S2 RS Turbo 4x4 Cosworth Conversion - Fuel Computer Issues
Old 27-05-2020 | 11:57 AM
MikeJamieson's Avatar
MikeJamieson
Default S2 RS Turbo 4x4 Cosworth Conversion - Fuel Computer Issues
Hi Guys,
Just wondering if anyone is able to offer any information or assistance.
I am just completing the finishing touches to a 4x4 Cosworth conversion that I started 15+ years ago. I have fitted the RS Turbo fuel computer to the dash but would like some advice on calibrating it with the correct sensors... As it is currently reading a fuel consumption of 3 MPG, I expected the Cossie to be juicy but I feel this is a little out...
Does anyone have any experience with making one of these computers work on a Cossie set up?
I have the standard fuel sender inside the tank, the speed sensor fitted to the gearbox side of the cable drive and have fitted a fuel flow sensor to the main inlet to the rail. Its the final sensor I feel the problem me exist at. Would this normally be fitted inline to one of the MFI injectors on a RST? Possibly making mine read 4 times the amount of fuel use?
If so, does anybody know of the electronic values expected this sensor is supposed to give, I wonder if I'm able to place some kind or resistor within the wiring to achieve 1 quarter the current given value?
It would be nice to know what others have done or how you might have overcome this problem. I guess I'm also going to get the measurement for the flow going back to the tank with my current configuration?
Any advice is greatly appreciated.
Cheers,
Mike J.
Old 13-07-2020 | 05:33 PM
iansoutham's Avatar
iansoutham
OCD Victim
Have you go both earth connections attached at the back of the fuel computer.
I cannot remember if you have both connected for MFI and 1 for EFI or the other way round.
Also, it may not be compatible with the Cosworth engine management sensors?
Old 16-07-2020 | 03:10 PM
MikeJamieson
Thank for your reply, I will have to check on the earth situation, I had an original RST loom and plugged that in to use. So I would have though how it was meant to be set up when standard. Am I right in thinking that using the second earth makes the computer measure fuel flow from just the sender and speed sensors? Ignoring the fuel flow sensor?
The Cosworth engine management is not linked to the little loom at all, only the in-line fuel flow sensor, speed sensor, fuel sender (in the tank) and the main power are connected to it. Although I have seen some threads where they have used an output from an ECU to measure the fuel flow through the injectors.. I too am not sure if that would work.
Would be nice if I could get it working or at least reading more than 3 MPG
Cheers for your help!
Old 17-07-2020 | 07:38 PM
foxy06's Avatar
foxy06
Need some more pics of this beauty
Old 17-07-2020 | 08:26 PM
MikeJamieson
boost monster (17-07-2020)
Old 17-07-2020 | 10:34 PM
gcfcos's Avatar
gcfcos
Wow that car is awesome! Cracking work there
The following 2 users liked this post by gcfcos:
dan le moignan (23-07-2020), MikeJamieson (17-07-2020)
Old 18-07-2020 | 07:51 PM
christos's Avatar
christos
Stunning engine bay and car!!!! Good work!!!!
MikeJamieson (18-07-2020)
Old 18-07-2020 | 07:58 PM
scoooby slayer's Avatar
scoooby slayer
What an absolutely stunning escort yb power and 4wd 👌👌👍👍
Old 19-07-2020 | 07:28 AM
I love mk3 mk4 escorts like this.
MikeJamieson (23-07-2020)
Old 20-07-2020 | 11:28 PM
Lee read's Avatar
Lee read
Rs turbo
Lovely car mate. Did you use sierra floor?
Old 23-07-2020 | 02:16 PM
MikeJamieson
This one is a Sierra floor pan... although this was the first shell of 2 that I have converted. I built the second (shell only) to help fund this one... The second was completely fabricated and looked like it had been driven out the forecourt like it. If I was going to build another, I'd definitely fabricate the conversion instead of using a floor pan!
Old 24-07-2020 | 03:41 PM
RUBY123's Avatar
RUBY123
whats the heater box made from looks good
Old 24-07-2020 | 08:01 PM
Lee read's Avatar
Lee read
Rs turbo
how would you go about fabricating the conversation. I think you one look stunning and from what I can see from the factory
Old 27-07-2020 | 12:24 PM
MikeJamieson
I fabricated the heater box from Aluminium then had it powder coated black. I made it when the engine was out and was sat in the engine bay with the bonnet closed fitting all the pieces together...TIG'd it up then polished all the welds off before having it painted.
Old 27-07-2020 | 12:32 PM
MikeJamieson
Thank you! Yeah its pretty good, theres just things I would change if I did it again. Don't get me wrong, its lovely and I paid attention to all the little details, but when I fabricated the whole thing there wasn't any visible welds, I done it to look factory. Obviously chopping a Sierra floor pan up and pasting it in, requires a lot of tinkering, bit here and a bit there, patches and buggering about. The second one I built just looked like it had been made that way by Ford. I guess it's just my opinion...
Old 30-07-2020 | 08:40 AM
Cookson's Avatar
Cookson
Oh my I can't help with your computer issues, but that is stunning
MikeJamieson (30-07-2020)
Old 06-08-2020 | 09:42 PM
foxy06's Avatar
foxy06
Other than the bonnet, that is perfect, usually the wheels dont sit right in the arches with these conversions but this does look factory RS Turbo running gear, spot on
MikeJamieson (19-08-2020)
luxembourgrst
11-07-2011 06:09 PM
cdc
17-08-2006 04:19 PM
Hardeep_Singh
15-12-2004 06:14 PM
16-04-2004 12:53 PM
Quick Reply: S2 RS Turbo 4x4 Cosworth Conversion - Fuel Computer Issues
