mayo on the oil cap?
ok, the fiesta gets regular looking after by your truly because the mrs can't be trusted to put anything into it, even petrol ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
so at least once a week it get all it's fluids checked over and topped up where necessary
this week i've topped the oil up and there was a smattering of light mayo on the inside of the filler cap which has got me worried
on the other hand, most of the journeys are approx a mile and 5 minutes worth of use so it gets more regular oil changes than normal and i've heard that they don't like to run low on oil so i keep it topped up and this is the first time i've seen this mayo
the water level is fine, no need to top it up other than once in the summer
so does it just need a longer run or what?
Could be a leaking head gasket,condensation,if your not losing water and the oil is fine might just be condensation if your not running it long enough or short trips.
