Gutted and need advice from engine builders
Old 06-10-2005 | 02:47 PM
Ratty's Avatar
Ratty
Default Gutted and need advice from engine builders
Took head apart to change tappets today and got worried when I found this
And this
Thinking I may have to get a new pair of cams, but OH no much worse was to follow
So thats twice a sweat running engine I've bought has been less than useable (<real tears)
Can anything be done with it or is it new head time
Thinking about putting the 1.8 back in again
Old 06-10-2005 | 03:49 PM
Spiky's Avatar
Spiky
that oil looks a very weird colour
Old 06-10-2005 | 03:56 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
wounder mate.
only thing i can think of is to have the head line bored but it will cost a fortune and you will need new cams and bearing liners too
Old 06-10-2005 | 04:12 PM
Ratty's Avatar
Ratty
Spiky dunno why oil is that colour prob just the camera flash
fudgeass I beginning to think you may be right
I've asked Mark from MAD to take a look and see what options I have
Old 06-10-2005 | 04:15 PM
Neil S's Avatar
Neil S
Don't panic mate... My cam bearings were worse.
After advice from both stu and Karl, I gently dressed the bearings and caps off wit 1000grit, then built them up again.
I think what Karl said was to do this, put it back together without tappets, then see if there was any play in the cam bearings. If not, then it's all good.
It's probably picked up on start-up the last time the cams had been out.
I reckon its caused by the shape of the cam bearing - it kind of wipes the oil off as the cam turns. When I rebuilt it, I filled the engine by pouring oil directly over the cams before putting the cover back on
Neil.
Old 06-10-2005 | 04:21 PM
Neil S's Avatar
Neil S
Sorry, it was 400 grit
https://passionford.com/forum/viewtopic.php?t=66979
Neil.
Old 06-10-2005 | 04:35 PM
Ratty's Avatar
Ratty
Cheers for that Neil maybe some hope then
Old 06-10-2005 | 06:03 PM
Al Bags's Avatar
Al Bags
Hmmm .. I always use anti-scuffing paste .. and gear oil at first. Looks like it might have been a bit dry at that end for a while.
Old 06-10-2005 | 07:01 PM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
if its a 4x4 the oil feed for the turbo is straight out of the gallery that feeds the lifters and starves the lifters of oil as it takes the path of least resistance i bet that is the exhaust side i would use the head again by dressing them up as karl/stu said
Old 06-10-2005 | 07:10 PM
AJ Escos's Avatar
AJ Escos
and change to a 2wd oil feed pipe that takes its feed from the block
Old 06-10-2005 | 07:30 PM
Neil S's Avatar
Neil S
Ahhhh! I've heard people say that the 2wd oil feed is better, but no-one has ever explained why!
Neil.
Old 06-10-2005 | 07:34 PM
The Sludge's Avatar
The Sludge
garibaldi
ouch! dont look too good does it tho. I dint realise you could use grit paper to make it good,
Old 06-10-2005 | 07:44 PM
AJ Escos's Avatar
AJ Escos
Neil.
doesn't take pressure of the head mate
Old 06-10-2005 | 07:53 PM
Doctay's Avatar
Doctay
I wish i knew what the fook you lot were on aboot!
Old 06-10-2005 | 08:15 PM
Ratty's Avatar
Ratty
Its 2wd so oil feed is already from block and yes its is exhaust side thats gone
Old 06-10-2005 | 08:47 PM
Rs Gus's Avatar
Rs Gus
it always seems to be the exhaust side that cops it other explanation maybe the engine has run low on oil I SAY LOW not OUT as a yb can nearly hold the sump contents higher up the engine so oil becomes scarse and the furthest point cops it been the exhaust cam/turbo dip the oil and see it could have been done for ages though u never know
Old 06-10-2005 | 09:13 PM
Matt's Avatar
Matt
metal spray and line bore back to tolerence?
Old 06-10-2005 | 09:45 PM
Rs Gus's Avatar
Rs Gus
new head?
Old 07-10-2005 | 08:00 AM
Neil S's Avatar
Neil S
Wet and Dry?
Old 07-10-2005 | 08:04 AM
Graceland's Avatar
Graceland
Team HOTHOT!
i bet its picked up on numbers 2 and 5 cam caps on there
mine did a similar thing, but only lightly scuffed the bearing and didn't damage it, cleaned it up with some 1200 grit and then washed it down with white spirits and all is good
just remember to put it back together wet - ie, with camlube or molygrease otherwise it'll do the same again within a few hundred miles.
yours looks like someone has removed the cams previously and either replced them dry or there has been a bit of dirt on the cap, so when replaced and started, its worked its way round
Also, the problem could be from someone putting the camcaps on backwards - IE, numbers 1 to 5 on the inlet and 6 to 10 on the exhaust, when they are supposed to be 1-5 on the exhaust and 6-10 on the inlet, with 1 and 6 been the roller bearing caps at the front of the engine
Old 07-10-2005 | 08:25 AM
rsnissan's Avatar
rsnissan
hope your cam cap studs dont start to pull through the head as well when you get it all back together
I had to helicoil a couple of mine when i did my lifters
Old 07-10-2005 | 08:41 AM
Ratty's Avatar
Ratty
Gunna try wet & dry and do oil pressure test over the weekend, so it fingures crossed
Old 07-10-2005 | 08:44 AM
Graceland's Avatar
Graceland
Team HOTHOT!
alternatively, as a modification, you could use a lathe and add an oil groove to the cam where the bearings sit - a bit like the inlet cam.
altho, according to the cosworth techy book, "due to the design of the cam bearings and cams, and the positioning of the lubricator on the exhaust cam, an oil groove is not required"
obviously it might be required to stop the caps and cam chewing themselves senceless
Old 08-10-2005 | 02:00 PM
Ratty's Avatar
Ratty
Well I've cleaned up the head and cap, tried cam back in and its loose as hell, tried inlet cam in its place and its fine, then I put exhaust cam in inlet side and its loose as hell so I'm going to replace the cams and keep everything crossed
oilman
Trader Parts for Sale.
30-08-2015 08:37 AM
da52rkn
Ford Focus Range
21-08-2015 04:41 PM
Rickyrustyfox
13-08-2015 01:11 PM
track.focus'd
12-08-2015 05:53 PM
knight19770
04-08-2015 12:36 PM
Quick Reply: Gutted and need advice from engine builders
