Supra diff conversion
Old Oct 25, 2012 | 07:26 PM
  #81
MK MOTORSPORT's Avatar
MK MOTORSPORT
Originally Posted by joffy
if we can get 10 takers or near that
i will do full kit £480
adapters £180
Dont wanna sound thick () what do you get extra in the kit other than the adapters? The diff?
sorry if this is a obvious question
hi
you get mounting to put diff in beam and 2 drive shaft adapters and one prop shaft adapter
mark
Old Oct 25, 2012 | 07:29 PM
  #82
Sonic Boom's Avatar
Sonic Boom
Originally Posted by MK MOTORSPORT
hi
mark
So you won't need any cutting and shutting of the prop shaft it'll be a bolt on adaptor?
cheers Rich
Old Oct 25, 2012 | 07:30 PM
  #83
joffy's Avatar
joffy
SLOW LEARNER
Aaah ok, so its the mounting for the standard beam, still sounds like a good mod
Old Oct 25, 2012 | 07:37 PM
  #84
Fezman1's Avatar
Fezman1
Heres and example of the kit
As they have been producing it in america for awhile now
Old Oct 25, 2012 | 07:40 PM
  #85
COCHYN's Avatar
COCHYN
Awesome example to work form eh Mark
But that kit's for the Mekur right?
Old Oct 25, 2012 | 07:44 PM
  #86
Cosnada's Avatar
Cosnada
Started another thread to put names on for parts. Save clogging this thread and pissing off the op.
Get your names down them mark will pm us - thread is in general car related discussion.
https://passionford.com/forum/showthread.php?goto=newpost&t=439915
Old Oct 25, 2012 | 08:13 PM
  #87
SapphyMike's Avatar
SapphyMike
https://passionford.com/forum/showth...wpost&t=439915
Not pissing me off at all . I anything that means I can get the parts I need at a stonkingly good price is fine by me! Lol
Old Oct 25, 2012 | 08:59 PM
  #88
peteh's Avatar
peteh
ok looks like I'm the only one without a diff, lol
so I'm looking for a turbo mk2 or 3 diff yeah, not a non turbo one....?
Old Oct 25, 2012 | 09:01 PM
  #89
MK MOTORSPORT
hi al
i wouldnt want to work from that lol
i hope my welding and fab is better than that lol
mark
Old Oct 25, 2012 | 09:15 PM
  #90
COCHYN's Avatar
COCHYN
Didn't want to say anything But that diff mount would need strengthening anyway, mine would rip it apart
Old Oct 25, 2012 | 09:18 PM
  #91
scoooby slayer's Avatar
scoooby slayer
£480 for full kit is a bargain imo, specially when the diffs are so cheap and so strong.
the whole job done for less than the price of a quaife or gripper and then replacement diffs are available for feck all, win win imo
Old Oct 25, 2012 | 09:21 PM
  #92
COCHYN's Avatar
COCHYN
As above, and they actually last unlike uprated Cossie diffs
Old Oct 25, 2012 | 09:23 PM
  #93
peteh's Avatar
peteh
????????? Just a yes or no would be helpful!!!
Old Oct 25, 2012 | 09:31 PM
  #94
COCHYN's Avatar
COCHYN
MK3 Supra 3.0 Turbo Manual (1988-90) with 3.73.1 ratio.
That's the most common to find.
Old Oct 25, 2012 | 09:33 PM
  #95
Cosnada's Avatar
Cosnada
Lol,
a mk3 turbo is the one you want
Old Oct 25, 2012 | 09:37 PM
  #96
peteh's Avatar
peteh
Hehe cheers lads, ill keep my eyes open, if I miss one a quick pm would be great!!
Old Oct 25, 2012 | 09:53 PM
  #97
Cosnada's Avatar
Cosnada
As previously mentioned thay are going for £100 max but post / courier is a fair whack due to being over 40KG's.
I personally think that as the cars are less and less available and us Cossie boys are on the want they will become hens teeth.
