Bonnet pins...does make make a difference?
Old Jul 26, 2005 | 05:19 PM
bassboy's Avatar
bassboy
Default Bonnet pins...does make make a difference?
Hi peeps...just wondering whether the different makes of bonnet pins make a difference? are there any differences in the cheap one and the mor expensive ones?
i need some as my bonnet opened on me on the A40 last night
reason for asking as i know there are some Ripspeed ones laying around at work that i can have but dont want them to let me down etc...
thanx
bassboy
Old Jul 26, 2005 | 05:21 PM
bassboy's Avatar
bassboy
also does anyone know if there is a common problem with the catches/cables on these as i have heard numerous stories of the bonnets opening without warning...
i was only doing about 60mph as well!! glad i werent doing any more as the damage could have been alot worse!! only got away with badly bent bonnet, scuttle panel damage and a cracked left vent...
bassboy
Old Jul 26, 2005 | 05:24 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Bit of a common problem mate, happened to me a few years ago.
It's uaually due to a tired lock and melted bonnet cable not letting the lock slide fully back when you shut the bonnet
Old Jul 26, 2005 | 05:27 PM
CarlRsT's Avatar
CarlRsT
Mine did it last year coming back from usc luckly it stayed on the second catch Done it loads since but guess I'm just lucky!!!
I'm putting pin on but dunno which ones so come on ppl
Alvyn's Avatar
Alvyn
get a new lock/catch and the correct adjustment and that's all you'll need
Old Jul 26, 2005 | 05:28 PM
bassboy's Avatar
bassboy
tony, the plan is to change the cable as well...is there anything else i should change while im at it?
also any idea about the makes of bonnet pins?
bassboy
Old Jul 26, 2005 | 05:30 PM
andre_k's Avatar
andre_k
happened to me a couple of days after i bought my s2... was a prob with the catch, the cable kept catching on a kink in the cable, which held the latch open... everytime i shut the bonnet i made sure the latch on the slam panel was fully closed before i lowered it...
did the same damage, as well as a smashed windscreen
proper scares the shit out of you, trying to slow from 60 whilst lookin through a gap tighter than a nuns ass
Old Jul 26, 2005 | 05:36 PM
Tony Turbo's Avatar
Tony Turbo
bassboy
I changed the lot, catch, cable and lock, about Ł30 worth if I remember rightly. I did the same last year too as a pre caution.
Don't know about makes of pins mate, don't like them personally, I made my own catch that goes round the engine lifting eye. Not ideal, but does the job and you can't see any difference with the bonnet shut.
Old Jul 26, 2005 | 05:40 PM
Thrush's Avatar
Thrush
Irritating c........
My mates S2 bonnet use to keep popping without warning, so he fitted pins to his. Then shortly after that mine popped on the M11 - luckily both of us were lucky and we never had it fully lift, but I still didn't like it so I fitted a set of pins aswell.
I only used a cheap pair made by RACERX or something - cost about a tenner. Ally bolts, very lightweight. Took all of half hour to install and for the piece of mind it was worth it
Old Jul 26, 2005 | 05:46 PM
bassboy's Avatar
bassboy
thrush thanx for that...might invest in a pair from ripspeed as they are just layin at work
are they easily over paintable?
bassboy
Old Jul 26, 2005 | 06:03 PM
Retro Al's Avatar
Retro Al
RWD IS KING
dont think theres is much differance with bonnet pins, there are all the mostly same design prob just differant metals you cant go wrong
Old Jul 26, 2005 | 06:12 PM
bassboy's Avatar
bassboy
excellent mate exactly wat i wanted to hear
bassboy
Old Jul 26, 2005 | 06:17 PM
NUTS RuS's Avatar
NUTS RuS
We ONLY ever fit stainless steel ones.
If it were just a road car we were doing I'd go for a secondary cable located under the bonnet (as TT has done).
Old Jul 26, 2005 | 06:25 PM
Tony Turbo's Avatar
Tony Turbo
About the best I got, that I know of, anymore, go look at my thread lol
Old Jul 26, 2005 | 06:50 PM
Damo V's Avatar
Damo V
Yours is patented thoughh isnt it Tony?? any other examples which are similar have to pay you to use it dont they ?
Old Jul 26, 2005 | 06:52 PM
Stoo's Avatar
Stoo
Good idea with the cable I've been considering bonnet pin's but i just dont like the look of them.
Old Jul 26, 2005 | 06:54 PM
Tony Turbo's Avatar
Tony Turbo
It's ok Damo, I am used to being copied and getting no credit for it
Old Jul 26, 2005 | 06:59 PM
Damo V's Avatar
Damo V
Old Jul 26, 2005 | 10:17 PM
Thrush's Avatar
Thrush
Tony - your engine is looking mighty tasty there son
I saw a secondary cable set up once before a few years ago - think it was JasonP's old track liveried S2? Seems like a good idea - I just don't like the idea that the bonnet is still able to pop tho, I prefer mine to be shut dead - no way of it opening unless I undo both catches
Old Jul 26, 2005 | 10:21 PM
Tigran's Avatar
Tigran
I thought the point of bonnet pins is to remove the locking mechanisms altogether - so you can whip the bonnet off sharpish - or am I totally off the mark.
Old Jul 27, 2005 | 12:11 AM
NUTS RuS's Avatar
NUTS RuS
In motorsport Tigran, yes.
But modded cars sometimes suffer either through age, or poorly fitting/fitted intercoolers etc. As the cost of a repair is soooo expensive its a small price to pay for the added piece of mind.
Old Jul 27, 2005 | 01:28 AM
rs_daz's Avatar
rs_daz
I fitted some on mine as the bonnet poped while over taking a lorry.
I have seen some bonnet pins that sink into the bonnet which look trick
Old Jul 27, 2005 | 02:24 AM
andyhardy's Avatar
andyhardy
I'm gonna replace the cable on mine - the latch is working fine but the cable isn't engaging/disengaging properly.
It's on my to-do list
Old Jul 27, 2005 | 04:51 AM
Tony Turbo's Avatar
Tony Turbo
Thanks Thrush
Rstar_man
143
Jul 20, 2020 11:16 PM
gavt123
Sep 5, 2015 10:03 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
StephTell
Sep 2, 2015 06:31 PM
