DEFLEX BUSHES S2 TURBO any body had probs fitting them??
Ive bought a set of deflex bushes for my car , i have just started to build up the front end and found that the front anti rollbar bushes seem loose and the inserts for the outer tca bushes dont go on.
im dreading doing the rearend .....
all mine went on great
but the only probs so far ive had is the either the rear small wishbones or inner tca ones werent in the kit
so never bothered doing them
mine are like yours but once clamped there fine
also what roll bar are you using as the rst is bigger to normal escort
duno then mate as im using the std xr roll bars i think thats the 24mm with rst bushes and not a problem at all
did you cut the slits in the roll bar bushes to get them round
i never as i take the roll bars of to fit them
could be something to do with how you have put them on
All mine were shit (were fitted to a mk4 XR3i, but apart from not having a rear ARB, same fitting kit)
The front ARM ones were complete shite - completely the wrong fit and kept popping out, which caused the car to lose all direction control and lurch everywhere - not what you want at nearly a ton on the M1 is it
The rear bottom bushes were shit and flexed more than the standard rubber ones
The rear inner wishbone ones were so poxy I took em out and refitted standard ford ones
I never bothered to fit the steering rack ones and suspension top mounts after that little lot
honsilty mate i refuse to fit them
biggest pipe of none fitting shite i have ever come across
sleave wrong sizes roll bars wrong size
ya get what ya payed for i guess
poly sport or power felx evey time
marky_g
15-08-2015 10:43 AM
track.focus'd
12-08-2015 05:53 PM
