working out compression ratio...
Old Dec 15, 2005 | 04:13 PM
Wazzzer's Avatar
Wazzzer
Default working out compression ratio...
right I'm having no luck finding out the compression ratio of my engine so I might end up having to work it out myself...
What do you need to do this? The engine is built and running but I have access to a piston that came out of it originally (this is the second set due to the previous owner being boost happy lol) so I can get the piston size from it...
Old Dec 15, 2005 | 04:14 PM
Rick's Avatar
Rick
Can't do it mate, as u need to measure the deck height, and the combustion chamber volume.
Old Dec 15, 2005 | 04:18 PM
Agree with rick, not possible without stripping the engine.
Old Dec 15, 2005 | 04:23 PM
Wazzzer's Avatar
Wazzzer
thats me fucked then, cheers anyways
Old Dec 15, 2005 | 04:25 PM
you only need to whip the head off, CC it, measure the deckheight, and pop it back together.
Cost you a bit for new gasket + bolts, but hardly the end of the world, and will only take an afternoon as head doesnt need skimming in those circumstances. (although getting it checked for flatness while off is a good idea of course)
Old Dec 15, 2005 | 04:28 PM
Wazzzer's Avatar
Wazzzer
I've only just got it running and its taken me months to get it to this state, I'm not pulling it apart again lol
My last hope is Torque Developments (where the engine came from), I'll see if they can shed any light on it 2moro
Old Dec 15, 2005 | 04:29 PM
Well whoever built it should still have all these figures written down if you give them the serial number off the engine.
Old Dec 15, 2005 | 04:57 PM
Wazzzer's Avatar
Wazzzer
woo hoo just got word back from them, thanks for all your help guys, looks like I will be able to order my chip now
Old Dec 15, 2005 | 05:05 PM
M Brian's Avatar
M Brian
does it actually matter at this stage?
if you assume standard comp if a 1600 and get it set up to its optimum then surely this will highlight whether the compression is too high for the intended boost and have to be backed off... regardless of the comp ratio?
i.e. if you are at a level of tune that the exact compression ratio is significant then Ł100 or so for bits to take off and measure can't be too bad can it?
Old Dec 15, 2005 | 05:19 PM
Wazzzer's Avatar
Wazzzer
Stu asked for the comp ratio of my engine for the chip mate, ordinarilly I wouldn't care lol
Old Dec 15, 2005 | 05:21 PM
Stu @ M Developments's Avatar
PassionFords Creator
One of my favourite quotes:
"The difference between ordinary and Extraordinary is that little extra"
Well done on making the effort Wes
YODI
Aug 30, 2015 01:12 PM
155lee
Aug 14, 2015 11:21 AM
Zoggon
Aug 10, 2015 10:39 AM
Caddyshack
15
Aug 4, 2015 08:50 AM
