Hubcentric wheel spacers
I'd get them from eBay mate, I'd go for the ones that are actually drilled 4x108 rather than the big slotted multi fit ones as it's easier to get them on centre.
cossie fan (unluckerly)
I can't find find any on eBay that are the proper hubcentric ones with the lip to support the wheel. I've email loads of sellers and they say they don't do them
5mm one won't be enough to clear the original hub lip enough to make a a new hub lip.
I bough these, best thing I could find
https://www.ebay.co.uk/ulk/itm/321687401899
I just bought some 7mm multi fit ones, looked at them and there's no way I'm fitting them to a 150mph car lol. They sell longer sleeved wheel nuts but not liking the idea of no lip for the wheels to sit on
That's why I'm after hubcentric ones as they have the location ring. I need a spacer to clear my ap's. I got my ap's second hand and there's something funny about them. So have to use the spacer or my rondels catch.
Mad_Mat (27-03-2016)
2wdsaph ben (26-03-2016)
Of course it's possible to make I'll get the disc bell hole made larger and a spacer done that sits over the hub that fits through the middle of the disc the wheel side will have the lip that the wheel sits on
So how is this wider hub you have made to go over the existing hub then going to fit into the hole in the wheel? or are you machining out the hole is the wheels as well, hell of a faff
The reason hubcentric spacers only exist in 15mm plus is that the first 10mm of the hub hole in the spacer is larger than the existing hub and only once the metal of the spacer is past the original hub can it taper back down to the original hub size.
I have had centrelock adapters made to my spec in the past for a sierra, I know what I am talking about, people are trying to help you here, it cannot be done if you plan to keep the original sierra centre bore diameter of your wheels, simple as.
The only way your idea will work is if you had the centre bore of your wheels machined out to take the wider centre of the new hub that you had fabricated.
Very crud drawing but I'll have something like this made if the disc hole that go's over the hub lip is made bigger the spacer can slit in the middle of the disc. My disc bells and the 5mm spacer that's on there now cover the hole hub lip so there's lip to support the wheel
![](http://i737.photobucket.com/albums/xx20/ajamesc8392/image_zpshs12plms.jpeg)
The sierra hub is I believe something like 62mm from memory, as is the hole in your wheel to allow it to slide in
Your idea adds a few mm either side of the hub as a min taking it up to 65 mm plus, a 65mm hub will not go into a 62mm hole how ever hard you push!
As I say my discs are funny the bell almost covers the hole hub lip the drawing is very crud it's obvious the lip that sits inside the wheel will have to be the same size as the wheel. As there's very little original hub lip there this should not be an issue. If I can't buy something that will work give it till end of summer ish and I'll post a picture of what's been made
From reading what Paul's saying I agree it will be abit more involved that what your picturing mate. Your saying your 5mm spacer will have its own lip for the wheel to sit on but will be bigger in diameter so you'll have to machine your disc but as its bigger in dia it will also be too big for your wheels.
What part of the disc is fouling your wheels? Can't it be ground and repainted?
The only option would to machine the existing protruding hub face back until it is flush with the face of the disc then have a spacer made with an integral hub the same as the standard hole width, and bored out to clear the big nut holding it all on, but then the spacer itself would not be hubcentric as its relying only on the 4 bolts to hold it in place.
Hammer to crack a nut as well.
If it could be done, they would be on the market, the reason they are not is because it cannot be done.
The centrelock wheel adapters out there for Fords are seriously flawed in their design due to the same problem, it is scary how much little alloy is left on the adapter when the centre is bored out to clear the hub when you look at them in profile, my design resolved the problem but it involved machining back the hubs.
20mm will stick out a little to far lol I'm not changing the brakes they have been on the car for 2 years now I'll sort the problem no worries
Ian e34 m5 (02-04-2016)
Can't you get the wheels machined for clearance ? Or is that a no no
I had a similar problem when I ran a set of tarox brakes in the end I sold them went for APs still had th issue so a mate made me some new bells and caliper mount I went round the houses big time wish I'd bought a new set of wheels tbh
If your on radial mount calipers you might be able to redrill the brackets.
I agree on the other comments, you cannot have hub centered without the material in the first place.
I make all my own bells and caliper brackets btw.
Here is the problem, inner bell face needs machining back, bells are too thick.
Its been like it for about 3 years lol and seen plenty of off the clock action without issue. But to me it's not really safe and is an issue its always been on my to do list. As I'm pretty much re doing most of the car at the moment I'm going to sort it. I work on commercials and see lots of snapped wheel studs. The weight of the vehicle shouldn't really be on the wheel studs there should be a location ring
If the wheels need a spigot ring then they are not Ford fitment, which is in your favour for an easier solution along the lines you were thinking of.
Whatever way you try, if you had ford spec centrebores on your wheels then hubcentric spacer of less than 15mm cannot be done.
The fact you have now clarified your wheels don't means you have some excess width on your existing hub to play with.
All you need to do is sleeve with steel tube your existing hub to the same diameter as the larger than Ford spec hole in your wheels.
Simply also have the ford hub holes in the bell and existing spacers machined out to the same diameter so the sleeve can slide through them as well, they will also hold it in place
The sleeve would need to be 8mm longer than the distance from the hub back face to the existing end, in order to give you 10mm of a centralising bore, Job done.
Far cheaper than the route you have come up with via MK and no need for spigot rings either then.
All the centralising bore does is correctly line up the wheel in order for the bolts to be secured correctly, once they are torqued up its then done its job, the wheel does not rely on it for strength.
Gary @ RS CLASSICS
05-04-2016 07:12 AM
Gary @ RS CLASSICS
25-03-2016 08:33 AM
