WTF HAVE I DONE ERST HELP NEEDED
Done a service on my erst today. Changes oil, oil filter, fuel filter, plugs, leads, rotor and cap
And now i cant get the thing to start. Chacked i have the leads in the in the right plug in the cap took um out and started again and still cant get it to go.
Any ideas. Gotta drive a fair way in it tomorrow to. Also every so often it makes a huge bang out the back of the zorts when its turning over,
AGHHHHHHHHH help
AGHHHHHHHHH help
Its probably because you changed the fuel filter. Prime the pump a good few times (ingnition on, but don't start, then off for a while then repeat a few times) My old turbo was the same - twas a bastard to start after it ran out of petrol or when i changed the filter.
Originally Posted by Billabong
Dizzy cap on correctly? IIRC they go on both ways, but only one is correct (unless it's XR3i I'm thinking of) Try turning through 180 degrees.
Irritating c........
Last time I had a problem that sounds like yours (turning not firing, then BANG) it turned otu to be the rotor arm thingy, changed it and presto, worked fine
JoeyBoyden
04-01-2024 02:36 PM
rog
04-09-2015 12:10 PM
borboyous
22-08-2015 11:17 AM
