Quicker Spool
Old Jul 24, 2016 | 02:50 PM
caprizetec170's Avatar
caprizetec170
Angry Quicker Spool
Just Looking for help from more knowledgeable people on here,
Just got my zetec turbo capri back from mapping,
And its shit it makes 315bhp but at 6900 and 14psi and's gutless low down
spec is st170 engine JE pistons arrow rods, 9;1 compression(suspect may be less) custom inlet (homemade)
homemade tubular exhaust manifold
Garrett GT2871R with a TiAL vband .63 housing
would fitting smaller turbine housing or shorter exhaust manifold shift spool and power lower down the Rev range,
Or any other suggestions would be great
Old Jul 24, 2016 | 03:05 PM
gjh's Avatar
gjh
Who mapped it? I would of thought with that sort of spec it would be a good responsive motor.
Old Jul 24, 2016 | 03:11 PM
Adam-M's Avatar
Adam-M
How much torque did it make and at what rpm?
Old Jul 24, 2016 | 04:42 PM
Bart's Avatar
Bart
With that spec it should spool very good. You have a dyno plot? What boost control and ecu youre using?
Old Jul 24, 2016 | 04:51 PM
costina's Avatar
costina
Live long and prosper!!
Sounds like it was mapped by m tech.
Old Jul 24, 2016 | 06:04 PM
caprizetec170
local Rolling road mapped it( there not exactly common in south of ireland) and in fairness he mostly builds rally engines on throttle bodies.
Its running on omex 600 and an aeg tru boost boost controller
Torque levels out at 241 about 5400 till redline
I can get a .52A/R turbine housing would that spool up quicker/earlier ???
Sorry dislexic me turbine housing is a TiAL 8652 so i presume thats a .86 A/R ?
Old Jul 24, 2016 | 06:36 PM
Bart's Avatar
Bart
Should spool up just fine with the tial, something is not right. I did a standard cosworth engine with gt2871 and this spooled very good.
Old Jul 24, 2016 | 06:39 PM
Bart's Avatar
Bart
Can you send me the ecu file so i can have a look?
Old Jul 24, 2016 | 06:52 PM
Jay,'s Avatar
Jay,
Sponsor
Fuckin lol
What fuel are you on .
Old Jul 24, 2016 | 07:16 PM
costina's Avatar
costina
Originally Posted by Jay,
Fuckin lol
U like big man
Old Jul 24, 2016 | 08:45 PM
Jay,'s Avatar
Jay,
Sponsor
M tech have trouble tuning preset a radio lol
Old Jul 24, 2016 | 10:02 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
Pics of inlet and exhaust manifold?
Old Jul 25, 2016 | 08:52 AM
jontysafe's Avatar
jontysafe
I wouldn`t mind betting it`s the set up on the boost controller
Old Jul 25, 2016 | 09:31 AM
Adam-M's Avatar
Adam-M
Or the homemade inlet
Old Jul 25, 2016 | 11:25 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
thats why i asked for pics lol
Old Jul 25, 2016 | 11:32 AM
stevieturbo's Avatar
stevieturbo
C**t
Some detail might help.
When does it start to spool, what boost, any graphs or logs etc etc ? What are you using for boost control, how is this configured ? What is tuning like during spool etc ?
Surely the tuner had some input ?
Old Jul 25, 2016 | 05:28 PM
costina's Avatar
costina
Input. Yeah he turned up that day.....
Old Jul 25, 2016 | 06:09 PM
Rick's Avatar
Rick
ST170 - what are you doing to control the cam timing?
Rick
Old Jul 25, 2016 | 09:25 PM
caprizetec170
Rick
i just deleted the VVC and fitted variable pullies,
Old Jul 25, 2016 | 09:35 PM
caprizetec170
OK there some manifold pics, rough calculation inlet is about 3.6 litres, exhaust manifold is hard see but its basically just simple equal length 4 branch about 12 inches,
And boost controller is an AEM thru boost set at 16psi on a 38mm external gate which dosen't even make that much psi.
Also turbine housing is .86 not .63
Old Jul 25, 2016 | 09:43 PM
Adam-M's Avatar
Adam-M
Looks a neat conversion
Old Jul 25, 2016 | 09:55 PM
stevieturbo
C**t
So VVC cams but fixed pulleys ?
I'd say that really wouldnt be helping much, but again more info needed.
Old Jul 25, 2016 | 09:59 PM
stevieturbo
C**t
The tru boost is a very basic open loop controller...as such you dont set it at a particular boost. Just a fixed duty cycle after testing to achieve any desired boost level.
How much duty is it taking to make 16psi ?
What spring is fitted to the gate ?
Is the gate sealing correctly when closed ?
Exactly how is the gate plumbed ?
All of these things can affect spool ( as indeed can camshafts ! ) as well as tuning etc etc
Old Jul 25, 2016 | 10:14 PM
caprizetec170
to be honset i just set up and plumbed it to instructions that came with it and fitted a 16psi spring, yes it seats correctly but the turbo has never seen more than 14psi
Old Jul 25, 2016 | 10:21 PM
gcfcos's Avatar
gcfcos
Lovely looking engine bay!
Old Jul 25, 2016 | 10:22 PM
stevieturbo
C**t
Really it needs someone experienced to look at it and make sure everything is ok.
Although I guess that was largely the point of taking it to a tuner ? So what did they say about it ?
And if the boost control is plumbed exactly as AEM list in their instructions, there should be no difficulty making 16psi or more with very low controller duty.
Unless there is a major cam/tuning/turbo/tuning issue somewhere
Unless there are huge leaks, the intake and exhaust manifold certainly wont be the problem.
The larger turbine housing would be worth changing to a smaller one though as it should be relatively cheap.
Old Jul 25, 2016 | 11:15 PM
caprizetec170
Well i can get a smaller turbine housing in either .52 or .62 not exactly cheap at close to £400 but if it solve problem not too bad
like i said above local rolling road guy that mapped it dosen't normally do turbo stuff and just reckoned turbo was too big,
thanks for help though
Old Jul 26, 2016 | 01:09 PM
gcfcos's Avatar
gcfcos
There a guy my mate uses called devil developments he seems real good with turbo zetecs and cossies etc. Not sure how far away from u he would be though
Old Jul 26, 2016 | 02:51 PM
Rick's Avatar
Rick
ST170 cams are not suited to turbo use unless you have full closed loop VCT working. What is the inlet cam timing set to if it is static?
Rick
QplateRST!
Apr 19, 2017 11:38 PM
Will Pedley Racing
Ford Focus RS Parts for Sale.
Mar 12, 2016 05:00 PM
Mike Rainbird
Trader Parts for Sale.
52
May 17, 2004 07:48 AM
richm
Dec 8, 2003 06:40 PM
