Coil pack conversion question (stu ?)
Old Jul 23, 2005 | 10:43 PM
NICK K's Avatar
NICK K
Default Coil pack conversion question (stu ?)
Thinking about going on to coil packs. my car is a converted small turbo escort to big turbo. Correct me if im wrong i should be able to use my original coils that sit under the cam cover meaning i dont need to buy new coil pack and plug leads ? Im using a p 8 ecu and i have bin told thst they can run coil packs the ecu jest needs switching over to do it . Is that true ?
Old Jul 24, 2005 | 01:57 AM
Ginge !'s Avatar
Ginge !
just finding my feet
yeah the p8 can run coil pack already, not sure how but ya got all the toys
Old Jul 24, 2005 | 02:10 AM
Fiecos Dan's Avatar
Fiecos Dan
best speak to someone with pectel gear, may be karl norris etc etc.
my coilpack conversion still aint workin right, just waitin on simon to come down and sort it.
Old Jul 24, 2005 | 08:22 AM
NICK K's Avatar
NICK K
Ok thanks for the info
Old Jul 24, 2005 | 09:13 AM
DazC's Avatar
DazC
P8 doesn't need Pectel gear. The ECU can run it without and add ons.
On the origional coils thing, yes you can!
Old Jul 24, 2005 | 11:46 AM
NICK K's Avatar
NICK K
So what else do i need 2 ignition amps ? and ?
Old Jul 24, 2005 | 01:35 PM
Fiecos Dan's Avatar
Fiecos Dan
just a loom, for it.
Old Jul 24, 2005 | 01:39 PM
Ginge !'s Avatar
Ginge !
ask dazc as im sure i clocked a engine in a workshop that had simmiler to what ya asking
Old Jul 24, 2005 | 01:58 PM
B11GNS's Avatar
B11GNS
can you run it on a L8 ecu?
Old Jul 24, 2005 | 04:15 PM
Dave Henshall's Avatar
Dave Henshall
DazC, could you elaborate please. markk is also teasing me abuot his p8 running coilpack with no extra boards who has the software to do the mod ?
Old Jul 24, 2005 | 07:04 PM
NICK K's Avatar
NICK K
any more info anybody please
Old Jul 24, 2005 | 07:23 PM
ECU Monitor Enthusiast
The P8 ecu has the required driver electronics built in to drive coilpacks already.
The problem is there are LIMITED tuners that can "switch on" the software to enable this feature.
This is typically limited to PECTEL boards but others such as MSD (Stu) have done this on board-less versions.
However, in this latter situation, your existing chip may not be able to be modded and you will probally need a different version program.
Old Jul 24, 2005 | 07:30 PM
M K's Avatar
M K
ive just dropped my ecu off to field motorsport to sort my p8 to run dizzyless
Old Jul 24, 2005 | 07:36 PM
markk's Avatar
markk
thats not teasing m8 -
this is teasing .................................................. .........
ALS, WI, coil pack, dual map, etc etc ...................................
Old Jul 24, 2005 | 10:01 PM
Dave Henshall
ya nowt but a big tease ya
so is this p8 revision dependant or just the software that s loaded onto the chip..?
Old Jul 24, 2005 | 10:04 PM
Dave Henshall
so rather than just upload the eprom swap the required 0 to a 1 for example then re burn it , it woule be necessary to have a complete newly mapped chip..?
Old Jul 24, 2005 | 11:13 PM
markk's Avatar
markk
dont know about that im afraid im honoust at least - if i dont know - i'll say so !
Old Jul 24, 2005 | 11:17 PM
DazC's Avatar
DazC
Ok,
For the benefit of the origional topic poster, if you are running P8 then all you need is Stu and Kenny @ Motorsport Developments to sort the software out for you. If you are running an L8 then you will need the SECS driver board.
With the P8 you will need a dual or second ignition amp and a wiring harness to run the coils and amps. You will need a spare pin on the ECU to fire the second coil. The other thing required is a pulse amplifier to run your rev counter.
Old Jul 24, 2005 | 11:21 PM
markk's Avatar
markk
Old Jul 25, 2005 | 10:40 AM
Malc50's Avatar
Malc50
Hi All
I spoke to MSD last week to order a dizzyless conversion for my P8 and was told its not available yet, has this situation now changed???
Malc
Old Jul 25, 2005 | 11:11 AM
Dave Henshall
there is a problem that they are aware of and are on with sorting which affecs SOME p8's not all, with the secs driver fitted, we could so with some way of checking whether its certain serial numbers of p8s that are affected.
