Rolling Roads - Tell us your stories...
Old 27-07-2012, 06:59 PM
  #161
markk
markk's Avatar
Sounds cool mate, I will have to come over and have a look and get some education from you
Might even have some more work for on the new hardware.
p.s we need to meet up for some excellant food soon - it's been too long !
Old 27-07-2012, 10:05 PM
  #162
GaryEvo
GaryEvo's Avatar
depends on how you strapping them,if you pull on shock mount downwards and then 2 straps to stop it climbing its easy
yes i agree getting people to understand mapping dynos but this is real world and EVERY one wants things as cheap as poss
squatting in a rwd is not a problem - it's shitty fords with their geometry that means you get less contact patch the more that they squat that are a problem, and dipshit operators putting people in the boot and ratcheting them down harder only makes that worse.
Old 28-07-2012, 01:05 PM
  #163
Stu @ M Developments
PassionFords Creator
Stu @ M Developments's Avatar
Originally Posted by jamie's
stu does this mean that you will now be able to map non road legal track only cars now?
Yes, will happilly map anything on the rollers but be aware they still need a professional check over on the road as the map will be different once given full airflow and different load. If its actually road legal we will do that no problem and map it via datalogging if its too hairy to tweak live, but if not, its still going to need to be tested and tweaked off road somewhere.
Originally Posted by GaryEvo
great cooling is ace but if you have to charge Ł300 per hour to run and upkeep it it wont work in every day world
Agreed mate.
isn't it a matter of educating the customer as to why they need to spend that much to have a proper job done by someone who understands what it takes to do it properly and safely (the whole point of Stu starting this thread it seems)?
Easy to say, incredibly hard to achieve mate, you would be surprised at the lack of cash available in the fast road world, and most people dont know a good dyno from a horrendous one and are happy to pay for anything that makes a graph.
Originally Posted by steveboyslim
I would look at the TAT equipment, does require much more building work to install.
http://www.tat-rd.com/dyno_htm_e/dyno_start.htm
Steve
At a brief glance, I dont see anything there at all that OBD2 cant already do?
Very true. The DD high power tie down system hopefully makes all this a thing of the past, but we will see.
Originally Posted by CarlosST3
Good luck with this Stu, sounds like a brilliant plan!
Moving back to Blackpool so will have to pop by if anyone is having a dyno run so I can be nosey.
Feel free mate, I will show you where the brewing materials are. LOL
Old 28-07-2012, 01:06 PM
  #164
Sounds good to me. What you guys doing tonight?
Old 28-07-2012, 01:11 PM
  #165
markk
markk's Avatar
Going to a family bbq mate
I'll call you to arrange as soon as i can arrange a babysiter
Old 28-07-2012, 02:10 PM
  #166
dojj
Resident Wrestling Legend
dojj's Avatar
i seem to recall rod saying that he would only run his car is there was a cage or soemthing to hold it in place? or solid bars or soemthing
is that the best idea then to actually solidly fix the vehicle to the machine?
Old 28-07-2012, 03:15 PM
  #167
Carlos-Titx
Carlos-Titx's Avatar
No worries. If its not long after pay day I'll even bring biscuits
When's it all up an running? Just a thought but how about an opening day in the form of a PF dyno day?
Old 28-07-2012, 05:18 PM
  #168
steveboyslim
steveboyslim's Avatar
I would look again at the TAT web site not just at the data acquisition and control.
TAT make some very capable chassis dynameters in both 2wd and 4wd.
As an example to at http://www.tracknroad.com/
FoMoCo have found this rolling road to be within 1% of their own engine dynos at Dunton.
I must admit I do not full understand all the technicalities.
At least they have a built in barometeric and tempertaure sensors and are able to give accurate power figures including flywheel conversions from the 'run down' using data gained at the time of the session rather than and applied 'constant' for the flywheel power figure calculation.
Steve
Old 28-07-2012, 09:57 PM
  #169
T28 RST
Ok then
T28 RST's Avatar
I had my S2 on a few rolling roads but only had 1 bad experience and that was with AVA, they had the car to fit a Newman cam and upgrade the fuel system.
I got a phone call to say they had a problem with the car when it was on the rollers, they were doing a high speed run (150 mph quoted by them) when the drivers front tyre blew out
Snapped the bumper, broke the wing, fucked the tyre, rubber marks up the side of the car, chunks of rubber inside the car.
I paid for the repairs
I will post pics soon when I find them.
Old 28-07-2012, 10:05 PM
  #170
T28 RST
Ok then
T28 RST's Avatar
Nearly new Avon tyres
Old 28-07-2012, 11:46 PM
  #171
T28 RST
Ok then
T28 RST's Avatar
Had 1 bad experience and 1 shocking experience, my S2 had a bad misfire at 4000rpm, I took it to AVA who changed the fuel pump, fuel lines and metering unit, they charged me Ł600 for the job and it still ran like a tractor
I wasn't in a very good place with my health at the time and this just added to my worries so I locked the car up and in the end broke it up
Over the past few years I've heard so many bad stories about AVA, looks like there slowly getting found out for who they are.
