Mk6 JWRC fiesta cosworth
18-08-2015, 05:41 PM
Great work mate you make things look so easy
19-08-2015, 08:15 AM
It's not always easy lol I just like to get stuck in and give it a go
I dread to think how much more this car would of cost if I paid someone else to do everything
20-08-2015, 07:38 PM
All looking good mate I'v got spacers of about 15mm on my center bearing to make it line up . But I think you no that as I think you have all the photos I'v ever put up about this mod
20-08-2015, 08:01 PM
Coley, where are your spacers, backing plate to clutch?
20-08-2015, 09:26 PM
Quote:
Originally Posted by
COLEYST200
I have them all saved on my phone so I have them to hand to compare things lol
Caddyshack
No Toby, Coley means the spacers on his center propshaft bearing for the rear prop
22-08-2015, 08:46 AM
22-08-2015, 02:43 PM
Tacked up gearbox mount today
Going to go and fully weld it now.
22-08-2015, 03:10 PM
22-08-2015, 03:23 PM
Fitted up
22-08-2015, 04:51 PM
Nice mount Marc
have you had this car weighed? what did it come in at?
22-08-2015, 04:53 PM
Car weighed in at 1215kg with 50ltrs of fuel
22-08-2015, 04:57 PM
That's rather good, i presume the new box and gubbins will up it a little but still a good weight
22-08-2015, 05:06 PM
Yeah I suppose the new box etc may up it by 30kgs or so but not fussed about weight of it at the moment just want a box more reliable
22-08-2015, 05:46 PM
22-08-2015, 07:39 PM
Cheers Ian / Rob
22-08-2015, 09:01 PM
Any forts on wot you might have to do to make the exhaust fit
22-08-2015, 09:09 PM
I whent custom prop on mine
22-08-2015, 09:17 PM
COLEYST200
Going to cut an exhaust tunnel on the passenger side, didn't want to but it the only decent way to do it
graham c
Il make up my props cut and shut style get them balanced and see how I get on with them, then look at decent custom items later
22-08-2015, 09:18 PM
aka Turbosailorboy
Location: Under the water.... .......in a nuclear submarine
Nice bracket mate
22-08-2015, 10:06 PM
22-08-2015, 10:32 PM
This car just keeps on evolving
Great work Marc
23-08-2015, 07:38 AM
Thanks Dave
23-08-2015, 06:04 PM
Basically copied Ian (Coley) on his Focos as its a simple mod I can do myself with my own lathe although machining this much steel on a Chinese mini lathe is a slow process
I need a bigger lathe
Anyway.......
Final test fit on the car
All ready to weld later tonight or in the week when I get a chance
Thanks
Marc
23-08-2015, 08:57 PM
aka Turbosailorboy
Nice progress Marc
How did you do the taper?
I have to struggle with this
23-08-2015, 09:34 PM
Must be hard with that Richie
Just used the cross slide set up to do the taper
All Tig welded up now
23-08-2015, 09:35 PM
Your moving on well this now mate
23-08-2015, 09:39 PM
aka Turbosailorboy
COLEYST200
And showing off with his welding
23-08-2015, 09:54 PM
Rear prop done and fitted (apart from sending off for balancing and refreshing the joint)
25-08-2015, 01:04 AM
saw this at the fair marc...... very nice build u have done!
25-08-2015, 01:50 AM
Thanks mate
25-08-2015, 11:59 AM
that looks horrible richie
nice welding marc
25-08-2015, 12:36 PM
Awesome work. Is the rear part of that prop a standard cosworth prop?
25-08-2015, 03:28 PM
Yes mate
Rear part is standard cosworth with the splines inside
25-08-2015, 04:40 PM
25-08-2015, 08:11 PM
Nice work mark
25-08-2015, 10:39 PM
Front prop done but its not straight and true so I welded it up anyway as an accurate dummy to be re made by a firm with 1 new piece,
So that's the props both sorted and I will drop them off to get made/balanced and joints renewed this week and I will crack on with the other stuff and welding in fill panels etc,
I dropped the box back out today, so tomorrow will re fit the front casing to the built up box and start working on the concentric cylinder mounting.
I also have a proper oilite bearing for the crank/input shaft
More pics to follow when more is done
Thanks
Marc
26-08-2015, 03:49 PM
Oilite pilot bearing machined and fitted today
Here is the closest bearing I could find
This has the correct length and correct OD but need the ID machining from 15mm to 16mm
So that's done and fitted
Next up is re fit clutch with new skyline spline plates
Also spoke to JW Engineering in Kent and I'm taking props there tomorrow day to be sorted and refreshed
Thanks
Marc
26-08-2015, 04:14 PM
Also measured up for my Tilton cylinder and I need a new spacer 41.5mm thick so will do that tomorrow
26-08-2015, 05:00 PM
Cool progress, I hope to pick up my modded tilton mount when I get back from hols, as long as zircotec deliver the other bits back to me I hope to bolt all mine back in.
26-08-2015, 09:00 PM
Fingers crossed it all goes smoothly this time when you put it back together mate
