Anyone bolted 2 engine together?
21-11-2005, 05:06 PM
As above, as in weld the crank of one to the other and put it thru the same transmission?
21-11-2005, 05:17 PM
i think it might be a bit front heavy mate!!
understeer anyone!?
(assuming you were thinking of putting it in the front!!)
21-11-2005, 05:22 PM
good luck balancing it properly
21-11-2005, 05:24 PM
Football Cwazy
didn't they try to do that on scrapheap challenge yesterday
21-11-2005, 05:25 PM
Resident Wrestling Legend
bolt the rear engine to the front via a torque converter
that way you have to seperate engines that, if they produce the same power, will be spot on
21-11-2005, 06:29 PM
Yeah scrap heap challenge. This is to go in a capri, in the passenger seat, only have to trun one way so i want the weight there, 2 v8's
21-11-2005, 06:31 PM
Chasing Radders
Aston Martin do it with 2 Mondeo V6,s
Vanquish anyone
21-11-2005, 08:56 PM
Quote:
Vanquish anyone
Is that true?
21-11-2005, 09:00 PM
Everything you see posted on here is true, It must be because I just said it.
21-11-2005, 09:03 PM
21-11-2005, 09:04 PM
Chasing Radders
Quote:
Vanquish anyone
Is that true?
Yes mate
tiff is semi true but not as in the rawness of it ha ha
21-11-2005, 09:10 PM
Chasing Radders
Here you go, just to clear things up
"The 6.0 L V12 used in Aston Martin cars is sometimes erroneously referred to as "essentially two 3.0 L V6 units bolted together". In reality, the engine is custom-built for Aston Martin by Cosworth Technology (both Aston Martin and Cosworth are owned by Ford) and while it uses some standard Duratec components, it is Cosworth's own design. Aston Martin use this engine in the DB7 Vantage, the V12 Vanquish and the DB9."
21-11-2005, 09:13 PM
i know that tiff but they dont take two mondeo engine out and weld them together mate he he
21-11-2005, 09:15 PM
Chasing Radders
I know that....see above
22-11-2005, 06:48 AM
Like what i want to do to to V8's can you imagine the sound
22-11-2005, 06:53 AM
Legend
Quote:
Originally Posted by Stu @ Fordsport
Bikers love doing it
There you go again with the
stuff.
22-11-2005, 08:48 PM
22-11-2005, 08:54 PM
stuff.
PMSL
that siggy thingy is ace
Toms Grende
13
22-08-2015 03:39 PM
JoeyBoyden
14
15-08-2015 09:51 PM
Gadget
Ford Escort RS Cosworth
14-08-2015 07:19 AM
Gadget
13-08-2015 08:19 PM
track.focus'd
12-08-2015 05:53 PM