Old 29-07-2012, 12:28 AM
  #172
botters
competant bodger
botters's Avatar
to be fair that tyre could have been split during fitting or had some other problem so you cant blame them for it blowing out and you cant expect them to pay for the damage either
Old 29-07-2012, 06:24 AM
  #173
Another interesting dyno point - I wonder how many dyno operators know that tyre manufacturers specify a maximum time limit for their tyres on a dyno? And its normally measured in seconds...
Old 29-07-2012, 06:37 AM
  #174
cossie4i+
TT T38 Power
cossie4i+'s Avatar
I was not aware of this, like many others i expect
Steve
Old 29-07-2012, 06:40 AM
  #175
Moderator
STeve's Avatar
dont say that steve will be buying special dyno tyres now
Old 29-07-2012, 03:28 PM
  #176
Karlos G
Balls Deep!
Karlos G's Avatar
Is this on the tyre somewhere Stu??
Old 29-07-2012, 04:24 PM
  #177
scoooby slayer
scoooby slayer's Avatar
hub dyno ftw
Old 29-07-2012, 04:44 PM
  #178
dojj
dojj's Avatar
is that for normal 2 roller setups then stu?
what about them single contact point roller type setups?
and is it true that if you increase the tyre pressure you can get a higher reading?
Old 29-07-2012, 08:49 PM
  #179
T28 RST
Ok then
T28 RST's Avatar
The tyre was perfect, they even said themself that they didnt know what happened
My question is, do all rolling road operators do 5th gear flat out runs with there cars on the rollers, who knows how many times my car was run up at this speed
Old 30-07-2012, 05:32 AM
  #180
foreigneRS
Testing the future
foreigneRS's Avatar
exactly. i have a pair of aston martin vanquish wheels and tyres in my back garden as flower pots as they had done some dyno time and were therefore useless for anything else.
Old 30-07-2012, 07:51 AM
  #181
vroooom ptssssh
It Wasnt Me!
vroooom ptssssh's Avatar
You broke that car as it was rotten....what's the sudden issue with AVA anyway? you were quite happy at the time to tell everyone who built/tuned the car, come back over and over for years and put AVA stickers on it etc etc etc....stop acting like a little bitch.
Old 30-07-2012, 08:16 AM
  #182
dojj
dojj's Avatar
lots of tuners become popular because they tell you wnat you want to hear
later on when people get smart and figure this out, it's natural to blame the tuner for fucking you over, and even easier when lots of other tales start to come out of the same tuner
my 2 bad tales of tuners could turn this thread all the way around from what it is supposed to be about as in neither case did i use their rolling roads so there i no need to comment
the guy used a set of rollers, this is what happened, totally relevenat to the topic, i've put several cars on several sets of rollers and in my granada i had a variation of around 20 brake which was easily explained by the fact it had an auto box and i've been on 4 sets of rollers with the mondeo and the ones with the standard engine saw it making the only figures they could make count being at the wheels and then after that i had an exhaust and air filter which realeased an extra 40 lbs/ft of torque which was really noticable on the road and was very noticable on the rollers as the power remained roughly the same
and every single one of thee testes were done on a set of dd rollers and all the numbers at the bottom were all the same
Old 30-07-2012, 08:12 PM
  #183
T28 RST
Ok then
T28 RST's Avatar
The car wasn't rotten, it needed a wee bit of work but thus was because AVA failed to fix the problem and I lost interest
You still havnt answered the question about AVA going down the pan........
Old 30-07-2012, 08:40 PM
  #184
T28 RST
Ok then
T28 RST's Avatar
Vroompish why are you defending Alan's shoddy workmanship so much
What the topic about, bad experiences at rolling roads..........LOL
Old 30-07-2012, 09:16 PM
  #185
TommyB
Boosted 122 cu in
TommyB's Avatar
The Mynes Evo are my friends. We brought that very dyno, single 42 inch roller balanced to 200mph.
It's a mustang dyno and I spend nearly every day tuning and running on it. We found that the 1/4 simulation test is helpfull for a tonne of different things. We have had a couple of big power front wheel drive cars on it making 400-500 hp with zero wheel spin. One of them has gone on to run consistent mid to low 10s which is cool. We also test our nitrous on there without wheel spin which is a bonus.
I once run a escort cosworth on the dyno for a1 rally sport and it went really well. The one thing you have to live with is wheel horse power results which I prefer instead of crappy run down losses which always create a point of discussion. I spoke with mustang alot and they all say to run in lower gear as possible. I run all the mini cooper s in 3rd. We get a nice long run topping around 90+ mph and have no issues.
Old 30-07-2012, 09:27 PM
  #186
TommyB
Boosted 122 cu in
TommyB's Avatar
Not to start arguments with but most components for top fuel engines are dyno tested. Blowers,valve gear,heads,injectors , sure they don't run a nitro engine on the dyno. Det will be detected by EGT's, pushed big end bearings and boucing marks where there heads bouce on the deck.
