My 3dr Cosworth project updated (16.01.12)*
Old 07-03-2009, 03:58 PM
  #481
fezzajsy
fezzajsy's Avatar
looks awesome mate
Old 07-03-2009, 04:05 PM
  #482
TimC
TimC's Avatar
Some real trick bits on this. Whats the engine spec Gav?
Old 07-03-2009, 06:34 PM
  #483
Gav Diamond
Gav Diamond's Avatar
Cheers guys
Originally Posted by Richie.
Looking lovely there Gav
Loving the breather set up You got a catch tank off that ?
Any future plans or you just going to use it ? You fancy risking R888s in the wet
No catch tank dude, vents to air under the car but seems to be working ok as no loss of oil and it doesn't smoke
Spoke to Martin about a hour ago about some R888's as i need some grip, lol
Not bothered about the wet as it will just stay parked up
Furute plans include some bigger injectors so we can raise the boost but ok for now as its fast enough for the time being.
Hydrolic clutch as the cables are not lasting very long, got 2000miles out the last one
Tremec TKO once the funds allow as used the car for 1 day with some boost and the T5 is whining already, lol
AquariousRS
200 Block
Long studded etc
Knife edged crank
Arrow steel rods
WRC (i think) spec pistons
all balanced with flywheel
3 layer gasket
A1 Rally Sport spec head
A1 Rally Sport spec cams
Swedish inlet
GT35 Turbo
Reyland modded 2wd manifold
Siemens injectors
Pectel T2 Management
T6 Loom modded by Carlooms for the T2
Sure there is more but cant think
Might dig out the big disk kit for the rear and get that on tomorrow if i get time
Old 07-03-2009, 07:06 PM
  #484
Richie.
aka Turbosailorboy
Richie.'s Avatar
Location: Under the water.... .......in a nuclear submarine
Ok cool
Not out in the wet ? ? ? You turned into a bufty ?
Hydraulic clutch is way forward. Got one in the Saff and its lovely . You going for centre push version or just the kit Martoooooon uses ?
Old 07-03-2009, 07:14 PM
  #485
Gav Diamond
Will be center push once i can afford a Tremec
Took the car out with damp roads and it will spin the wheels in most gears so on R888's will be dangerous and its took me long enough to get it on the road as it is
Old 07-03-2009, 07:15 PM
  #486
Richie.
aka Turbosailorboy
Richie.'s Avatar
Fairy muff
Old 08-03-2009, 02:34 PM
  #487
COLEYST200
COLEYST200's Avatar
Hi mate wot cams have you put in
Old 08-03-2009, 03:38 PM
  #488
Gav Diamond
Not a clue matey, Steve spec'ed the engine
Just doing the Nuts Rus big rear disk kit so will have another update later today
Old 08-03-2009, 06:23 PM
  #489
Gav Diamond
Thought i would fit the 300mm rear disk kit today that has been sitting around for ages
This is the kit Nuts Rus sells
So wheel off and what we are removing
Old stuff off
The reason for changing
New stuff on
Passenger side done easy as that
Round to drivers side, so same as other side all stripped down.
Start to put the new stuff on and problem.........handbrake cable is too short to allow the caliper on thought maybe i had the brakets on the wrong way so tried the other way which puts the caliper further forward, wasn't happy thinking i was going to have to change the other side round so they are the same though.
Note caliper is center top now
But that doesn't work as the flexi brake lines are too short then
Only way i could see was to un-clip the hand brake cable and move it from the outside of the drop-link to the inside and secure with a cable tie
Bracket flipped round again and all bolted up, think it looks better set back anyway
Job done
Sorry for boring people but it may help if someone else goes to do this
Old 08-03-2009, 06:34 PM
  #490
Sonic Boom
Sonic Boom's Avatar
How much is that rear brake kit?
Looks very smart.
Rich
Old 08-03-2009, 06:47 PM
  #491
Gav Diamond
Looks very smart.
Rich
Here is the thread matey
https://passionford.com/forum/sin-bin/247699-cosworth-4x4-300mm-rear-upgrade-kits.html
Old 08-03-2009, 07:04 PM
  #492
Sonic Boom
Sonic Boom's Avatar
Cheers Fella
Should have know it was Comp brake, I have there 6 Pot 350mm Kit on the front already.
