sierra conversion to to 2.3 16v engine.
hello all,
could anyone tell me if a 2.3 16v engine will fit into a sierra mk1 and how much modification is needed. i want to run it as a daily. i have complete 2.0 dohc with all running gear set ups (manual) here and wondered if the 2.3 would bolt up. i know the 2.0 16v will do the job.
any help advice or advice would be appreciated.
Ben
Anything will fit in anything with enough work.
By 2.3 I assume you mean the one from the Galaxy?
it is from a galaxy. what else will i need off it to convert. if the head fits on the 2.0 8v engine surely easier conversion. thanks for all info.
Resident Wrestling Legend
you just need to make sure you've got a flywheel that will fit with the manal conversion as the clutch is way way different, i've got one int he garage somewhere i might be able to take a picte of
so basically i can use the head on the 2.0 engines i already have. job done. just rewire and should be ok. am i right about that. i have 2 x 16v heads and 2 x 2.0 engines with dohc 8v heads.
the heads will swap over no issues
but the compression ratios will be all over the place
with the 2.0 8v head on the 2.3 bottom end the compression ratio will be too high
and the 2.3 16v head on the 2.0 bottom end you may have issues with the bore being bigger and the seal not working properly in the head gasket fire ring
Vces (21-08-2020)
your forgetting 1 major thing, the galaxy 2.3 heads thermostat housing will be in the way! you need a 2.3 scorpio head as theres no thermostat housing at the back of the head
galaxy head has both side and rear waterways, rs cams, 8v sump and pickup, youll need 2 block of a part on the block when removing the balencer chain, rs flywheel and clutch is a bolt on fit aswell,
just done me own 2.3 on a twinchoke carbbie
Vces (22-08-2020)
