Bleeding Brakes
On my S2. Recently just put rear discs on the car and at the minute I have not dropped it back down on the rear wheels. I need to bleed the whole system as I had all the rear compensators out and stuff so will be lots of lovely air in the system.
Firstly, do I want the car on all for wheels to do this, im assuming? secondly, which order do I need to do each caliper please
Thirdly....wish me luck
dont lower the rear end on its wheels or bleeding is a bastard to get at and can cause mistakes. Put axel stands or blocks or ramps under the swinging arm and lower the car onto those....in affect it will be like on its rear wheels but they wont be in the way
Yup! last job for the back end hopefully!
Chuffed 2 bits! that it could be running again this weekend for the first time since last august!
Hope the weather stays mild for the weekend
Hi again all,
Maybe a silly question but, do I need the ignition on when doing this
Also, the resovoir was tottally empty I noticed since removing all the brake lines for the underside, I have filled it up and pumped the pedal a few times but have nothing, will it need a lot of pumps to get the fluid back round?
p.s resouvoiuris not empty again still just under max
Heeeelp!
Heeeelp!
Cheers Micky,
Thought so re: ignition. I must have pumped them a good 50 by now I reckon, nada, had the bleed nipples out and checked them nothing with them tottally left out ffs!
Ive been under the car to check the lines no leaks anywhere, pedal feels stiff though like the fluid is not getting round maybe? i mean not stiff like normal but certainly not "free flowing" ? although the level in the fluid resovouir has gone down a small amount
Are they still plumbed diagonally ? If so do the final bleed 1 circuit at a time.
Be very careful when the master cylinder is empty, if you push too sharp/hard on the pedal it will flip over the seal in the cylinder and then give you even more problems.
Tony, they are plumed in as standard. I cant make sense of it, master cyl is just under max bit down from where I fulled it to max. did the bleed nipple back up and thought id try the other side rear, same, fuck all, remove the bleed nipple tottally dry as a fcukin bone
What do you suggest?
I knew this was gunna be a fcuking problem
Open rear right and front left, and slowly pump the pedal. If the seal has already flipped in the master cylinder you will have to unbolt it from the servo and unclip the circlip on the back to get at the inside. Correct the problem re-build and continue a bit more carefully.
Ive put the car away now, got fooked off. peice of crap car
I'll try the above tomorow I guess
Cheers mate
you have the same problem as James
https://passionford.com/forum/viewtopic.php?t=109404
Except that u wont notice ur pedal going to the floor as that only happens with the car running
OMFG! we have fluid to all areas now! WOOOOO HOOOOOOO!
I did what Tony said to release the one rear and one front, then got the back flowing nicely, same with the otherside, nothing until I released the front one and then it was there at the back....when the car is running at some point (tomorrow?)
I'll see how the pedal is, if its shite, i'll just bleed them again now I have fluid there
Oh and Paul, did it on the ground mate with the calipers still fixed in place, just front end jacked up with wheels off.
Lee, I have a one man bleed kit, one way vlave thing i think (bot pressue one that uses tyre pressure) but this works cool when i eventually got fluid! lol doing my head in for ages
Tony, u certainly are it seems!
Fooking over the moon when I saw fluid!!!!
I changed oil / filter / plugs / water / coolant today.
Got the battery conected back up, the fuel pump even primes (nastily
) all thats left to do is.........turn the key!
and BOOOOM!
Roll on tomorrow
and BOOOOM!
Roll on tomorrow
LOL! well done that man! lol I bet the pedal will feel shit still, will see when I take it out tomorrow hopefully, then just try bleed em up again properly this time. unless I end up in a ditch cos the arse end locks up now I have discs on the rear
hmmm no HARD braking adam!
Yep next (final) bleed will be one at a time (working diagonally) starting furthest away, and please take it steady until your sure about everything
Just bled them again (in that order) all seemed fine, pedal is still crap and goes to the floor now car is running
Heeeeeelllp
Anyone got any ideas on what I can try next, they seem to bleed up ok but still have far too much pedal travel
Is it worth me d/c the rear calipers and suppoprting them higher? will this have any effect? considering they seem to bleed ok? I wanna try a couple more things before I take it to the local garage.
P.S is that order above correct ?
If the pedal is still travelling then there is possibly still air in the system.
Suspending them higher may help. How did you bleed them ? Pump the pedal a few times before opening up the bleed nipple on one of the down strokes. Then lock it off let the pedal come up on its own, and repeat.
How did you bleed them ? Pump the pedal a few times before opening up the bleed nipple on one of the down strokes. Then lock it off and repeat.
It doesn't help the fact i'm doing it on my own so in that case impossible Can u tell me exactly what I should be doing