Rich
Old 08-03-2009, 07:45 PM
  #493
Gav Diamond
No worries bud
And cheers for the pm
Old 08-03-2009, 08:02 PM
  #494
Stu @ Claims Care Centre
Compensation Specialist
Stu @ Claims Care Centre's Avatar
how do you find the gt35 i have a very similar spec to yours with a gt35 .82 housing.
what boost you running? and what spring in the external wastegate as i have the same also
Old 08-03-2009, 08:18 PM
  #495
mercury grey minter
mercury grey minter's Avatar
Saw this car last week at rolling road session in solihull,looked nice on the mo,s
Old 09-03-2009, 12:47 PM
  #496
Gav Diamond
Not sure of the spring mate as i didn't fit it.
Running 1.6bar at the moment but will be 2bar plus once i change the injectors
Seems a good turbo but i have not really driven the car for a good few years so have nothing to compare it to.
mercury grey minter
You should have popped over and said hello, what car was you there with?
Please don't call my wheels MO's..........It took me ages to find a set of Dymags to be different
Old 09-03-2009, 03:37 PM
  #497
marco polo
marco polo's Avatar
yo gav
looking good as ever , seriously you will need to hydro clutch it , fook the cable off
once it's done you will wish you dont it yrs ago
good luck with it
marco
Old 09-03-2009, 06:15 PM
  #498
Gav Diamond
Cheers bud
Just wanting to do some tidying up at the minute, will be doing the inside once i get some carpet as not a fan of totally stripped out for road use.
Need to get some gauges as well plus fit the AIM dash display.
Plus need to get the arches modded and a re-paint.......where does it end, lol
Old 09-03-2009, 07:25 PM
  #499
Brakes look great
Old 09-03-2009, 09:30 PM
  #500
mercury grey minter
mercury grey minter
Was in my mates evo.If you wanted your rims to be different,you should of got 3 spokes.lol
Old 10-03-2009, 06:15 PM
  #501
Gav Diamond
Cool man, was a few nice evo's there
As for the 3 spokes, erm.........i'll give it a miss
Cheers Twins
Old 10-03-2009, 08:11 PM
  #502
fezzajsy
fezzajsy's Avatar
looking good,just got my rear brakes from Tony,well happy
Old 10-03-2009, 08:20 PM
  #503
Daviet
Daviet's Avatar
stunning car mate and a quality spec to match
i remember reading this post when i first signed up to pf years ago.glad to see its finally on the road and getting used and abused
are you leaving the bump strips off?
Old 11-03-2009, 01:31 PM
  #504
Gav Diamond
Cheers guys
Daviet
Will be putting the side strips back on but the car needs repainting first as the paint is pretty much falling off at the moment
Old 11-03-2009, 01:44 PM
  #505
CraigoScott
CraigoScott's Avatar
Cheers guys
Daviet
shit the bed, is that caused by a reaction? did they use house paint?/?
i wouldnt be taking it back to whoever did that mate, get someone else to do it!! you having it painted all over?
Old 11-03-2009, 01:48 PM
  #506
Gav Diamond
The whole car is being painted yes mate.
This is what happens when you have water under the paint and when some welding was done it boiled the water, well so a couple of painters have told me.
The roof and the front wings are bad also but you can only see this when it freezes as it all blisters up.
Old 11-03-2009, 02:57 PM
  #507
CraigoScott
jesus thats bad! get it done asap mate, you dont want it rusting up on you again!
Old 13-03-2009, 06:23 PM
  #508
PAUL_SHEP
PAUL_SHEP's Avatar
awesome car fella!
Old 13-03-2009, 08:03 PM
  #509
COLEYST200
COLEYST200's Avatar
f.cking hell mate
Old 13-03-2009, 08:28 PM
  #510
bigchez
bigchez's Avatar
Great car fella just read from start to finish
I work with Andrew Ward who i think you know from Yamworth mentioned your car - looks awesome especially the inlet
Old 13-03-2009, 09:23 PM
  #511
andy escos
andy escos's Avatar
great looking car with a really good spec took some time to do are you happy with the spec or is there any more work on the horizon .
