d384.jpg)
Nice neat and simple which is what i like lol
Next up as you may of noticed in the pics was mounting the alternator,
I am using a 2wd set up as i have done away with the power steering and didn't want the big heavy escos style bracket but i also did not want the twin belt 2wd set up so i have gone with a 2wd bracket set up with a 4wd poly v belt that is just routed around the alternator pulley, water pump pulley and crank pulley, i know this leaves less belt to pulley contact on the crank but Martin Hadland runs a set up like this and has never seen any issue's so that is proof enough for me that it will be fine,
So to mount the alt to the block i sold my wrc bracket set up due to the cost and aggro of sourcing a wrc alt and went for a 2wd billet bracket with a drop bracket all machined into 1 from Anembo Engineering, i spoke to mk motorsport about 1 first as i always use him but he was very busy and did not have 1 available on the shelf so sent me in there direction,
![Name: 5B554095-843B-45EC-BE82-4F249EE9521D-2129-000002B435657796_zpsdb7b643a.jpg
Size: 117.1 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/93439d1501528187-mk6-jwrc-fiesta-cosworth-5b554095-843b-45ec-be82-4f249ee9521d-2129-000002b435657796_zpsdb7b643a.jpg)
Going to swap the bolts for plated ones as im a bufty at heart lol
Also you can see the stainless rose jointed belt tensioner i made instead of using the standard type,
![Name: BB259893-9FA7-4F2B-B382-C7A36EA571F5-2129-000002B43D137204_zps56d470b1.jpg
Size: 88.3 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/93440d1501528187-mk6-jwrc-fiesta-cosworth-bb259893-9fa7-4f2b-b382-c7a36ea571f5-2129-000002b43d137204_zps56d470b1.jpg)
with with all that fitted i used a dummy knackered alternator to check things lined up ok which they did but the only thing i noticed is my red anodised pulley is very faded compared to my others and they were all bought at the same time and were all the same dark red so im guessing that maybe mine was mixed up at fms and i ended up with this one but no drama's as i will either get a new 1 or re anodise this one,
Here is the alternator dummy fit pics
![Name: 60B32181-C01C-4F5B-B378-97408CE9D440-2129-000002B403F84429_zps29cea36b.jpg
Size: 130.5 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/93441d1501528187-mk6-jwrc-fiesta-cosworth-60b32181-c01c-4f5b-b378-97408ce9d440-2129-000002b403f84429_zps29cea36b.jpg)
![Name: 03C185EF-B748-4336-BA93-706DC2CDCB70-2129-000002B40CFECDDB_zps1a22f4ef.jpg
Size: 136.5 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/93442d1501528187-mk6-jwrc-fiesta-cosworth-03c185ef-b748-4336-ba93-706dc2cdcb70-2129-000002b40cfecddb_zps1a22f4ef.jpg)
So now i know all that fits, i have measured the length of belt needed so will order a belt and new alternator (90amp) along with a long 130mm M8 bolt to go through the bracket as i do not have 1, and get it fitted properly,
Then it will be time to buy some water hoses and make a start on that side of things
All done
Well happy with it
#2969
Boost Junkie
Wiggins clamps are a pain in the ass to faf about fittin too. Very quick to get off but overly fussy fitting. Not to mention if you have any kind of prang the they have no give whatsoever. A silicone hose will bend/collapse or tear.
Look pretty and hold monsterous boost but that's about it. Lol.
Lookin good Marc, I also welded an elbow on my turbo, much better for space and keeping the pipe runs clean.
