Mk6 JWRC fiesta cosworth
Old 08-07-2011, 08:51 AM
  #1481
B13 JUS
B13 JUS's Avatar
Originally Posted by M K
Car is now gone
Big thanks to Justin for taking it to Gaz's for me, was nice to meet you
No problem mate, cost u a passanger ride though.
I look forward to it been painted, Gaz will do a very good job I'm sure.
Old 08-07-2011, 09:14 AM
  #1482
c20tbo
c20tbo's Avatar
Big step Marc, will give Gaz practice before doing mine.lol
Old 08-07-2011, 06:05 PM
  #1483
Miller 3
Miller 3's Avatar
Sorry Marc i have no idea on the colour, Iv had a look just cant seem to find any info
Old 10-07-2011, 02:58 PM
  #1484
M K
M K's Avatar
Your panels are already bonded on and fitted nice though aren't they Rob?
The problem with mine is the rear quarters need bonding and joining on and that's where the grief is in getting good panel gaps and getting it to look nice as there are holes etc where the kevlar panel edges aren't finished perfectly.
I have never expected it to be as nice as a car using original pressed metal panels so whatever Gaz can do with it is good enough for me.
No drama Doug, just wondered what it was, cheers for the pics though
Old 10-07-2011, 08:24 PM
  #1485
Drizz
Enthusiast
Drizz's Avatar
Saw a red one today in colchester parked on the side of the road....
Old 10-07-2011, 08:38 PM
  #1486
Miller 3
Miller 3's Avatar
Looks hard as nails going round track ay Marc
Old 13-07-2011, 03:38 PM
  #1487
fezSTturbo
MADST.COM
fezSTturbo's Avatar
Looking utterly brilliant.
glad you didnt put that vent on the wrong side,it only looks good on the passenger side (obviously because of the shape).
my air filter sits right under mine so its ok but useless to you I guess.
Old 13-07-2011, 11:07 PM
  #1488
M K
M K's Avatar
Cheers mate
Yeah the vent was all wrong for me,
Old 15-07-2011, 01:28 PM
  #1489
M K
M K's Avatar
Originally Posted by markk
The sleeves are threaded you know that ?
and yes, dont forget our wheels are on and off very very regular
Spoke to Malcom at Dewitts today Mark and the wheel stud sleeves they supply are NOT threaded!
Tey are 28.5mm long and 17.9mm outside diameter
I have also had 1 or Rob's (c20trb) sleeves sent to me to look at and that 1 is not threaded either!
Are you sure yours are threaded?
How long are your studs and sleeves Mark overall length?
Thanks
Marc
Old 15-07-2011, 01:39 PM
  #1490
markk
markk's Avatar
My studs are 80mm long iirc , and the sleeves are 30mm long, and yes they defo screw on.
You do have to watch Dewitts at times, I ordered two lower TCA pins, Ł8 each iirc, they arrived and where 2 x M24 bolts that had been ground down - very naughty.
Old 15-07-2011, 01:46 PM
  #1491
M K
M K's Avatar
Think i will make my own and thread them then
Do the bells go over the sleeves and flat against the hub face so it is essentially sitting on the 4 sleeves or behind the sleeve with the sleeve up against it Mark?
Thanks
Marc
Old 15-07-2011, 03:40 PM
  #1492
c20tbo
c20tbo's Avatar
Marc,
The sleeve i sent you is threaded but not all the way, i had to screw it off anyhow, i will take the 70mm studs off you aswell.
Old 15-07-2011, 03:46 PM
  #1493
M K
M K's Avatar
Your sleeves are not M14 x 1.5 rob
I'm in the garage now and have checked it, must be imperial like Marks,
I have made up a new sleeve quickly to try but because I might need to keep my 30mm spacers it gets more involved for me lol
Old 15-07-2011, 03:50 PM
  #1494
c20tbo
c20tbo's Avatar
Nothings ever bloody easy.lol
Oh well seems as as im taking those studs i will get sleeves to match.
Old 15-07-2011, 04:07 PM
  #1495
markk
markk's Avatar
Thanks
Marc
yes bells sit against the sleeves up against the hubs, might only be on grpa studs (unf)
Old 15-07-2011, 08:36 PM
  #1496
M K
M K's Avatar
Originally Posted by special-K
hi mark had a good look round the fezzy 2day said to beef. gaz got his work cut out for himself there.. dont normaly comment about others work but ill tell you what i told beef im personaly dissapointed for you because the work whats been done is very poor dont no what it cost you heard it was 10,000 - 12,000 but id of done that work for half the price and to a far better standard you have seen my work its speaks for itself this is no way a dig or piss take at you just my thoughts. hate it when people pay owt there hard earned cash for very poor work when i do peoples cars if im 120% happy i no the customer will be 119% happy but its in good hand now and look forward to seeing it finished....K
I really do not see what the point of this pm was fella! But if that is the only kind of comments you have about the car/project then I would appreciate it if you keep your opinions to yourself please
Andrew done a lot of work on the car, it is not your average cosworth 4x4 conversion, alot of parts were included in the price above,
2 10 bar fuel pumps
Custon Fuel tank and straps
Vibra technics gearbox and engine mounts
Prop supplied shortened and balanced
New pro alloy rad and cooler
Group a uprights
Grp a bearing adapters
4 eccentric alloy top mounts
That's just some of the parts supplied,
I was also paying for Andrews experience of how these things should be built, with correct driveshaft angle, tca angles etc, he has a wealth of experience in building race winning cars,
And Andrews price was a he'll of slot cheaper than anyone else I got a quote from, and after all is said and done I am more than happy with the results, the service and what I paid for what I got.
