Cosworth hub
Hi,
Having trouble getting the hub back onto the driveshaft. It is not a sliding fit and I have to use the hub nut to push it home, this wouldn't be an issue but my concern is I have to use a bit of force to do this.
A hub puller is also required to remove it and speaking to a friend he said his slid off.
I replaced the wheel bearing and it was like this prior to replacement.
I have cleaned the splines on both the stub axle and driveshaft to no avail, there is no corrosion.
The bearing I replaced circa 6 months ago, collapsed last week and the wheel seized.
As such there is an underlying reason and don't want to put it back together without knowing the root cause.
It now seems it is even tighter since this time.
Any help would be appreciated please.
Martin
Martin
Thanks for the replies, I may assemble it and see how I get on.
Yes, it is the rear nearside.
This time I took the hub to a mechanic to press the bearings in and he said it should slide on and I shouldn't have to wind it on with the nut.
A friend has a 3 door and he says his slides on and off.
Having had the previous bearing fail in a short space of time, it's not something I want to occur again and want to eliminate anything untoward.
Martin
Martin
I had mine pressed in.
The first time I done mine by hand with a heavy duty screwdriver and a club hammer
So this time got them pressed, defiantly better and takes all of five minutes.
I suspect the hut nut may have not been tightened enough, having one of these fail though at high speed is not an experience I want to go through again.
Martin
Martin
I suspect you damaged the races when you first installed them using a hammer which is easily done, can you remember what torque you tightened the nuts too the first time? Iirc it’s like 260nm
Have not got a torque wrench and if I did I dont believe there are that many that handle the kind of torque required in this case.
Martin
I have taken a photo and would post but its not like the old times with photobucket.
I chalked it up to the tolerances being minute that some fit and some dont.
Its not a job I done before and so have nothing to compare it with.
Martin
I personally wouldn’t risk doing it without knowing how tight you are going, when torqued up the wheel should have some resistance when you try to rotate it in the air
https://rover.ebay.com/rover/0/0/0?m...2F273862027760
works out not too bad and can be used on your breaker bar
Resident Wrestling Legend
I used a 500lb/ft torque wrench to do mine up ![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
But yes, they should be tight coming on/off because the bearings are tight on the hub shaft
They normally fall apart when you pull the hub off so you need to replace them
If they are sliding on/off then either the bearings aren't right or you have other issues
The whole point of them sitting right is that there's no movement in the hub
Martin
Martin
Adam-M (18-09-2019)
to undo them i had my dad, all 17 stone of him back in the day, standing on the beam while i was hanging from the bar ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
i had it upto 300 lb/ft before it started to turn
and i weighed around 170 lbs then so i'm sure someone will do the maths on that![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
but they are supposed to go right up to from 310 to 350 nm so that's fucking tight as fuck!!!!!
martysmartie (23-09-2019)
According to my manual it’s 250-290nm so I did mine to 270
Previously, I believe it was too loose as I could loosen it with a 2 FT breaker bar with the car in the air.
Kind regards,
Martin
Now I'm worried
Kind regards,
Martin
You quoted yours in lbft Martin where as I quoted mine in NM. I’ve got the Ford Cosworth workshop manual
Received 1,044 Likes
The last part on mine I had to use the nut, I have cleaned the splines with a needle file and there is no corrosion.
Martin
Martin
09-11-2007 09:00 PM