![](http://img.photobucket.com/albums/v208/frayz55/turboon21.jpg)
#2970
Got an alternator and belt sorted so will have the ready to fit at the weekend,
Also got my 1 piece hose coming from Roose Motorsport with another reducer for the cooler to tb hose so they match,
Going to drop this lot off tomorrow to be anodized red like the other little bits on the car, if i am lucky i may get it back for friday but will have to wait and see
![Name: C95CAD3B-D39C-421E-9BCC-400CC8852440-5003-0000067A80F2BCA7_zpsbe1aba11.jpg
Size: 163.4 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/92978d1501528187-mk6-jwrc-fiesta-cosworth-c95cad3b-d39c-421e-9bcc-400cc8852440-5003-0000067a80f2bca7_zpsbe1aba11.jpg)
#2972
It's getting close mate,
Dropped off the stuff this morn to the anodizers and just got the call to say its all done,
Couldn't do the handbrake though as I forgot to press out the steel inserts so going to get that done next week as they said were charge you a set amount and just drop the handbrake in soon as I've presse the metal bits out and he'll get it done for nothing
Pics once I've picked the bits up
#2974
Action electro plating in basildon mate ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
Didn't finish work in time to get down there to collect the bits tonight so picking stuff
Up in the morning and I've now removed the steel insert from the handbrake lever so there gonna do that for me tomorrow day
#2980
As I'm so eager I got all the bits re fitted straight after work lol
Steering wheel spacer
![Name: 416B2E41-F095-4E41-A633-FA8E95EF591F-6301-0000085633EB5D64_zps0b7e6b6b.jpg
Size: 115.0 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/92795d1501528187-mk6-jwrc-fiesta-cosworth-416b2e41-f095-4e41-a633-fa8e95ef591f-6301-0000085633eb5d64_zps0b7e6b6b.jpg)
Handbrake parts
![Name: E5FD08D2-4BE0-4F68-8481-6FB42C1CE214-6301-000008563B36DB06_zpsfb6707ce.jpg
Size: 112.0 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/92796d1501528187-mk6-jwrc-fiesta-cosworth-e5fd08d2-4be0-4f68-8481-6fb42c1ce214-6301-000008563b36db06_zpsfb6707ce.jpg)
![Name: 24441062-F38D-4048-9960-D427AB3E2533-6301-000008564277A609_zps5246a542.jpg
Size: 119.7 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/92797d1501528187-mk6-jwrc-fiesta-cosworth-24441062-f38d-4048-9960-d427ab3e2533-6301-000008564277a609_zps5246a542.jpg)
Just need some new rubber heat shrink to re cover the handle,
Alternator heat shield got a lick of vht, it came with the 90a ford visteon alternator I just bought second hand in minty mint condition
![Name: FFC97836-0288-403F-B243-9F9563B021AB-6301-00000856512E61B8_zpse4a3911a.jpg
Size: 99.7 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/92798d1501528187-mk6-jwrc-fiesta-cosworth-ffc97836-0288-403f-b243-9f9563b021ab-6301-00000856512e61b8_zpse4a3911a.jpg)
Alt pulley and the plated parts fitted I had done ages ago
![Name: EC4ECB5D-2DC2-4E93-869E-D7DE915822F1-6301-0000085623C0477A_zps7fd81958.jpg
Size: 112.6 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/92799d1501528187-mk6-jwrc-fiesta-cosworth-ec4ecb5d-2dc2-4e93-869e-d7de915822f1-6301-0000085623c0477a_zps7fd81958.jpg)
Handbrake parts
#2985
Toying with the idea today of re designing the cooling package,
Would mean selling my brand new pro alloy rs500 cooler and getting then to make a custom fit escort/focus wrc style cooler, slanting the radiator and putting a large air filter behind the ford grille in direct airflow as per Ronnie Amis time attack sierra,
Here it is as it is now with the rs500 cooler, absolutely no room for air filter pipe work anywhere!
![Name: B06F43A0-11D3-4018-B5D2-C69CF6D0933C-7251-0000094BAEA52F01_zps03085b09.jpg
Size: 136.2 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/92684d1501528187-mk6-jwrc-fiesta-cosworth-b06f43a0-11d3-4018-b5d2-c69cf6d0933c-7251-0000094baea52f01_zps03085b09.jpg)
Bumper removed
![Name: 33AA861F-90AB-4008-BA05-F3761D6B1134-7251-0000094BC60E30B0_zpsf50f4adf.jpg
Size: 110.2 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/92685d1501528187-mk6-jwrc-fiesta-cosworth-33aa861f-90ab-4008-ba05-f3761d6b1134-7251-0000094bc60e30b0_zpsf50f4adf.jpg)
Angled the radiator to make it work better and give me more room around it and above it behind the ford grille for an air filter
![Name: 4293AFD4-97AF-4E1D-93FD-F66E37F3BFE6-7251-0000094BD41EF0C9_zpsbc2b4b17.jpg
Size: 98.8 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/92686d1501528187-mk6-jwrc-fiesta-cosworth-4293afd4-97af-4e1d-93fd-f66e37f3bfe6-7251-0000094bd41ef0c9_zpsbc2b4b17.jpg)
