Turbo's with cut back blades ?????
#81
Im a tad confused as to why your confused.
Pipe off = 3.5bar.
Pipe on = only a test done by idiots as an engines vac draw varies depending on hundreds of things.. cams, ports, timing.. blah blah bollox blah.....
To get around the 2.5bar mark would require you to get your YB to pull a HUGE vac at idle, which, aint happening.
Reality.. Std YB pulls around 3bar at idle with pipe on, but is subject to idle speed, cam timing . blah blah bollox blah... but as i said, pointless test.
Pipe off = 3.5bar.
#83
Originally Posted by Turbosystems
you best get a new gauge chip I suggest an accurate one lol
Ive set the fuel pressure on my current L8 chip to give me a lambda reading im happy with rather than just make an assumption as to what it was mapped with and just blindly dial in a number, so i'll refrain from doing as you tell me to in this instance as your advice sucks frankly and in this instance i happen to know better
![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
#84
Originally Posted by Stu @ M Developments
Pipe on = pointless test.
#85
If you want to know what it is with the pipe off then its pointless doing it with the pipe on and then trying to subtract the effect of the pipe really.
#86
#88
interesting way of doing it we normally map them rather that twidle the regulator
When installing someone elses chip (like alex is here) i would always recomend setting the FP based on lamda, as if his injector flow rates are a little different or his FP gauge reads differently its more like to lead to an error, where as if you go off lamda at least you know if there is a problem or not and know wether or not you can sort it with FP.
#90
The only worthwhile test is to put some pressure into it and see what it does. I always test em to 2.5Bar absolute which should show 5bar fuel pressure.
That obviously gives you your fuel pressure at 1.5bar boost.
Very good point Stu, given how much these things vary by!
#91
the fuel pressure reg has a working range min and max if you start the basic fuel pressure 1 bar higher then in effect it bottoms out 1 bar earlier
#97
Originally Posted by ImaRacing 700
Well done Tony and Stu
Showing Chip he really knows very little.
Will he ever admit this?
No Sir he will keep coming back till you all gone home ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
My original comment was (as you seem to making out ive said something i didnt so im guessing you havent even read it?)
I thought standard pressure on a cossie was 2.5 bar
Better to set it up on the wideband for the chip you have on max boost you are running though Alex, until such time as you can get it remapped.
#98
a t34 will make the boost it may not hold it on a yb at 7000 rpm but it will certainly be good for 38 +psi at lower rpm .If the reg bottoms out the pump will stall very dangerous for pump engine and wallet lol ![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
Interesting to hear thats where the regulator tops out though, cheers for the info, you learn something new everyday!
track.focus'd
12-08-2015 05:53 PM
CabrioTurbo
01-08-2015 11:04 AM