Old 14-03-2009, 06:40 PM
  #512
Jumbo
Jumbo's Avatar
Jesus Gav, bet your pissed how the paintwork has gone
Will have to pop up your sides one of the nites with Coley
You've had shit luck with paint, so Good Luck this time round!
Old 14-03-2009, 09:41 PM
  #513
Gav Diamond
Cheers guys
bigchez
Andrew from Rawlett?
Was a good mate of mine back.......gotta be 11yrs ago in school, man i feel old now
You got a great 3dr too bud, i know Mark the previous owner
andy escos
There is abit more to be done but its jobs like getting the suspesion set-up and working properly, possibly a 6degree beam at some point and just a tidy up and use it as its been away for along time, the injectors are pretty much maxed out so will be changing them soon but the car is fast enough for the time being.
Jumbo
Dude you know this car has fought me at every oportunity, the amount of things that have gone wrong and not fitted etc has pushed me to the edge at some points, ask me Dad. He had to forcably remove the lump hammer from me when i was going to smash it to bits as i had lost it but im abit more chilled these days and to be honest i couldn't care less about the paint at the minute as i just love driving it, puts a smile on your face, im like a cheshire cat specially on the bypass
Will get the paint done at some point, going to see me mate soon about modding the kit as the tyres are just ripping them to bits when it comes on boost then will speak to me painter bloke to sort something out, im not going for a mega clean car as i want to use it doing track days/Santa pod etc where it will get knocked about anyway.
Old 17-03-2009, 06:40 PM
  #514
Gav Diamond
Well today has been another day of disapointments with the car, decided to go and see Millenium the body shop that painted the car as they put into writing they would re-paint the car for free as a warranty job as the paint is shite to put it nicely.
Well the good news is..........They have gone into liqiudation and are no more
Been to another bodyshop in Nuneaton that have told me just how bad my paint is, Also the reason for all the problems is that the paint used was mega cheap rubbish.
They quoted me £2500 to paint the car and sort the bad bits out and mod the arches, flush the petrol filler cap etc
Anyone got £2500 they wanna lend me
Old 17-03-2009, 07:04 PM
  #515
bloody hell not seen paint like that before, and i have been about the trade for years ,not good news on the bodyshop
Old 17-03-2009, 07:13 PM
  #516
Gav Diamond
To be honest i was a bit gutted they went bust as it means i have to pay again, but if this is the standard of work its no suprise really.
The guys i spoke to today were telling me that the paint they use is about £90 a litre (dunno if thats good or bad) but it looks like the stuff used is probably about £20/litre, he was also suprised at how many different shades were on the car seeing as it was all painted together and that it is nowhere near Diamond White.
He was saying there is alot of Green in it (if that makes sense?)
Old 17-03-2009, 07:19 PM
  #517
Ryan
Ryan's Avatar
shite news gav
Old 17-03-2009, 11:28 PM
  #518
Gav Diamond
Originally Posted by Ryan
shite news gav
This car is really starting to push my patience again to be honest dude now it has sunk in a bit and i have had time to think about it.
I had to have welding done for the MOT which annoyed me a little as i always thought the shell was a pretty good one, now i need to spend another £2500 to have the car all one colour and sort out someone else's mess. I really don't know if i am prepared to spend that sort of money as what i had saved up was to go towards a Tremec Gearbox which i will need sooner rather than later due to the standard one already showing signs its not going to hold on much longer.
So we are up to £5000+ already (gearbox and paint) and my work is telling us we will be losing our bonus soon due to the recession which counts for 26% of my wages so money will be tight so dunno if its worth doing.
Old 17-03-2009, 11:41 PM
  #519
fezzajsy
fezzajsy's Avatar
gutted for you Gav..hope you able to sort it out one way or another
Old 17-03-2009, 11:55 PM
  #520
COLEYST200
COLEYST200's Avatar
give my mate a ring mate and ask jason. tell him ian cole told you to ring a mate of dean,s it down by ASDA MINWORTH
Quick Reply: My 3dr Cosworth project updated (16.01.12)*