![Name: F2F9826E-9170-4CD2-824C-DCF273482022-7251-00000946D6880162_zpsa73325af.jpg
Size: 124.1 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/92687d1501528187-mk6-jwrc-fiesta-cosworth-f2f9826e-9170-4cd2-824c-dcf273482022-7251-00000946d6880162_zpsa73325af.jpg)
![Name: C88B26D0-FC39-4312-942B-06863BCB1D1E-7251-000009448D10E3D6_zps4e72f1d0.jpg
Size: 128.9 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/92688d1501528187-mk6-jwrc-fiesta-cosworth-c88b26d0-fc39-4312-942b-06863bcb1d1e-7251-000009448d10e3d6_zps4e72f1d0.jpg)
![Name: D27759AD-6114-4F52-B7BF-F9FE05751C7C-7251-00000946F6033CF7_zpsdd6eb289.jpg
Size: 148.0 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/92689d1501528187-mk6-jwrc-fiesta-cosworth-d27759ad-6114-4f52-b7bf-f9fe05751c7c-7251-00000946f6033cf7_zpsdd6eb289.jpg)
![Name: 226D123E-E58D-4355-A240-6B452F78EF46-7251-0000094701A3A785_zps435aaa5e.jpg
Size: 154.5 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/92690d1501528187-mk6-jwrc-fiesta-cosworth-226d123e-e58d-4355-a240-6b452f78ef46-7251-0000094701a3a785_zps435aaa5e.jpg)
More on this when I've made some calls to get a price for a new cooler and see what interest I get in mine as there £432 new so was thinking about £360 for mine as it is like new still
Thanks
Marc
Bumper removed
Thanks
Marc
#2991
No it's not really a road car but I don't want to remove a headlight or use the quad lamps as I don't like the look, appreciate the ideas though
Hi Mike, if you want I can let you know once I've decided what I'm going to do, probably in a week or 2
#2994
Hi Marc on my fiesta on the turbo side inner guard we have a cut out to let the pipe Work in for the air filter' there is a place made away from dirt and water in front of drivers front wheel for air filter to sit the air flow is fed from the front bumper area
Thanks steven
Thanks steven
#2997
Due to cost and extra hassle im not going to go the slanted radiator route so im keeping the existing rad with a new cooler so ive now worked out the new cooler size etc,
Going to put double thick foam strip all around the radiator and run an identicle sized intercooler in front of it with 90degree outlets at the top,
Here is the cardboard mock up show the gap between the two which will be sealed by the foam,
![Name: B3318E45-DCD1-432D-B00B-F72178568A03-8818-00000BCD8F78A32C_zps18acf31e.jpg
Size: 994.5 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/92192d1501528187-mk6-jwrc-fiesta-cosworth-b3318e45-dcd1-432d-b00b-f72178568a03-8818-00000bcd8f78a32c_zps18acf31e.jpg)
You can see the circles where the inlet an outlet will be,
I have also moved the whole lot forward by approx 40mm and will go from a 50mm intercooler core to a 65mm core,
By lowering a new cooler the same size as the radiator it creates a big gap above it
![Name: 198E3AB3-82D7-4A1B-9C6B-06FEDE84E6A0-8818-00000BCD88F4DD71_zpsd13b89e1.jpg
Size: 1.07 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/92193d1501528187-mk6-jwrc-fiesta-cosworth-198e3ab3-82d7-4a1b-9c6b-06fede84e6a0-8818-00000bcd88f4dd71_zpsd13b89e1.jpg)
This should allow me to make a smaller version of this type set up
![Name: 9262BDF5-337E-4980-9D29-0D6B7258D510-7742-00000A5DBFA12AA0_zpsafe652c2.jpg
Size: 298.5 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/92194d1501528187-mk6-jwrc-fiesta-cosworth-9262bdf5-337e-4980-9d29-0d6b7258d510-7742-00000a5dbfa12aa0_zpsafe652c2.jpg)
The new cooler being a bit wider will also fill the bumper mouth better as shown
![](http://img.photobucket.com/albums/v104/CHICKAROO/498D9222-42A5-43B5-97F6-F78D849CCB2F-8818-00000BCD9788E481_zpsdc554bbe.jpg)
I actually made the mock up too short so the real thing will be lower and sit level with the splitter so there is no gap underneath for air to flow under it, then il make ducting for top bottom and sides so it all has to go through the cooler and in turn the radiator![Top](https://passionford.com/forum/images/smilies/smile011.gif)
Moving it all forward by 40mm also gives me a bit more room to mount the heat exchanger somewhere around here
![Name: 97CA6DBE-20E2-424B-BC2F-3800A5690980-8818-00000BCD9E91F22C_zps365bd746.jpg
Size: 1.48 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/92195d1501528187-mk6-jwrc-fiesta-cosworth-97ca6dbe-20e2-424b-bc2f-3800a5690980-8818-00000bcd9e91f22c_zps365bd746.jpg)
Just waiting for a call back from pro alloy for a price on the intercooler
