Any tips/tricks????
Evening.......
Anyone have any useful tips or tricks for getting the actuator rod back on the wastegate lever as its not happening for me!! Maybe im just not strong enough to pull it over the lever
but its just not happening. im only about 10mm short of getting it on to the lever (No jokes).
Ta Daz
Ta Daz
DEYTUKURJERBS
You big girl
No, seriously, with a strong actuator its pretty hard.
What i do is use molegrips to hold the actuator arm and push on that, and if i cant do it maself, jus get somone else to help you push the fucker on, and on some, even then its not easy, but always do-able.
Only fucker is when you REALLY close and you acidently knock the wastegate arm so its too far away to put the actuator arm on and you have to start all over
yep if set right you should only have to put the actuator under 4mm of preload and if you want to use more boost get a bleed valve to adjust the actuator pressure
just finding my feet
Originally Posted by DazC
Use compressed air to expand the actuator.....
but dont fit a bleed valve for that reason look at ya amal valve jets
as a rule of thumb ya should have half a hole ( around there)
but get a pump and pump u[ the actuator and ya sorted
was gunna say the same get a bike pump and cut off the end that normally screws onto the bike valve then feed the pipe into your actator hose and use a bit of tape to seal it, get a friend to pump pressure into the actuator which will move the actuator rod back and forth then all you have to do is slip it on
( watch your fingers tho...cos it hurts so bad) lol
Graceland
22-04-2012 11:33 PM
ScORTED
10-07-2007 03:50 PM
Stu.H
13-03-2006 06:22 PM
