Zetec Turbo cams and headwork
im looking to build a new zetec turbo engine but need help with the top end. im unsure who to use for the headwork, and also what spec i will need, valve sizes etc as you see them listed as stage 1, 2, 3 etc.
where to send the head to get the work carried out? and cost?
i also know very little about cams, so some advice or recommendations on that front would be cool too
do you only need to upgrade the valve springs if going for a higher revving engine?
im aiming for 350+BHP with a similar torque figure
The spec i have in mind is : lightened and balanced standard crank and flywheel
ARP bolts
steel rods
8.2:1 C/R
tubular exhaust manifold
0.63 t34
Rover M16 inlet manifold
custom intercooler (triple 2wd cossie)
ARP bolts
steel rods
8.2:1 C/R
0.63 t34
your best bet is get the head reconditioned and flowed, standard sized valves and you should see 340-350hp...rudey hit 320hp running standard head and cams with t34 but the head cracked so it was aborted...however it should now produce more power with a new head...
judging by that, im going for a flowed head and standard valves, IH cams, vernier pulleys, RS1800 inlet (for now) and undecided on turbo and hoping for similiar power figures to what your after...oh and you might wanna consider dropping the cr a little to make it a little safer
SOY, ran 366hp IIRC running big valve head and custom inlet...however his car never ran its full potential due to a few problems ive heard....could have gone 400hp+ but was running out of fuel according to Ian Howell
bassboy
bassboy
bassboy
bassboy
cheers bassboy very impressive figures for rudeys standard head, sounds like a similar spec to the zt ive just sold on ebay c/r isnt decided yet, just thats the one im considering more than the rest but im open to persuasion
gaz your prob looking at about 2000...
low comp pistons - 500
steel rods - 600
rs1800 inlet
erst exh manifold - 25?
machining work to block - 100ish
t34 - 500
complete rebuild - 250
plus mapping plus injectors and labour
but just engine aint too much...ita the rest that adds it up lol
red16...i wud say 7.8 maybe less
bassboy
steel rods - 600
rs1800 inlet
t34 - 500
bassboy
did SOY and RUDEY both run lots of boost, ie around 2bar ?
and has anybody used this guy http://www.pumaracing.co.uk/Head_Prices.htm for head work?
Baby Cheesus
im currently building a 2.0l ZT
spec:
0.5mm oversize wiseco pistons 7.8:1 CR, may see if he will do em 7.2:1 CR yet, dunno.
Steel rods
prolly get a specialised engines stage 3 head (std valves i think?)
piper or kent cams
T34 with .63 housing
primary designs tubular manifold
S8
injectors - prolly get 750cc ones
might try and ge a focus RS inlet too
aiming for 350bhp
spec:
Steel rods
piper or kent cams
S8
aiming for 350bhp
Originally Posted by * Rudey *
not tellin ya
all these monsters track days are gonna rock next year
fudgeass, nice engine you got planned, ive not seen any 7.8:1 pistons for sale are they custom jobbies? they all seem to be between 8:1 and 10.5:1
not tellin ya