Old 30-07-2012, 09:38 PM
  #187
stevieturbo
C**t
stevieturbo's Avatar
Why would they say that ? Surely the likes of 1st gear, 2nd gear etc would just be nonsense ?
The torque the lower gears would generate would cause problems with both tyre grip and the dyno's ability to hold it back ?
Old 30-07-2012, 09:56 PM
  #188
TommyB
Boosted 122 cu in
TommyB's Avatar
I think there words were avoid 4th and 5th when you can as speeds are real high.
I use 4th for short geared cars and somtimes 5th for some lotus's we have done.
My way of explaining was wrong he he.
Old 31-07-2012, 05:33 AM
  #189
dojj
dojj's Avatar
If you read the title of the thread, I think you owe yourself a massive fail
It's about your experience on the rollers, which would assume that it's your car, and it's been on a rolling road
If the thread title was along the lines of "what's the worst fuck up a tuner has committed on your car" this thread would rival steves
Old 31-07-2012, 12:51 PM
  #190
vroooom ptssssh
It Wasnt Me!
Why don't you give Alan a call or pop in and see him, he's more than willing to talk to you about any issue's you have from the time...which was how long ago now, correct me if im wrong here....round about 9 years ago was it???
He seems to remember all 4 of your tyres were de-laminating when you got them checked....but you won't remember that coincidentally will you?
look forward to hearing from you 0141 848 5257 incase you've forgotten
Old 31-07-2012, 01:05 PM
  #191
JamesH
JamesH's Avatar
I used to think AVA were good etc, but T28 is not the only person from up north to tell of bad experiences recently! Seems just over the last year or so, quite a few horror stories have come out. My point is, surely they can't all be wrong!
Old 31-07-2012, 10:00 PM
  #192
jamie's
jamie's's Avatar
i wont go into in this thread as its not the time or place,
but i've used ava several times in the past(never again in the future)
only used them as there was very little 4x4 rolling roads in the area at the time(plenty now)
i've had a couple cosworths there and never left happy for 1 reason or another
had a couple escort turbos there(not mine but i was there with them),
alan did seem to be very good with these and they always left going well, cant fault them with them
but as soon as your not throwing an open cheque book at alan he hasn't got the time of day for you,
he even got my mate to pay Ł125 for a secret mod on his escort that took nearly 5 mins to do and wouldn't tell him what he done and wouldn'd let us see what was being done,
he even said there was no parts involved lol
i thought that was taking the piss a bit
anyhow i've said to much already here,sorry for the tread hi jack
Old 31-07-2012, 10:25 PM
  #193
tomoyb
tomoyb's Avatar
ive had my cars on 3 rolling roads in scotland,and have to say these state of the art dastek big ŁŁŁŁ rollers are rubbish.400bhp in 2wd form needed 2 in the back and 2 sitting in my boot.questions asked to why if such a good rr
ive had nothing but good experiance at ava on various visits.alan is a more than competant operator on his rr and talks you through whats happening/results,and his rr can take big power without the need of 4 fat bastrds in the car.and runs huge fans.
to sum my experiance up in recent years.....theres nowhere else id take my car this side of the border over ava
a friend of mine recently took his car down south for live mapping at a known tuner,fitted new cam,air injectors etc,think he got around 40miles and the belt jumped,.....equaled all bent valves,cracked block etc
had to buy a new engine
hence t28 give it a rest over an old tyre,these things are going to happen
Old 31-07-2012, 10:33 PM
  #194
stevieturbo
C**t
Who said Dastek were ŁŁŁ state of the art ? They are a good dyno, but they are a more budget setup than "state of the art"
Old 31-07-2012, 11:01 PM
  #195
jamie's
jamie's's Avatar
what car is this?
i wouldn't for 1 minute say anything about alans ability,
he's a very knowledgeable man and capable of great things
and the roller set up and fans etc are poss the best i've ever seen,
its just his silly prices and his terrible attitude i cant stand
but as i said about the escort turbo's he's a very capable guy
Old 01-08-2012, 10:08 AM
  #196
tomoyb
tomoyb's Avatar
2wd saph
Old 11-08-2012, 10:24 PM
  #197
T28 RST
Ok then
T28 RST's Avatar
Why you as an employe getting so defensive, out if the whole topic can you see any other employe's getting defensive
Yes it was a few years ago but it was still a bad experience at a rolling road.
If all 4 tyres were delaminating why did only 1 pop and why was he more than willing to run the car a week later with the same 3 tyres on it.
Old 11-08-2012, 10:35 PM
  #198
Turbosystems
Super Moderator
Turbosystems's Avatar
Steve
have you tried your car on a hub dyno
Old 11-08-2012, 10:38 PM
  #199
T28 RST
Ok then
T28 RST's Avatar
Alan is always keen to take take your money WITHOUT giving a receipt, how much money went through the book at that place.
Old 11-08-2012, 10:42 PM
  #200
T28 RST
Ok then
T28 RST's Avatar
Stop arse licking
It happened and they fucked it up
Quick Reply: Rolling Roads - Tell us your stories...
