Zetec turbo HG failure advice
After having ongoing pressure problems in the cooling system, we thought we would pop the head off this is what we found,
Now why? Head lift, det damage, too hot, or just dodgy gasket?
We did run just over 2 bar on a t38 407hp, genuine st170 gasket.
What's your thoughts guys?
![](http://i1228.photobucket.com/albums/ee444/nevsrevs/photo-145.jpg)
Now we are thinking that we lifted the head, it's been pressure tested and skimmed today, so we will try again with some arp studs this time.
gasket looks like it just got hot mate but that could of happend after it let go. did you use gen ford head bolts ? and did you torque them down to silvertop settings or blacktop ?
Yea gen 4 layer gasket, pattern bolts though, but was told that would not make much difference? We seem water temps of 105C on the dyno is that enough to harm it?
What ever did it, it happened whilst mapping, and only was a niggle when on track that it use to push water out the header cap, at least it's not a cracked head!
know how you feel. ive just done a m12 conversion on mine but only because its in bits lol.never had a problem the way it was but planning on running more power through it next year
Think we will give the arp,s a shot and keep our fingers crossed, never going to be pushing the boundarys on the power front just want a reliable motor! At least the manifold good now!
