transit t280 bleeding fuel system
Old Nov 28, 2013 | 10:20 AM
fezzielove's Avatar
fezzielove
Default transit t280 bleeding fuel system
Did a clutch slave on a transit last week vans come back now after the lad has run it out of fuel, now iv bleed these before and know there a nightmare but this fucker just wont go, iv cracked of high pressure to pump and van fuel thru till clean of air iv pumped the plunger ontop of the filter 100's of times then cracked the injectors and its only giving me a trickle of fuel theres no pressure atall, have tryed toeing the van with not joy, what should I try next :s
Old Nov 28, 2013 | 05:41 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
Check filter as it may have sucked a bit of shit through, also try jacking the back of the van up so any air with travel back to the tank
Old Nov 28, 2013 | 06:05 PM
GVK.'s Avatar
GVK.
That yellow plunger isn't a primer, you can press that all day it does nothing.
It's a 'filter minder' shows how blocked the filter is.
Need a hand primer on the outlet of the filter to the pipe to the pump.
One of these with pipes made up to suit the filter/pipe http://www.ebay.co.uk/itm/8-MM-FUEL-...item1e7f3d4a5a
Don't crack off the pipes on a TDCI it will just introduce air.
Old Nov 28, 2013 | 06:22 PM
jameswrx's Avatar
jameswrx
Take the fuel filter off and fill it with diesel.
I've had people run them out of diesel and all I've done is taken the filter off, refilled it and started it.
Old Nov 28, 2013 | 06:52 PM
botters's Avatar
botters
competant bodger
i cant say ive ever had trouble starting these just filled filter and use my vac pump to pull fuel through the pump feed, reconnected pipes and fired straight up
Old Nov 28, 2013 | 07:26 PM
jamie's's Avatar
jamie's
its also quite common for it to ruin the pumps if it gets turned over a lot while its out of diesel
the diesel lubricates the pump so if its run dry then it ruins a seal inside and cant pull fuel thru
if it does this then it usualy means the pump is scrap,
i run a workshop for a hire drive company and unfortunately we have peple run them out of fuel all the time
usualy just fill the filter and crack an injector on a tddi and it'll fire up
tdci is fill the filter and turn it over
but definately fill the filter to the brim and try that
Old Nov 28, 2013 | 09:50 PM
GVK.'s Avatar
GVK.
We have a right problem T350 2.4 TDCI ex Police thing at work.
Timing chain jumped, new head and all the gubbins.
Broke down again, no comp on cyl 4, some muppet decided to have it bored/sleeved and a new piston (not me I must add)
Engine was rebuilt.
Wouldn't start, despite having good fuel pressure on datalogger. No codes etc.
All PCM feeds/grounds tested, new CKP.
Usual shagged injectors with excess leak back, these were reconned by Delphi specialist.
Still didn't start.
Found no CMP signal (by scoping) even though it had no DTCs (usually P0340)
New CMP sensor.
Still didn't start.
Had pump reconned by Delphi specialist, started but cuts out on hard accel, IMV duty cycle low, but IMV signal goes crazy then fuel shuts off.
Starter fucked up on road test.
Burn it? Yes that has been suggested
IMV replaced (wasn't done on pump recon), ran on slave fuel supply.
Still cuts out.
Pump is back with the Delphi place, they say it's faulty..again...
Never known one van to have so many problems!
Old Nov 28, 2013 | 10:56 PM
gingerturbo
Sounds about right for a t350
Old Nov 29, 2013 | 07:34 AM
Sounds like fun Gary. The trannys we have at work have been really good. We have changed a few fuel pressure switches and a few egr valves and thats about it. Had a few bolts snap on the gearbox selector and the chuck the bolts out of the gear box casing.
Old Nov 29, 2013 | 07:56 AM
fezzielove's Avatar
fezzielove
Are you sure the pumps for tge filter minder?? As when I pump it pressurises the fuel line I have been using this pl7nger and the bleed nipple to draw the air out the system using a hose under some diesel I cracked of the high pressure to the pump until until diesel ran clear of air but occasionly I am still getting air thru the system.and the injectors are refusing to pressurise!!! Had to recover a 2009 hightop last night put a can of diesel in her and she started first turn why ford fitted a plunger instead of a bulb we will never know
Old Nov 29, 2013 | 05:17 PM
GVK.'s Avatar
GVK.
If you're pressing this - This isn't a primer, it's the filter minder (sees how blocked it is)
Old Nov 29, 2013 | 05:22 PM
jamie's's Avatar
jamie's
some tddi's have a pump on top of the filter housing,
i'm thinking this is what he has, if so then yes that is a primer but they're crap
Old Nov 29, 2013 | 05:36 PM
GVK.'s Avatar
GVK.
