Tuner in bournemouth
Tremona Garage in Southampton, and if they can't help they will recommend Power Engineering. They don't do mapping or rolling road for example.
Definitely DO NOT use Veysport though.
cheeRS
cheeRS
I will be as fair as I can be, and that is to say I have heard a couple of people say Andy @ Veysport has done a good job. But they were talking about Jap crap so no relevance here IMO.
Also to be fair, my car will never, ever, ever go there again.
Came back to me with the crank pulley a tooth out and me being told "got a bit of a flat spot around 3 grand, but that shld go with a bit of use. All your AFR/mixture/emission levels are fine."
Fortunately I checked the timing as I knew it wasn't right, and a tooth out! And the actuator rod came off within 2 days as well, which wasn't set right either.
Went to Power Engineering 2 weeks later and got told it was running so lean they didn't know how I got there without melting my engine! Levels were shot to shit, and my MAP sensor was faulty.
So make your own decision...
Richard @ Tremona Garage 02380775829
Power Engineering - 01895255699
Veysport - 0800 FUCKED!
cheeRS
cheeRS
Not too good with older turbo fords either, had no idea how to alter my timing on a setup session, it was running a fooking dizzy !!!
And reference knowing his jap stuff, you might want to ask around a bit
Daveyboy
55
26-08-2004 01:04 PM
