Is this Cossie ECU standard? (pics)
Help pleeeease.........
Is this Cossie ECU a standard one?
Is it from a Saph 4x4 or Es Cos?
Does the baby board fitted mean that it is a greens (or whatever) modified/chipped ECU???
Standard sapphire 4x4 redtop ecu with standard software fitted.
The babyboard fitted is indeed a standard one, not a pectel or other aftermarket type.
Doug,
If you plan on fitting a pectel board to it, i iwll give you a few quid for the standard one as a spare. Same goes to anyone else with a standard L8 board lying around
Doug,
Thanks for all the replies.......
Stu, I am thinking of fitting a Pectel board, but will the one I have (see pics below) work with the above ECU?
It is a greens stage 3 chip supplied by SCS.....but I think it's for an Es Cos ECU only
Originally Posted by Stu @ M Developments
Doug, If you plan on fitting a pectel board to it, i iwll give you a few quid for the standard one as a spare. Same goes to anyone else with a standard L8 board lying around
kosienutter
31
22-08-2015 09:55 AM
CabrioTurbo
01-08-2015 11:04 AM
