injector question zetec and cvh
right im having some problems getting my car to run on cvh management
now i was told earlier to try the 2.0 zetec injectors as it sounds like its lean on start up so it fires up but cuts out
ive just manage to wedge sum cvh injectors in and it reved its nads off with fuel everywhere i know i shouldnt of done it but i had to try
i want to know what injectors people use for there zetec conversions running cvh management
and is there and equilevent injector for the zetec so its the same a s blue injectors on fiesta
any ideas
or will i have to run the cvh inlet
any ideas
CVH management will never be 'right' The fuelling & ignition tables are programmed with the 1600cc engine, and fuel etc accordingly. The ECU has no way of knowing your running a 2.0.
What inlet manifold are you running etc?
Steve
Steve
zetec inlet manifold and injectors
cvh everything else bar crank sensor
its going in on yuesday now as ive had enough so going to have all the zetec loom put in
as it will not run on cvh like i was told
just need the car to run as i carnt keep borrowing friends cars all the time
thanks
thanks
my zetec turbo recorded 191bhp on un-mapped frst ofab management yesterday so yes it can be done. you need to use frst style injectors and fuel rail to do it right. standard zetec injectors are piss poor pathetic.
What map sensor are you using? The wrong map sensor or wiring at the map sensor would cause this as well. Dont give up yet. Why did you start the project if you needed the car?
And in your above post you said "IT WILL NOT RUN ON CVH MANAGEMENT LIKE YOU WERE TOLD"
Well how come everyone else can.
What cvh ecu do you have? ofab? ofac? or are you trying to use your xr3i ecu?
The only thing this tells me is that its YOU at fault not the management and certaainly not the folk thats trying to tell you how to do it.
its a n/a zetec
so im using my standard xr3i ecu, my engine loom which i have changed to wires round because of sensors in different places
ive had a bracket made up so the throttle body will accepth the standard cvh tps
im using zetec crank sensor as the cvh is to long and got chewed up
and zetec injectors
standard xr map sensor
everything is as it was bar the crank sensor and injecters
i can get the car to fire up on the xr ecu
but it cuts out it wont tick over, this to me is its lean on start up
if i take the map sensor pipe off it will run but obviously at max fuel where its that much black smoke it burns my eye
im sorry if i sounded like im having a dig that it wont run cvh but i cannot find what i need to do
ive got to options now
either have a fuel rail made and some bungs into the zetec inlet so it will allow std cvh injectors
or get someone to wire me and zetec engine loom up
i rekon the 2nd option is the cheapest
as the throttle body to have modified just cost me 200 quid and i hate to see what a fuel rail and adptors cost
and zetec injectors
Why are standard fuel injectors piss poor pathetic? Surely you can't say that just because they do not have enough flow for turbocharged applications? Or do you say that for a better reason?
The 1.6 EEC-IV ECU without changing the tables, will not be running properly, on anything other than a 1.6cvh simple as. It may be running, but not to the best of it's ability.
You should be able to mod the loom yourself. Use a mondeo ECU. You will get a better running engine and sequential fuel injection too!
Steve
Steve
JK12
33
26-04-2021 12:09 PM
