Zetec turbo Vs duratec engine
Okay, here's one for them turbo nuts.
I've been looking into zetec turbo engines and the cost involved. Now would it make sense doing the Zetec turbo using the 2.0 zetec or going for the st170 engine which is duratec. Of course the focus Rs engine Isn't cheap to buy.
Your thoughts
Your thoughts
Bodger of Blackburn
the st170 isn't a duratec, neither is the rs engine, they are all blacktop zetecs with minor differences in terms of head/rod+piston combo's.
depends on power and budget.
to get 300bhp, st170 bottom end with standard blacktop head with valve springs swapped out.
then it's focus rs engine.
then onto a standard blacktop with rods/pistons/cams/valve springs changed.
best route to go is to fit a frs tall block, people have seen 390bhp from the standard bottom end and no zt oil pump problems
then st170 bottom end with frs 1.8mm headgasket and black top head, with uprated valve springs, good for around 300bhp
silvertop with block bored to 86mm and fitted with c20let pistons and rods modded to suit, and uprated valve springs with frs gaskets and arp rod bolts good for 270bhp, its worth thinking about at this point that its only an extra Ł250 for steel rods and they come with arp bolts so will then piss 300bhp
1/4 mile beasty!!!!
My engine cost
Ł700 for pistons and rods
Ł150 for silver top engine
Ł300 for machine work and bearings
Ł550 for ported head
Ł140 cat cams valve springs
Ł180 area six exhaust cam
Ł50 Gaskets and bolts
Total Ł2070 for a 500hp capable engine
Really could do with an external oil pump or dry sump to hit 500hp
The lack of Focus RS oil pump failures is interesting, particularly as they use the same block, crank and I think oil pump as a normal Black Top.
Focus RS do use larger gudgeon pins though and there was a theory floating about that it was somehow related through harmonics or something, as a majority of failures in Zetec turbos seemed to have occurred in engines using the smaller sized gudgeon pins.
Who knows! Black Tops seem happy enough at 450bhp and for some reason Silver Tops seem to be ticking time bombs at that power though. Anything below 400bhp I wouldn't be at all concerned about oil pump failures.
i think it tends to be the home pro engines that idiots put together
if your zetec is bolted up right and treated to a full engine balance and the oil pump checked and cleaned then there shouldnt be a problem, but i wouldnt want to build an engine and be unsure if it will hold together.
i keep thinking i might get a problem but im only going for 250ish bhp, but im looking to build up another engine instead of modding what i have.
my next spec i hope to have is
frs tall block
inlet cam change
tubular manifold
custom inlet
gt28
frs tall block
inlet cam change
tubular manifold
custom inlet
gt28
![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
In all seriousness, Black Tops seem to last longer. I had a mate who made 440bhp on a standard Black Top and gave it death for many miles and that was fine.
See this thread when Devil Developements decided to kill a 500bhp engine in the name of research!
https://passionford.com/forum/genera...mp-failed.html
Lucas was a big spec, big budget build too, but they were the early days of Zetec turbo tuning. I know of a Silver Top Zetec turbo that was doing over 500bhp on standard pump and given a caining every single day as a daily driver and that was fine - but think he was a lucky one.
I am new to this concept could you help me out to resolve the problems on how to sort the cranks? Is there any special technique which will keep me away from buying a new costly pump.
Yeah but they come at a huge price difference for the privilege. In the long term it might be worth it but it all depends what your targets are.
In terms of why the oil pumps fail i reckon its down to crank speed rather than harmonics. They don't appear to fail on highly tuned N/A set up reving to god knows what rpm, just turbo's running big numbers seem to be the main victims.
If someones running 'sensible (ish) power and the oil pressure is properly monitored it need not be a ticking time bomb
You can buy frs tall blocks once in a while for Ł1100/1200 so not that badly priced when pistons rods and gaskets and timing belt kit would cost that for a black top
Then you need, block modded for oil returns, breather ect, Ł250 worth of valve springs or shimmed frs ones, so not that much more
