Supra diff ratios
Old Jan 16, 2019 | 08:26 PM
stevecfrst1's Avatar
stevecfrst1
Default Supra diff ratios
Im looking into doing the supra diff conversion on my sapphire and considering diff ratio options, from what it seems theres a choice of 3.7 or 3.9, im thinking it may be a good idea to go for the 3.9 to liven the acceleration up a little and loose a bit of top end that i will never use. Anyone tried a 3.9 out? Thanks
Old Jan 16, 2019 | 08:29 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
Yes, I went 3.9 on advice. Mark Shead said the Cossie is massively overgeared and the 3.9 brings it to life, I have 16 inch wheels and now I have close ratio oppliger 4x4 box and with 469bhp and 500ftlb acceleration was vivid to say the least in my little 205 shell, it tops out at 160mph now.
Old Jan 16, 2019 | 11:34 PM
Mad_Mat's Avatar
Mad_Mat
New Owner
I have all the bits together and plan on fitting in March. Gone for the Supra 3.9 with mk fitting kit and MT rear billet cover. Look forward to testing it. I will try mine without the weir LSD upgrade first to see how it is.
Old Jan 17, 2019 | 12:27 PM
turbotrev's Avatar
turbotrev
You can get a lot more ratios than that dude, I had a 4:3 in my saff.
Check out the Weir website for all the different ratios
Cheers Paul
Old Jan 17, 2019 | 02:34 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
If you are looking to buy a 3.9 they were standard fit in the non turbo supra. When I bought mine it did need some seals and bearings so the cost of refurb depends on condition. I too had weir kit fitted.
Old Jan 18, 2019 | 05:27 PM
COLEYST200's Avatar
COLEYST200
I use a 3.9 Supra diff in my focus witch was running around 400bhp 4x4 . and my mate is 2wd with just under 500bhp we both run 18 inch wheels and in the courner and as we get up to about 120 he can not live we my focus running the 3.9 diff . I will try and link the video up.
If you copy and past this into gooGoo the video will play . My mate comes up behind me at a bout 2.30 min in
https://youtu.be/ER7rIFSXxgY
Old Jan 24, 2019 | 06:01 PM
stevecfrst1
Thanks for all the reply’s, will go for a 3.9 I think. With regards to fitting do you literally just need to buy a diff and an mk fitting kit and it’s literally a case of bolting it in? Or anything else needed? Whats the deal with the billet rear covers?
Old Jan 24, 2019 | 06:36 PM
turbotrev's Avatar
turbotrev
If you drive it n any kind or anger you will break the standard rear cover as it’s hung from the cover on the fitting kit.
A billet cover is a must otherwise your looking at modifying the beam to mount the diff another way.
Cheers Paul
Old Jan 24, 2019 | 06:39 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
You do need the billet cover as people have broken the standard ones as they weren’t designed to carry the diff on the cover. . MT and MK make covers. Either use the MK fitting kit or have your rear hoop modified to take the diff without the fitting kit. I used both and loved the simplicity of the modded beam to take the diff and you can 6 degree it at the same time for a big handling and traction improvement. If not use the fitting kit and it is plug and play.
Old Jan 24, 2019 | 06:45 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
Hoop modded to take the Supra diff without fitting kit (you still need prop and drive shaft adapters though.
6 degree beam
WRC cradle modded for supra diff, you need the boot floor modded and ideally a cage to locate these.
Billet cover on just fitting kit. I think you can get these covers without the square edges now and the MT ones look ace with cooling fins.
Old Jan 24, 2019 | 06:51 PM
stevecfrst1
Oh right I didn’t realise the standard covers break, thats a bit of a bugger as it makes the job a lot more expensive
Old Jan 24, 2019 | 07:12 PM
turbotrev's Avatar
turbotrev
A billet cover is gonna be around Ł300
Cheers Paul
Old Jan 24, 2019 | 07:52 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
‘if you don’t chuck mega power at it then it MAY be ok but as Paul says, it’s just another 300 to protect it.
Old Jan 24, 2019 | 07:59 PM
smiley's Avatar
smiley
You still need the flange and prop adaptors that come with the fitting kit if doing the hoop mod
Old Jan 24, 2019 | 08:53 PM
COLEYST200's Avatar
COLEYST200
The big problem you will have is getting your hands on a fitting kit in the first place
Old Jan 24, 2019 | 09:08 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
Mark borrowed a part of my old one to copy as someone had his dummy so I assume he made some more kits, I could be wrong though. My old kit is supposed to be going to AuS if Tony ever sends his courier to collect.
Old Jan 25, 2019 | 05:41 AM
smiley's Avatar
smiley
I have the kit less the adaptors if it's any good to anyone
Old Jan 25, 2019 | 10:41 AM
stevecfrst1
Oh right im sure i read the covers were over Ł500. Mk aparantley have the kits on the shelf ready to go, but im aware that he’s not an especially reliable person so in not sure hiw truthful that is
Old Jan 25, 2019 | 08:25 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
how close are you to him? Collect and pay. You can alsways get a pic of it ready to go and pay then.
Old Jan 27, 2019 | 12:49 AM
Mad_Mat's Avatar
Mad_Mat
New Owner
try MT for the covers. A much nicer design and a great chap to deal with and i,m sure you will be pleasantly surprised by the price.
Old Jan 27, 2019 | 07:04 AM
Caddyshack's Avatar
Caddyshack
10 Year Member
yes, I really like the MT cover.
Old Jan 27, 2019 | 09:22 AM
COLEYST200's Avatar
COLEYST200
This is my MT cover on my focus . it's got a cooler set up on this one but he did them with out the AN- fittings drilled in the covers
Old Jan 27, 2019 | 10:08 AM
smiley's Avatar
smiley
Got one of his recent run had holes for cooler rapid delivery great to deal with
ginner
20
Oct 12, 2012 09:46 PM
bigal1978
Feb 19, 2006 03:54 PM
Stavros
16
Aug 3, 2005 01:16 PM
Sean Bicknell
Aug 29, 2004 06:55 PM
CosRush
Jan 18, 2004 12:04 PM
