***FRIJJ the White Westy - I'm Declaring it finished!***
#644
You'll like the wilwood 285 kit but you will need a front/rear bias setup on your car.
On the diff front depending on your chassis you may be able to go up to the 7.5" diff, later chassis are sized for it and have a spacer that you can fit to take the 7" setup. In the westie though the 7" is more than man enough for the job.
WRT the turbo, I've worked my way through the combinations from tweaked T3 upwards. On a westie the sweetest combination is the GT28RS, the GT2871 gives you more grunt but the extra little bit of lag means takes the edge off the enjoyment. Keep the turbine housing to a .63 max and it's OK, the .82 would be grim though.
Do yourself a favour though and get yourself a wideband and a proper ECU on there, your car was pretty grim to follow with all the flames, soot and unburned fuel coming out of there!
#645
Lee's car has both a very good ECU and wideband already and its also mapped by Stu at MSD so just about the best combo you can get IMO. Whats wrong with some flames on the overun?
On the diff front its about having a decent one, not one thats man enough for the job.
#646
The jubilee-clip boost-limit worked very nicely for the day thank you very much. With the benefit of a few minutes with the laptop to adjust the map we're back on a full 3D mapped setup, rather than the "better this than drive all the way back home again" setup
FWIW The 8 injectors top out at 80% duration, above 90% you tend not to flow any more anyway as all you're doing is hold them open during the open-close cycle, where they're already part open anyway. In terms of power I'll stake that at an honest 400bhp, to put that in context the "big name" remap on a P8/pectel setup that I used to run was officially rated at 330bhp, in the real world I called that 250bhp. Given those metric feel free to convert into whatever units you like.
Flames on overun means you're running too rich, it also means that you're destroying the silencer wadding. After following him I had to clean the unburnt fuel and soot off my windscreen! Perhaps it's the new exhaust causing it to run richer than it did but it could do with a tweak. If you had an aftermarket ECU on there then it's the work of minutes to correct, with the L8 it's a PITA.
Whilst the 7" LSD isn't perfect changing it for something "better" would be some way down my list of priorities, there's plenty of other things to more productively spend money on first.
#648
To point out the glaringly obvious flaw in your argument you set up your engine so that it can run at sustained WOT, if your piston cooling (by virtue of blowthrough on cam overlap and your under-piston oil jets) is good enough for WOT then when it's off throttle and generating no heat then it's going to be just fine. To take your suggestion to the point of the ridiculous you would have to rate every engine for a maximum of X seconds of WOT before you'd have to enforce Y seconds of "cooling overrun".
FYI peak EGT happens at around a stoichometric mixture (ie a nice gentle cruise), under WOT your EGTs are much lower. There's not much good information on EGT tuning on the net but if you want to borrow some decent books on the subject give me a shout.
#649
Caraholic
Not all tuned cossies do it and it's not really necessary, nor is it particularly beneficial as the cooling effects of the fuel are minimal and the detrimental effects to turbos and silencers of fuel igniting there are substantial.
Given your last statement, please explain why my EGTs are 700°C on a light cruise (at almost stoich), but almost 900°C at sustained WOT at mid 11s ? Might I also suggest you do a bit of real world testing, rather than guessing .
#650
*** Sierra RS Custard ***
Mike, ZERO fuel on overun is also good for cooling, ie an actual fuel cut, as few things generate less heat than not burning anything and just blowing cool air through the engine.
Running lean is the worst for heat though, it needs to be either rich or nothing at all, and nothing at all can cause problems when you get back on the throttle with a lean spot as it wets the manifold again.
#651
600-700 on cruise is easily achieved IMHO, but is very difficult to maintain on WOT
Have you ever actually had an EGT gauge on a car yourself, as I personalyl think that probably you are reading too much into theory and have no real world experience of it.
#653
On cruise you're trying to burn everything in the chamber as efficiently as possible, at WOT you don't care about efficiency so are prepared to let it burn later in the cycle and indeed still be burning as the ports open and the burning gas rushes out of the exhaust. When that's the case the EGT results can mislead you as the probe is seeing the full fury of the flame front rather than just the temperature of the resultant gas.
#654
You really are teaching your grandma to suck eggs here mate!
#655
Can you perhaps just let us know a little about yourself.
Do you map your own car, or was it mapped by someone else?
My answer: I do
Is that the only car you have mapped or have you mapped many cars, if so where they turbo cars or N/A cars?
My answer: Many cars, mostly turbo but a few N/A ones as well, before I had mapping facilities I was tuning cars on carb and dizzy setups
Do you monitor EGT and AFR on your car?
