Dump Valve removal!
Dump Valve removal!
Right, im quite sick of the noise of the dump valve however, when i asked Stu a whileback to remove the dumpvalve, he confirmed that the standard dump valve had been removed so advised not to take it off.
Is there a 'silent' dump valve i could buy? As i quite like the sound of loud as fcuk chatter!!
Originally Posted by Itsmeagain
If you want loud chatter than just blank off where the dumper goes, simple.
A silent dumpvalve will partially or totally remove chatter
Post Miester !
No i it wont damage the turbo, unless you are running a high boost T34 or a T4.
I believe the reason they were originally fitted was for Homolagation reasons and
to rid the noise of the chatter............
Al.........
Al.........
I don't use 1,got sick of it,and the "chatter" sounds much nicer IMO. Apparently it's got fook all to do with the wastegate tho,it's the air getting chopped up or something clever.
Originally Posted by TIFF-C20WTH
I have No d/v or recirculating valve on mine and it chatters its nuts off
When I removed my dump valve it killed the turbo !!!
It was a 450 bhp roller bearing turbo and it bent the shaft.
It happened between gear changes on low boost.
Completely my fault for listening to bad advice
Chasing Radders
DEYTUKURJERBS
Originally Posted by Stu @ M Developments
Remove it if you wish, but get ready for stalling at every junction and overfuelling problems galore
Ignore this lot who havent a clue what they are talking about*
Nope, you NEED a dumpvalve then, bloody stoopid AFMs...
DEYTUKURJERBS
Originally Posted by plynchy
Mmm but does a turbo have some sort of protection/dump valve on it as standard?
eh? wastegates to control boost, which is owt to do with the function of a DV.
Anyone know if the standard re-circ on the Focus can be removed?! I've got a cone filter + you can hear it pretty loudly, wonder if I could get chatter?! If so where's the best place to get blanking plugs?? Central day?!
Cheers Lewis but don't worry about it. Want to get conformation/some elses experience if it's safe/possible on the FRS first, then I'm sure they're only a few quid from Rainbird!
hi all, i normally dont even look at posts reguardin dump valves, as im sick of all the peeps talking crap iv had one of stus dv on for years and never had any probs or damage the simple fact is if it dident have one fitted a standard its up to you weather u fit one or not..simple or if you have erst fit one of stus electronic box,s ..and dont fit anodised
i talked to the guys at castle about it and he said d/v were first thought of by ford, and said when collin mcrae was rallyin thay were devised so he cud change gear faster.. thus gettin rid of the back pressure and bein able to change gear faster so people should look into why thay were first invented!!! instead of slaging them off, if you dont like them take it off, or if it was made with it on you should leave it on and not vent to atmosphere whitch is what ford did
i have a switch on my erst and can turn it off or on , and i think it deff goes thru the gears better with it ON!!!
andzz
andzz
Fudgey
17-09-2015 01:06 PM
Si B
12-09-2015 06:49 AM
