Yb no spark Help!!
Yb no spark Help!!
I've just tried starting my car for the first time after building it, and ive got no spark.
Engine and Ecu has been run on dyno but since then a MSD wasted spark kit has been fitted, loom was from a running car so assume that's good.
Pumps prime when ing switched on and run during cranking so that side of things seams good.
Not sure where to start looking or what for, checked the power to the coil pack and only have 12v at one of the terminals the centre one I think.
Where else should I be checking for voltage.
I have changed the plug leads for a set from matt lewis and they where difficult to get in to the coil pack I do have the original MSD leads so might swap these out tomorrow.
Any help will be much appreciated.
jamie
jamie
Ok will start with checking that, anything else you would think of looking at.
Thanks for the help.
Sponsor
MMM If the phase is wired incorrectly that could cause the issue or jusr not working
off the top of my head i cant remember the wiring but look at www.bigturbo.co.uk
I will double check it tomorrow I have a old original loom and used that to pin out the plug, Big turbo diagram just shows what pins in the ecu plug thing are connected to not the plug end.
The most likely problem is WS.
You have the correct supply, but it's almost certain the ECU is not switching the ground, so I would start by verifying your installation...
Martin
Right checked the phase wiring and that's correct pins 5 and 23, plug end as per original old loom.
Checked the voltage at the cps and phase and only have 0.5v with ing on.
jamie
Well I have a custom engine loom for WS so that's just plug in apart from changing over from cam position to phase and had to add Amel valve connection, and I had an electronics engineer fit the driver board ive opened up the ecu and checked the connections to the ecu pins (listed above) but need a copy of instructions to check the connections on the underside of the board.
Ive put the meter around a few plugs to see what I have,
CPS 0.5v
phase 0.53v
TPS 4.97v&4.99v
ISCV 0.47v & 0.16v
Coil 12v on centre pin
Ing amps 12v & 4.5v same on both plugs.
Fuel pumps prime and amel valve clicks when ing turned on.
Un sure of what two wires you are referring too the engine loom was made for WS or am I missing something.
Update finally got a set of instructions and turns out one of the wires on the board side of the ecu was on the wrong pin no;12 instead of 13.
Changed it over and now have a spark but still wont start, I have a spark on all 4 plugs during cranking but only 2-3 when ing turned on. Not sure if this is right or not.
Ive swapped everything round and tried another coil and its the same.
Now seams like im getting no fuel have fuel at the rail, but plugs stay dry dose a little cough every time you turn ing off then try to start not sure if the injectors fire when ing is turned on and that's what doing the little cough.
The annoying ginger guy
I know, but this was for the first problem, with no ignition, it will not effect that, that is how I knew it would be down to the WS installation.
He has multiple issues, in actual fact a phase sensor will only stop a 2WD managed car from running, the way I understand it. The later ECU's can perform a calculation to substitute a value in it's absence.
Martin
Martin
DixieTheKid
11
06-06-2020 11:20 AM
deathrider666
28-09-2015 06:12 PM
wheelwizardrefurbs
18-09-2015 08:59 PM
