Did someone find a new age starter to fit the cossy 4x4 ?
Received 1,044 Likes
A tranny connect one will fit but i think you have to drill one of the holes in the startrer motor. On a tranny connecy starter 3 bolt screw into the starter but i think on the cossie 4x4 box one or more of the bolts screw into the bell housing.
iirc we had a play wiith one of these to fit to a 4x4 and it fouled the oil filter so we rotated the solenoid clockwise to miss but then the solenoid covered the centre mounting hole so we passed a 8mm bolt through from the gearbox end and fitted a nylock nut and washer . does seem to turn engine over with more torque but a little slower.
we now have one fitted to a 4x4 with a wrc winged sump and breather system with no problems
David
David
With regards to people saying thats it won't fit the 4x4 cossie
whats the actual difference between a 2wd and 4x4 starter, i always thought it was just the length, and size of body, the holes are all the same? i hope im not wrong, i have a connect starter motor on my saff 2wd and my escort turbo, and im 95% sure there is also one on my escort cos.
The escort cossie only uses 2 bolts but that is because the big wing sump is in the way for one of them
kosienutter
31
22-08-2015 09:55 AM
jack-rs500
05-08-2015 07:07 PM