Get one whilst the going is good before the big rush and this leading to Supra diffs & conversions being comparable to an ATB / Barra / Gripper. That said, they are not gonna break like the afore mentioned.
HTH.
Old Oct 26, 2012 | 12:24 PM
  #98
SapphyMike's Avatar
SapphyMike
Daft question, but will this fit into a 4wd beam with 4wd drive shafts?
Old Oct 26, 2012 | 12:49 PM
  #99
dojj's Avatar
dojj
Resident Wrestling Legend
if you fit the 100 flanges yes
you'd just need a 1/2 inch spacer in one of the top diff mounts to take up the gap which is there on the 7 inch diff
Old Oct 26, 2012 | 01:14 PM
  #100
XRT_si's Avatar
XRT_si
Bargain! If I still had my Saff it's defiantly the way I'd go after breaking four standard diffs
By the way Mark - did you ever get anywhere on resplining the shafts I sent you for my 8.8 inch axle?
Simon
Old Oct 26, 2012 | 01:41 PM
  #101
philt's Avatar
philt
Default Supra diffs
Are the diffs the same in the Mk 3 Supra Turbo auto & manual? Same ratio and both have LSD? Are these diffs plate or viscous LSD?
Cheers.
Old Oct 26, 2012 | 02:03 PM
  #102
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Originally Posted by Moonstone Steve.
Not sure mate, I was just putting the question out there but personally I would like the OE mount utilised.
Didnt someone have problems with the mounts ripping out???
Steve
my mate did but he drives like a total cunt lol
Old Oct 26, 2012 | 03:58 PM
  #103
COCHYN's Avatar
COCHYN
Doesn't look like very thick metal was used in that mount, so not surprised on the result. When I made my roll cage box sections, I braced it with 6mm thick metal Nothings gonna break that fooker!
Old Oct 29, 2012 | 07:41 PM
  #104
BRAMMER's Avatar
BRAMMER
On to the next thing
Ive been trying to find out which is the best oil to put in these diffs and whilst searching the net came across this site http://www.supraforums.com/forum/sho...-yesterday...&
Seems like the best stuff to use is the Ford 75W90 i'm just going to use the same stuff as what i currently have same grade but Mobil SHC Competition Gear Oil.
Originally Posted by SupraForums
2.2: Differential Carriers : Another condition that may trouble your Supras differential is lack of regular oil changes; this will lead to differential failure or premature wear out. The MA-70 differential holds a very small amount of oil so it needs to be changed regularly. Cold climates are very hard on the differential. I recommend using a good quality synthetic in cold climates. I do not recommend standard 80/90 wt oils in any Toyota differentials used in cold climates. Using 75/90-wt LSD differential carrier oil from Ford motor company makes Supra differentials run quieter and smoother than any other oils tested.
Some LSD differentials in MA-70 and MA-71 cars have excessive LSD {limited slip differential} cage pressure causing premature clutch pack failures after some cars have become stuck in mud or snow, I have opened up badly abused differentials where the LSD oil is completely burnt and Dried up from the heat of one wheel smoking while the other is locked. If you notice some chattery noise from the rear of the car when turning corners donít panic: you have a supra with a very tight LSD differential carrier. On a Supra with tight LSD you can avoid the above clutch pack failure by using the previously mentioned LSD differential carrier oil from Ford motor company. This oil has increased protection for the clutch pack and has proven to be the best differential oil for all Supras from 1982 to 1992. Don't ask me why, all I can say is this oil works like magic. Note: A number of club members are using synthetic oils from Amsoil and Esso in their differentials with good results, one word of caution should be noted." Synthetic oils may make a some differentials that are already noisy, noisier."
Old Mar 25, 2013 | 09:36 AM
  #105
cossiekevin's Avatar
cossiekevin
Hi guys do all supra diffs have LSD as standard? How can I tell the ratio and whether has LSD, don't wanna end up shelling out for the wrong thing?
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
Iain Mac
Sep 30, 2015 09:39 PM
SMILER258
Sep 28, 2015 09:04 AM
DavidK
Sep 27, 2015 02:55 PM
