Seam welding. Is it needed?
Hi,
I'm buying parts for a 16v zetec turbo build in my 88 s2 erst. Aiming for 300bhp and similar torque, should i be thinking of seam welding the engine bay. Has anyone heard of problems when getting upto this sort of power?
Dan
Dan
but then I've sean solid cars split the front legs from the bulkhead so its really down to you mate, more to the point is you wont put 300hp down to the wheels through a shell that twists.
Cheers,
I'm no roll cage fan so theres not gonna be much stiffening going on. Strut brace and a decent suspension set up will be my lot. Still gonna have a good go at putting the power down.
Areas of suspension and stiffener mountings should be non-continuously welded for best strength and transfer of loads across a larger area. Gusseting in the joints between bulkheads and pans/floor rails is also a good thing. I do a lot of body welding/fabrication, and I usually strengthen with 1" long welds every 2" approx.
A few good pointers are in the Ford guide "How To Prepare an Escort For Rallying" (if you can find one!) That covers Mk1/2, but the areas to improve are similar, and the same theories apply.
I did my Mk2 Escort Flat-front RS1800 shell quite a long time back ... You can tell the difference when you jump a bridge, that's for sure
Well, I hope you got rid of the 'effin cradle to start with mate
I reckon you need a main trunnion to transmit the loads .. above the back of the gearbox.
Originally Posted by Freddy_mercury_magic
My Mk4 shell is being seam welded in most areas, gonna be used as a track car only
Power will be about 360bhp so i want a STIFF shell![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
The cradle that is used as a sling .. and to support the engine/gearbox mounts on the Mk4 ... I see yours is a Mk3 .. so you wont have that problem!
Al.
Al.
Al.
Al.
JoeyBoyden
04-01-2024 02:36 PM
jessie_rs
11
03-06-2019 04:57 PM
rog
04-09-2015 12:10 PM
borboyous
22-08-2015 11:17 AM
