Shells for line bored blocks
Old Oct 16, 2005 | 06:12 PM
Manchester Mike's Avatar
Manchester Mike
Default Shells for line bored blocks
Are these available from ford, i have a 0.4mm line bored block which i want new shells for but not much point in rebuilding the engine if i can't get hold of them
Thanks in advance, again
Old Oct 16, 2005 | 06:37 PM
DOO's Avatar
DOO
ford used to sale the Main crank bearings 0.40mm not sure if still avab
finis 6071882 £19.53 each +vat.
Thats well over £200 a set
I will check the avab tomorrow for you.
Old Oct 16, 2005 | 06:47 PM
Manchester Mike
Yeah its the mains i'm after
Over £200 a set
I may as well walk in with my pants around my ankles
Thanks for the help mate
Old Oct 17, 2005 | 09:43 AM
DOO's Avatar
DOO
Yes mate there still avab
Old Oct 17, 2005 | 09:50 AM
How come you didnt get the caps skimmed first so that it was back to std size?
Old Oct 17, 2005 | 03:19 PM
Manchester Mike
I'm not sure what you mean mate, i've only just learnt that line boring exists.
I bought the engine to strip down and rebuild, when i took the crank out i noticed that the main bearing shells said..
STD (crank side)
+0.40 (block side)
is there anyway i can get around having to pay for these from ford or should i just be prepared for them to spank me?
Thanks for the help guys
Old Oct 17, 2005 | 04:02 PM
When you line bore a block you can either take it out bigger to get it round again, or you can skim the faces and then linebore it back at the original size.
Ive always used the method where they stay the same size and use the same bearings.
Old Oct 17, 2005 | 04:38 PM
Manchester Mike
I see what you mean now mate thanks, yeah would be great if i could use origanal size bearings but the block had already been line bored before i got my hands on it.
So looks like over £200 just for new mains then bloody crank is mint as well, doesn't need a regrind, its its just having a polish.
Wish the block hadn't been line bored
jessie_rs
62
Aug 6, 2019 09:27 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
IainRS1700T
Sep 25, 2015 06:44 AM
timsrs
22
Sep 24, 2015 08:14 PM
