-16 and -12 hose fittings, how to bolt to floor pan?
Lucifer II - 666
Any one seen or use any fittings when running big JIC hoses throughout your car?
Not seen any giant P clips or nicely CNC'd fitting. looked all over the place now.
Kev.
Kev.
Lucifer II - 666
Alloy clamps would be great, I bought the hoses from them on eBay and lots of other bits, not seen the clamps on there shop though.
Will look again bud.
Lucifer II - 666
Lucifer II - 666
Never heard of um mate, they good?
Not talking rape here Gaz
Think it maybe a bit more than 30mm tbh, will measure it.
All round band. Pretty flexible and versatile for larger diameter stuff. Still needs a hole drilled in the chassis to fix though
http://www.discount-electrical.co.uk...nd-fixing-band
Or if you were really intent on alloy brackets, it really wouldnt be that hard to get whatever shape you need waterjetted out of a block of aluminium
Yes mate and bonkers cheap too, but really well made stuff, it's mean to be trade only but if you knock on the door with cash they don't turn you away, it basically a huge warehouse with a tiny little office that you have to be buzzed into.
I bought 40 various sized really nice stainless steel hoses clamps for Ł20, they do allsorts and Mikalor stuff too.
http://www.zeroclips.com/content/Contact_us.html
Rich
Rich
Here's some from ebay. I've bought braided hose from them which seems good quality. Cheaper than torques ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
http://www.ebay.co.uk/itm/AN-12-AN12...item565a599f82
http://www.ebay.co.uk/itm/12-AN12-24...item5658c61b1c
http://www.ebay.co.uk/itm/AN-12-AN12...item3f286063d3
Not quite sure how that place is listing those P-Clips for -12 hose, which typically as a 19mm ID. Yet they say their clips for -12 can take a hose diameter of maximum OD 19mm ?
So OD would be closer to 22-23mm
Pretty sure Torques do -12 alloy brackets for though ?
Strangely they dont list 12, but sure a friend got some earlier in the year. Wouldnt be hard to sleeve down a 14 or 16 though
http://stores.ebay.co.uk/Torques-U-K...=p4634.c0.m322
Lucifer II - 666
They wont hold down -16 bud, main oil feed and return pipes to dry sump.
I have emailed Torques about -16's but yeah may get some made up.
Thanks bud, will save that link for future reference.
Thanks, but their OD seems wrong.
They do mate yeah, they're really good, emailed them about -16, so probably be after Christmas when I get a reply now though.
Thanks for the help lads
Looks different...
Looks different...
Rich
Rich
They do work fine on any hose as I have used them in the past on dry sump setups inc on my own car. Personally I think p clips are just an expensive way round doing the same job but are less easy to remove if required unless you use a riv nut for every fixing.
Lucifer II - 666
Alex @ Torques_uk has great customer service!
They made me -16 P-clips and list them in their shop now...
http://www.ebay.co.uk/itm/380843298043
What you using -16 on Kev?
Lucifer II - 666
borboyous
22-08-2015 11:17 AM
Jack and the Beanstalk
15-08-2015 04:27 PM
Gadget
Ford Escort RS Cosworth
14-08-2015 07:19 AM
Gadget
13-08-2015 08:19 PM
track.focus'd
12-08-2015 05:53 PM
