cvh turbo cossie management
can somebody explain to me how this is done and whats need to convert a erst to to efi using cossie management
cheers mark
cheers mark
you would need a cosworth engine loom, ecu, crank and phase sensor set ups, the throttle body and idle valve other sensors need incorporating, either with a modded or custom inlet manifold.
You basically adapt/fit the cosworths management system to the erst engine/bay
cheers for reply,what do you do about fueling injectors chip.does the crank sensor mount straight on to sump and phase sensor is straight swap in dizzy of erst?.take it still need cross over pipe from frst?. do you have any photos of modded inlet with cossie throttle body?
cheers mark
cheers mark
No problem, I will help if I can, personally I would use a more modern standalone engine management system, having had cossie management and now running megasquirt, I wish I had used aftermarket in the first place.
post whore
I have a field Motorsport crank and phase sensor set up in my garage.sure theres other stuff like igntion amp etc.also got a cosworth loom,l6 ecu and brand new pectal board that cost £185 from Collins alone.its at Janos just now but he's meant to be sending it all back to me as I've sold my car.
Matt Baxter
16-09-2015 08:30 PM
CrOwSoN15
18
22-08-2015 10:24 PM
Cameron
14
09-08-2015 06:28 AM
