MY 205 GTI-6 Supercharged Track car
#562
no, but someone on here is breaking a gti6 with dead engine, the head might be ok?
her username is >>>> https://passionford.com/forum/members/563-bigmatt-s2rst.html
cheers matey
cheers matey
#565
Time for a little update, the engine is a little closer to being fitter, just need my pedal box painted and fitted and it can go back in
swapped the Quaife over into a 1.6 box and gave a lick of paint
Had the valance painted
Rear hatch painted
bonnet painted
Changed my mind on the cabling, it was starting to look cluttered, so moved the fuse box's and relays inside the car now , as you can see look much better
My new expansion tank, as the old one wasn't see through, so couldn't tell if there was any water in there, or if it had mixed with oil
Had the battery tray powder coated, as it was looking very minging..lol
here is my new washer bottle, and the new location for the fuse holder and relays
#569
i know
just been back out there and the aero catch's are finished in the rear hatch now, just need to bond the rear screen on the hatch and it's finished
will try and do the aero catch's in the bonnet tomorrow
#571
well big update,
Paul has made me a pedal box.... looks awesome too.
painted it the same colour as the engine bay.
this was the last peice needed so i could re-fit the engine, so 90 mins after assembling the pedal box.
woohoo engine and box back in
#579
does it come with the cap?
Take it has the correct number or outlets? think there are two(one big and one very small) used on my car and one blancked off.
#581
well had an hour in the garage last night, also thanks for paul for popping in after working to give a hand (though i dont think thats was his intension..lol)
309 ARB fitted to the subframe and the subframe bolted in place with STD length bottom arm
her are the clearances i have now
#583
well had another few hours this evening, not much left now
tonights work
connect up low pressure warning (this has never been done..lol)
wire up alternator (i've put the gti6 one on now)
route engine loom to inside
fit all the gear linkages,gearstick,reverse cable,new top hats on gear linkages,
fit speedo cable and VSS
clutch cable
oil cooler
some water pipes at the rear of the engine, and to expansion tank
found a new place for ECU (next to exp tank, not ideal, but it's going there)
rivet inertia switch to inner wing
connect steering rack up
here are some random pictures
tonights work
clutch cable
oil cooler
#587
check out this thread Spiky.
its my mates 205.
http://www.falkirkcruise.net/forum/v...hp?f=7&t=31960
its my mates 205.
#589
its my mates 205.
its my mates 205.
looks good though, what engne? he going for and what power?
yeah, getting there , have a full day to work on it tomorrow, so should be able to get a few things done
#592
and a few more hours in the garage...lol
thats it for this week, will spend some time with sarah and lewin now
thought she is making sort the scaletrix out for xmas, so not all bad..lol
anyhow here are some pics
as i have my top mounts on top my bonnet wont shut, do you think it looks crap?
the arch's aren't dry and the pcis make it look worse than it is...
#593
starting to see end of the tunnel now, lomst everything is back on the car
Left to do now
buy a new set of 309 wishbones, so i dont need to rush to make the ADJ one's
exhaust still needs to be re angled to fit the newly positioned ex manifold
screen fitted to the rear hatch.
buy and fit new SRF brake fluid
fix TPS wiring
buy and fit 76mm 90 degree pipe for airfilter
buy and fit std 8v water top hose
Left to do now
fix TPS wiring
#595
Lukesville
Mate looks wicked will be awesome on track in New Year..
One thing though, I put some of that grip tape on the floor of the festa.
Drove to Castle Combe few weeks back and by the time I got home it had sanded my heel through to the inner sole
What grit you running the DS300 or the DS2000
#596
it's the new ds4000
#597
i have some of that tape waiting to go into mine!!! along with some smaller squares to go onto the pedals! great minds
and love the car, the bonnet looks great, how did you get over the fitting problems? you may have mentioned it but i havent read it properly really!! haha
#598
the suspension is mounted underneath at the moment, will have to raise the front to stop it bottoming out (the whole reason for mounting suspension on top)
while i decide what to do
it's pretty much there now,
exhaust was welded up last night,
MASSIVE THANKS TO PAUL (3DR-RALLY-SLAG)
#600
i bloody hope it's dry too..lol
nice one dude, you have wet and dry tyres so you will be ok
going to finish the rear hatch tonight hopefully, then that will be done,
just awaiting my new wishbones and the front suspension can be finished off
make a bracket for my rad and think i'm almost there, and mount my new gauge
