Cheap engine management options...
Old Mar 24, 2013 | 04:46 PM
perry3188's Avatar
perry3188
Default Cheap engine management options...
I have come across a few different names of programmable ECU kits and I'm wondering what all of your experiences are?
The type I'd want are the ones that will do 4cyl, electronic ignition (crank sensor), and obviously injection.
Old Mar 24, 2013 | 08:00 PM
Karlos G's Avatar
Karlos G
Balls Deep!
The very best bang for buck at the bottom end of the price scale is an MS2/3 ECU from www.boostmonkeys.co.uk
Old Mar 24, 2013 | 08:58 PM
perry3188's Avatar
perry3188
Had a look at that website. Is it not just mega squirt then? Is mega squirt any good?
Old Mar 24, 2013 | 09:15 PM
stevieturbo's Avatar
stevieturbo
C**t
That depends....how good do you need it to be ?
You're requirements were as basic as any would ever be, and it will easily do that task.
Old Mar 24, 2013 | 09:23 PM
robrs2's Avatar
robrs2
Had and MS2 they are ok but sometimes need to be altered for use on fords, unless you buy it setup.
I have now spent the extra on an Emerald K6, Well worth the extra
Old Mar 24, 2013 | 09:30 PM
perry3188's Avatar
perry3188
I'm thinking of building a zetec turbo. Can I map in anti lag with mega squirt? Or emerald for that matter?
Old Mar 24, 2013 | 10:06 PM
slammedorion's Avatar
slammedorion
I'm on Adaptronics on my zetec turbo...
Run it on my impreza type r too, was a far better job than the Gems ecu it run when I bought it...
Old Mar 25, 2013 | 05:17 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yes it's Mega Squirt mate, but built by pick and place robots and then conformal coated rather than hand soldered by a hobbyist in a shed! lol
MS3 for example will do everything any of the more expensive alternatives can do.
It's more about how well a car is mapped these days rather than what's the 'best' management, as I always say choose your tuner and go with what they recommend as they will be the ones using it.
Old Mar 25, 2013 | 06:11 PM
perry3188's Avatar
perry3188
Thanks very much for the info. Do you know if anti lag is mappable with one of these then? I assume it is as basically it just over fuels and retards on the overrun (am I right? Ish?)
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
knight19770
Aug 4, 2015 12:36 PM
vdubo7
Aug 2, 2015 08:17 PM
Old ford
Jul 31, 2015 06:50 AM