My answer: I do on some cars I map but not all, I always monitor AFR just not always EGT
would just help us all a little to know a little bit about your background when reading your commments
Have filled my own answers in just so you can learn a bit about us too
My answer: I do
#659
cng1, by the way, allowing a boost leak to persist deliberately is an horrific bodge IMHO, you will be pushing the turbo WAY WAY WAY over to the righthand side of the compressor map, which will result in overspooling of the turbo and decreased volumetric efficiency of the engine itself due to pumping losses when working the turbo that hard, its no wonder Lee kicked your arse round track with that sort of bodge on your car
#660
The change to driving approach was to never use more than about 60% throttle or 0.5bar boost, the safety mod was to loosen a jubilee on one of the boost hoses such that if I used too much boost (more than about 1 bar) it would allow a controlled amount to vent and prevent the problem that I was suffering from. Better to incur a small amount of risk on the turbo than a large risk on the whole engine.
As it happened the boost-limit mod was used precisely once during the day - on the last lap of the day as the chequered flag came out. I knew what the limits were and by working with the car I had no problems. To me that sounds like a substantial success. Now I could have left everything alone and avoided the snide comments and just driven it like it was but I'd personally rather have a backup planned in, wouldn't you?
#661
Oh just out of interest, this is my car at the ring (not me driving) with a 20st passenger back when it was back in what I refer to as the "250bhp" state of tune:
http://www.youtube.com/watch?v=_InrLEU4cyo
Back then it only had a tiny IC rather than the big-arsed Pace chargecooler and water injection setup that it has now. The result being that on that lap the inlet temps hit 60C and the ecu was limiting the fun.
#664
200 inc vat for a set of four fitted? I think not.
Replumbed wastegate was allowing boost over and above the area I've mapped. A few minutes with a laptop would have had the extra setup done but having not taken a laptop with me my options were limited.
Why did you have to limit boost by the way?
#665
About that mate yes!
You should have said, I had a mapping laptop with the emarald software on it with me, and a set of detcans and a wideband, you could have borrowed it.
#666
Caraholic
#667
If you can tell me where sells and fits a set of R888s for 200-ish quid (2*225/50R15 and 2*205/50R15) then I'll be stockpiling a few sets, last time I looked they were more like twice that price.
Pah. Next time I'll get a tannoy announcement put out - "Could anyone with a laptop and Emerald K3 software please report to..." Widebands I don't need though, I've got plenty already ta
#668
Not much of Johns car left these days. Diff, box, radiator, the scabby old bonnet and the seats are about all that's left. Oh and the right front aluminium upright, the bootlid and one of the fuel pumps.
I guess you now have a better idea of what the car can do when it's running properly, albeit now it has 50% more get up and go than it did back then. These days even with me driving very little catches me on the track unless I'm letting them through
#669
Right well, lets get this going again. Today saw the ordering of:
Here is a familiar sight! BRUM back in my garage for some upgrades!
Here is what is left of the rear brakes after Bedford
Both mine and his go in for custom full cages in 2 weeks too.
Will let Lee do the talking from now on!
- New bigger 285mm Front Discs
- New bigger 253mm Rear Discs
- New 4 pot Lightweight Calipers all round
- New Lightweight Seats
- New Steering Rack, Track Rod Ends and Rack Mounts
- New Boost Controller
- Aquamist Water Injection Kit
- New Lightweight Rear Shocks
- New Pads all round
- New Braided brake lines all round
- Plumber in fire extinguisher system
- New Handbrake cables
- New lightweight Alloy Front Hubs and Wheel Bearings
#670
I've just sat here for the last 2 hours or so and read through the full thread, gotta say hat's off to everyone involved especially Stu, Foxy and the project boss LOL Top work fella's Will be keeping my eye on this thread for more updates and hopefully see it blasting round the track at some of the shows this summer
Keep up the good work lad's
Carl
Carl
#672
NOW HURRY UP AND FIT IT ALL MONKEY NUTS
Chop fucking chop!!!!
I LOVE MY BATHTUB!!!
Totally and utterly LOVE it!!!!!
Just soooooooo much fun and soooo involving and thrilling to drive. It can be a little scary as well though but thats cool too!
#679
Whatsize brakes were on it before,with what pads, and what problems were found if you dont mind me asking?
Im trying to pick a spec for mine just now...
#680
The front had 260mm AP 4pots. With seperate bells and vented rotors. Think Ferrodo DS3000 pads?
They are for sale if you are interested. Chip, Stu and Rainbird all thought they were fine and upto the job when they drove it at Bedford.
I thought they were poo
I like to REALLY stand on the brakes corner after corner. Basically in my opinion when it comes to braking.... if you are not locking the wheels then you are not trying hard enough
Stu has 10 pence pieces for brakes!! NON vented front discs to save weight!!! about 100mm I think!