Hasn't stated exactly what it is, we could guess all day
Old Nov 29, 2013 | 06:18 PM
fezzielove's Avatar
fezzielove
i said the plunger ontop of the fuel pump housing i didn't think that could be misunderstood for the minder this is the type the van has transit t280 bleeding fuel system-1ltczyd.jpg
i suppose i should of made it clearer as there is quite a variety on these derv transits
Old Nov 29, 2013 | 06:20 PM
GVK.'s Avatar
GVK.
Sorry about that!
Anyway, have you got it going?
Old Nov 29, 2013 | 08:03 PM
botters's Avatar
botters
competant bodger
run it on rod bender till it picks up on its own lol (yes i have done this on older stuff ha ha)
Old Nov 29, 2013 | 08:04 PM
GVK.'s Avatar
GVK.
*Cough* and newer stuff..
LOL @ 'rod bender'
Yeh, always a worry when it locks up...
Old Nov 29, 2013 | 08:10 PM
botters's Avatar
botters
competant bodger
ha ha yes i use it on anything lol! if it is an exspensive car i use wd40 as that will at least attempt to lubricate the turbo as it goes through lol
Old Nov 29, 2013 | 08:13 PM
botters's Avatar
botters
competant bodger
LOL @ 'rod bender'
not as worrying as when you spray a little too much and it revs its fucking cock off and i dont mean that bit of revving accompanied by diesel knock i mean that horrific scream with the horrendous deep growl that a diesel makes while you wince and hope the last person on the van didnt overfill the sump with oil lol
Old Nov 29, 2013 | 08:18 PM
GVK.'s Avatar
GVK.
pmsl - GREAT MINDS lol..
I was working at a Ford main dealer in Worcester a few years ago, one of the lads fitted a new engine in a Transit Luton van, unfortunately he forgot/didn't bother (whatever) to empty the old intercooler of oil.
I was squirting the 'rod bender' into the intake hose as he sat in it cranking it over, luckily he was sat in it, as once it fired, it picked up the old oil from the intercooler and revved FLAT OUT
Me -
Him -
He put it in 5th gear and dropped the clutch, the back wheels did a bit of a burn out and when it stalled the turbo made a proper CHA-CHA-CHA-CHA-CHA that an old WRC car would have been proud of.
Bearing in mind it was a brand new engine, he was lucky it didn't fuck it!
Old Nov 29, 2013 | 09:12 PM
botters's Avatar
botters
competant bodger
Me -
Him -
niiiiccceee lol
i was doing an mot on a passat that had just (moments before!) had a turbo fit and they neither told me nor cleaned out the intercooler, i proceeded to do the smoke test. now bear in mind this was last mot of the day so all windows, doors, cracks and crevices were closed down for the day. i gave it a good old rev as per the manual and sure enough it picked up on the oil in the cooler and revved like a good un, it was in that moment with the sheer amount of unburnt skeg and years of pussyfooting soot build up in the exhaust that i finally realised what it was like to be a human DPF!
Old Nov 29, 2013 | 09:28 PM
GVK.'s Avatar
GVK.
Fook! Worst bit of that is you turn it off, it's still revving flat out.
You take the keys out, it's still revving flat out
Old Nov 29, 2013 | 10:19 PM
botters's Avatar
botters
competant bodger
.......and then you slam the bonnet and panic followed by much running away and arm flapping!
Old Nov 29, 2013 | 10:27 PM
GVK.'s Avatar
GVK.
Or try and stall it and burn the clutch out...
Old Nov 30, 2013 | 11:37 AM
fezzielove's Avatar
fezzielove
Hahaha rod bender im going to give the van back sick of seeing it been in 3 times this month as much as I like taking the lads money I cant be fucked with it I only do this on the side and have to spend my evenings working late in the workshop I would rather be at home with the mrs I "think"
Old Nov 30, 2013 | 11:41 AM
fezzielove's Avatar
fezzielove
And you cant beat a run away diesel, I rember on night at my pals was about 3 in the morning we had just put a new engine in his fiesta and forgot to refit the daft gromnit on the air assist for the brakes also to make it worse the loom had ignition bypassed at the relays to get it running car also had no exhaust system it started up first turn and we couldnt get it to switch off so we paniced switched the fuel pump off switched the garage lights of and went inside and watched all the neighbours lights turning on and people coming out to see what the fuck was going on haha
Old Nov 30, 2013 | 11:44 AM
gingerturbo
Is it throwing up the coil light or EML at all as it may be the high pressure sensor
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
155lee
Oct 27, 2015 04:55 AM
kevin36
Sep 8, 2015 12:23 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
ST-170
Sep 4, 2015 11:02 AM
