HELP - S2 Rough Running at 2k
Just been out in the motor and there seems to be a developing problem with it....and I've got to drive it 200 miles tommorrow from Heathrow to Goole so the last thing I want is it to break down!!
Since I had it tuned at Well Lane when coming off the throttle then back onto it slightly its very jerky
But now under constant cruising throttle at 2k the cars jerking back and forth all over the place!! If you rev it at standstill to 2k you can here its not running correctly Almost like its on 3?
Also if I boot it...then back off...then onto throttle again I get a pop out of the exhaust which doesn't usually happen
Only thing I've done differently with it this week is short journeys <2 miles every day which I don't usually do.
ANYONE ANY IDEAS?????????????//
Faulty TPS will cause popping on ovverun etc - get a ohm meter and make sure its working OK (important this is OK as as well as coasting fuel cut it also brings in the wide open throttle enrichment so you could run lean on boost if its had it).
Also could be your dizzy, mine did that once, jerking about etc when the dizzy hall effect sensor was dieing - whats your rev counter doing when its jerking?
Rev counter is bouncing up and down a little (up and down 400rpm)...how do I go about checking the sensors??
The TPS is the sensor on the throttle isn't it...I'll have a nose about
TPM961
15-01-2018 10:50 AM
