Fuel pump voltage on a cossie
IIRC i was told that the fuel pump had to have at least 11.something other volts at tick over..
Is this correct? what voltage should it be?
also, is this the recommended way of changing it?
https://passionford.com/forum/viewto...hlight=voltage
and in a perfect world, i guess the wiring should be changed..
Yes, but 30amp fuse will be ok, runing 25Amp wires.
Don't forget to do the earth also, from battery to pump, and body to pump.
Cars i have done run about 13.5-14.2 to the fuel pump using standard 4x4 alternators.
If its running 11V get it checked mate, rang the place that set mine up yesterday to check what the voltage was actually reading just to find out, and it was 11v and dropping to about 9v when you rev the car which is fookin dangerous!!!!!!!! car was leaning out in a big way.
Think the only thing that saved me from a blown engine was prob the NGK 9s cos ive been driving it a bit hard
So gonna be re-wiring the car tomorrow
you should get virtually same voltage at pump as at battery should be something like 13.8 volts if not two ways of improving it are run a 20 mm cable from back of alternator to positive side of battery as well as standard ford cables also a bigger earth from battery to body and if fuel pump v oltage still not the same run a 6mm cable from battery into spare tyre well and use existing fuel pump wiring to trigger new 40 amp relay and power pump through relay using new 6 mm cable aspower supply .
Thanks, strange thing is that i get 13.8 at the Pectel Monitor (V+ from ABS connector). Cant understand why fuel pump only see 12.6 when its on fresh wiring direct to the battery.
Rod-Tarry
237
18-03-2016 09:13 PM
kosienutter
31
22-08-2015 09:55 AM
CabrioTurbo
01-08-2015 11:04 AM