As for fitting the kit, well yes that is gonna be some hard work as far is Gaz is concerned but I am confident that it us in capable hands as you say, but I was already aware these Motorsport panels/kits are far from perfect and I am happy with that and know that Gaz will get it as good as it can be
The work you have done on beefy's car looks great and I can see why beefy is so chuffed with the outcome so far
But at the end of the day I would not dream of pm'ing you or him or anyone else just to tell them someone's else work was shit and overpriced etc it's just fucking rude mate!
Old 15-07-2011, 09:07 PM
  #1497
-beefy-
formerly beefy-rst-2
-beefy-'s Avatar
got to say spesh that was uncalled for - opinions are your own
if some one took a dig at mine you would be spitting feathers
not needed to be said imo ,
regards beef
Old 15-07-2011, 09:26 PM
  #1498
c20tbo
c20tbo's Avatar
Regarding Spesh k, is it not the fact that Beefs and Marcs cars are built in 2 different ways? ie beefs is to look factory and pretty and a hell of a lot of man hours have been put in to make it look as good as it does.
AG doesnt work like that, the hours charged would be doubled if it was meant to be all pretty and factory, more right and purpose build is Marc's like my own which is also at AG.
Old 15-07-2011, 09:46 PM
  #1499
-beefy-
-beefy-'s Avatar
think we should leave it at whats already said rob ,
dont want the thread to veer off topic
two diffrent cars entirely !!!
keep up the good work mark
beef
Old 15-07-2011, 09:49 PM
  #1500
c20tbo
c20tbo's Avatar
beef
Good Call Beefy.
Old 15-07-2011, 09:57 PM
  #1501
dingla rs
dingla rs's Avatar
droping a sierra floor in and building from scratch bit different andys fab work is second to none but as stated its done for track rallying .k's work is mint also but im sure andys lad didnt have 700hours in this no dig at either as i seen both there work
id choice spesh for resto as his work top class
and andy for rally track car as his work top class
Old 16-07-2011, 08:24 AM
  #1502
carlo
carlo's Avatar
jesus all you need to do is look at andrews focus & other cars he has built to see he knows his stuff ! its hardly andrews fault the panels arent the best ! beefys car & marks are 2 totally different annimals ! beefys is proper mint & imho too good to use , yes i think its that good it needs built & showed marks car will be a proper tool when done & it was built no different than andrews focus & to me what you say spesh is a dig & look what that focus has acheived & is still doing so When you have built a car that has done as well in every way as that focus & the others he has then you can bring him down , your right mark its downright rude ! i mean what has spesh built apart from beefy's car ? a red rs turbo ? Im proper dissapointed reading that i thought spesh was one of the BETTER ppl in the ford community i dont think you have done yourself any favours at all
Old 16-07-2011, 11:17 AM
  #1503
JonnyBravo
JonnyBravo's Avatar
Its a race car, not a fooking show piece !
Keep at it Marc, can't wait to see it painted and finished !
Old 16-07-2011, 11:21 AM
  #1504
carlo
carlo's Avatar
Exactly
Old 16-07-2011, 11:35 AM
  #1505
JonnyBravo
JonnyBravo's Avatar
Originally Posted by carlo
Exactly
Possibly why I wouldn't bother with a thread for my own car if thats the attitude people have.
Anyway, isn't this done yet ? I want to see some more home made bits fresh off the lathe !
Old 16-07-2011, 11:38 AM
  #1506
TimC
TimC's Avatar
Lets get back to the car please, its more interesting then the bitching.
Old 16-07-2011, 05:26 PM
  #1507
carlo
carlo's Avatar
few pics i have on photobucket mate
Old 16-07-2011, 05:28 PM
  #1508
carlo
carlo's Avatar
Old 16-07-2011, 05:54 PM
  #1509
JonnyBravo
JonnyBravo's Avatar
Looks stunning when it was grey !
Old 16-07-2011, 08:14 PM
  #1510
escort700bhp
escort700bhp's Avatar
i just love this little thing
Old 16-07-2011, 10:24 PM
  #1511
carlo
carlo's Avatar
Ally i got the pleasure of going around donnington in that with chris i was bricking it big time was 680 bhp at the time & mental
Old 17-07-2011, 08:54 AM
  #1512
M K
M K's Avatar
Thanks for the comments guys :top;
Good pics, cheers
Carlo have you got any full size ones of it in grey? Everyone I have seen is a small thumbnail size one,
Thanks
Marc
Old 17-07-2011, 09:05 AM
  #1513
carlo
carlo's Avatar
marc i dont mate sorry i thought i did but on photobucket thats the way it came out i can give you my photobucket password if you want to try mess about with the pic ?