Old Jul 25, 2005 | 04:37 PM
markk's Avatar
markk
looks like im wrong on the availablity - but havnt had any issues on my P8
Old Jul 25, 2005 | 04:40 PM
Ryan's Avatar
Ryan
i can do a loom the same as i did for Daz C
Old Jul 25, 2005 | 06:30 PM
Dave Henshall
so, markk, are yuo using the factory rev counter or not? does the driver for this differ from say a stack one..?
Old Jul 25, 2005 | 06:57 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
P8 Dizzyless is easy with a pectel board + you will be able to monitor the engine via a pectel, powerchips, or SECS monitor
+ loads of other extras that ARE avilable without a pectel board, but is alot cheeper and easier to sort out with a pectel board
Old Jul 25, 2005 | 07:09 PM
markk's Avatar
markk
Dave Henshall,
no im usin an aftermarket
Jano_OddKidd,
i'd be interested in knowing how you get round the rev counter drive problem ??
Old Jul 25, 2005 | 07:11 PM
Dave Henshall
and whether jano use the factory rev counter,
Old Jul 26, 2005 | 08:10 AM
Versus_Creations
Ask me a question!
There are rev counters that have a coil signal spilter which transforms the signal from a coil pack to a single pulse instead of the double. They can be found in "other" cars.
You will need to mod them to work with our rev counters. (For sierra,saff etc..)
For a FWD escort, fiesta etc.. all you need is the rev counter from a car that was running coil pack from std (EFi Orion, xr3i, Etc..) so easy to sort for our cars You could use the same signal splitter as mentioned above but is cost effective to just change the rev counter for one with coil pack as the signal splitter requires you to buy the whole clock assembly from a breakers and the car they come on makes the clocks expensive.
Regards
Jano
Old Jul 26, 2005 | 08:18 AM
Jim Galbally's Avatar
Jim Galbally
out of curioscity, how is it cheaper with the pectel boards? are they given away for free nowadays?
Old Jul 26, 2005 | 08:34 AM
Versus_Creations
Ask me a question!
Jim Galbally,
You have such a great way of asking questions
Obviously they aint given away for free but can be sourced for as little as Ł40-50
Have you ever had a car mapped with dizzyless, ALS, WI, 24psi, Air injectors, etc etc etc etc .... WITHOUT PECTEL! if so how much did it cost??????
With a pectel board is alot quicker and easier. Now compare it with a map from anyone who can, without the use of pectel! The costs for mapping are way high! + with pectel you get the extras mentioned above and the ability to DATALOG, fault find, Real time adjustments, etc..
Old Jul 26, 2005 | 04:25 PM
markk's Avatar
markk
Old Jul 27, 2005 | 07:41 AM
Dave Henshall
Regards
Jano
have u got a pic of the said splitter, as i could n't easlly change the escos one over could i? or is it the actual movement in the back(which phisically would fit in an escos clock set..?)
Old Jul 27, 2005 | 08:02 AM
Versus_Creations
Ask me a question!
Why dont you just change your rev counter for one out of an EFi Mk5 escort with Coil pack?
Old Jul 27, 2005 | 10:48 AM
Dave Henshall
is it that easy, are the electronics part of the actual rev counter gubbins, not a seperate board or box in the loom?
Old Jul 27, 2005 | 10:54 AM
Jim Galbally
and you have an appauling way of answering them
Old Jul 27, 2005 | 06:31 PM
Dave Henshall
jano:
do you require the surpressor putting back in circuit at the coil before the signal goes to the tacho or not, doe sthe efi mk5 escort rev counter accecp teh back emf from the coil directly and soft it out internally?
Old Jul 27, 2005 | 06:42 PM
Versus_Creations
Ask me a question!
Dave Henshall,
Just change the rev counter, its easy to do once you take the clocks apart
Old Jul 27, 2005 | 06:56 PM
Chris Honeywell's Avatar
Chris Honeywell
Dave Henshall,
I think the problem is that esc cossie clocks aint back lit they glow
no other mk5-6 are lit this way
Old Jul 27, 2005 | 06:58 PM
Ryan's Avatar
Ryan
just what i was thinking.
Old Jul 27, 2005 | 07:13 PM
Dave Henshall
but that is just the face is it not,,, ive had the clocks out to reface the EL bit, is it the actual mechanical bit that needs changing or is there an input board or similar sitting nest to it and the actual movement of the tacho is the same..?
Prickly_buzz
Dec 7, 2017 09:52 PM
liamT74
Sep 23, 2015 10:24 PM
pabloXR
Sep 21, 2015 12:42 PM
beller
Sep 21, 2015 04:13 AM
KennyWelsh
Ford Focus (All Models)
Sep 13, 2015 08:28 PM