Old 17-07-2011, 10:25 AM
  #1514
escort700bhp
only one i have
Old 17-07-2011, 11:51 AM
  #1515
carlo
carlo's Avatar
thats a cracking pic ally , aklly do you use the car much ?
Old 17-07-2011, 11:57 AM
  #1516
escort700bhp
no not been out in it since early 09
ive rebiult it bigger and better and with more power now , wait till you see the evo version out soon lol
Old 17-07-2011, 01:41 PM
  #1517
carlo
carlo's Avatar
Nice mate keep us posted
Old 18-07-2011, 10:07 AM
  #1518
M K
M K's Avatar
I have that pic Aly, wondered if you had any more close ups of it in grey but that gives me the general idea,
Updates as far as parts go,
i have spoke to Mark at mk motorsport and he is hoping to have the parts i ordered with me this week which was as folows,
2 new billet uprights
2 new grp a type larger bearing with radius machined onto race
2 front steering arms for gravel uprights with all bolts and hardware
I sent Mark my tca and comp strut that Andrew at AG Motorsport made for me just to check it will all be ok with the gravel upright as it was made for standard but essentially a copy of grpa/wrc items and Mark has confirmed it will be fine.
I also sent Mark one of my rear steering arms, Andrew made these more to suit the 18" wheel so they are as big as you can fit inside the wheel without it touching, now they do the job but look very industrial, the problem i have is if i want to run the standard wrc rear steering arms my real link bars will not fit as they won't be long enough due to the more inward angle for the smaller arm so i have asked Mark if he can do me some wrc rear arms but re make them with stronger longer pins for the rose joints to keep the link bar angles wider just like the ones AG done for me, this will give me more clearance inside the rear wheels and look a lot better as well, he said it should not be a problem but just waiting for him to get back to me. pic's later this week hopefully of that stuff
I have sold my Piper Cams vernier pully's, i was not happy with the fact they only use 3 bolts to secure once timed up and i have seen quite a few cases of pully's slipping over the years so to be on the safe side i have ordered a set of Quaife Peg drive vernier pully's in alloy as pictured below,
They should of been here by now but are not so this site pic will have to do
No chance of them slipping with this due to the peg design, ok they are not as pretty but this is function over form.
Also all my power steering fittings and hose come through from the states, even though people have and do still use it i was not happy risking using the normal Aeroquip hose and fittings as they are not rated nearly high enough for power steering use so i ordered all the steel -6 fittings and 15ft of power steering hose as my pump is electric and is inside the car so i need a lot more of it, also i will also be running a small 7 row cooler.
Here is a pic of some of the fittings and 1 of the hose i made up to go from pump to bulkhead fitting
I plumbed the steering rack to the saxo electric pump and hooked it up to my car battery and filled it with fluid to check for leaks as i wasn't sure if my fittings had an exact 37degree angle on the seat as it was done by eye on my mini lathe, the good news is they did not leak and the pump was perfect after i stripped and rebuilt it
As far as Bodywork updates
I had a txt from Gaz who is painting and fitting the kit on the car yesterday to give me an update on where we are at,
He sourced a couple of different flexible fillers and types of bonding agents so he could do a couple of test panels and see what one gave the most flexability as my rear quarter panels could be an issue as far as cracking is concerned if something non flexible is used as the quarters join around the door shut and boot shut, which is gonna get slammed shut god knows how many times in the future, also as said before this is a track and race car if im lucky enough to afford to go down that route in the future so will get no end of abuse.
Gaz has done the test panels yesterday and will decide which is the better to use today and let me know the results, hopefully it will avoid the above problems, but he reckons were gonna be ok so fingers crossed and only time will tell i spose and if the worst happens and it starts to crack i will deal with it then and know that it is nothing to do with Gaz's work.
He is hopefully spending most of this week on the car and is aiming to have all panels lined up, rear quarters bonded on and blended in where needed, all the reapirs and dents sorted and into primer for the weekend so it can be left a while for it to settle down before paint.
The man works fast so will keep you guys updated
The problem i have now is i have to tell Gaz the final decision on color by mid week and i have not 100% decided yet
The worst thing ever is choosing a color on a car like this as it's hard to get the same effect off of a different shape car using the same color as all angles reflect differently.
I posted these pics previously of a mk1 escort in
VAUXHALL MOONLAND METALLIC
Then yesterday i went to the local BMW and AUDI dealerships to get a few more grey options that i am thinking of using.
This is the BMW SILVER GREY as used on the new 7 series
This is the BMW SPACE GREY as used on the new 3 series, it is slightly darker than the above
Then for the AUDI color, can't remember the name but have it written down somewhere
What's your opinions please?
Thanks
Marc
Old 18-07-2011, 10:24 AM
  #1519
Hman205
Hman205's Avatar
VAUXHALL MOONLAND METALLIC all the way!
Old 18-07-2011, 10:53 AM
  #1520
Mark RS
Mark RS's Avatar
vauxhall moonland!
Quick Reply: Mk6 JWRC fiesta cosworth
