changed the oil on my cossie now oil plug will not tighten up no threads {update }
Old 04-03-2012, 02:04 PM
  #41
rich123
rich123's Avatar
this happened to mine i ust took the sump off and helicoiled it job done think it cost me 5 quid to get it helicoiled
Old 04-03-2012, 02:10 PM
  #42
mulla
mulla's Avatar
mines going to be in situa
Old 04-03-2012, 03:47 PM
  #43
mattman1234
mattman1234's Avatar
mine needs doing,will do it in situ.sell the heli coil kits on the bay
Old 05-03-2012, 10:45 AM
  #44
mulla
mulla's Avatar
how hard or what do you do to take the sump of from underneath the car
Old 05-03-2012, 11:02 AM
  #45
Guinnless
Guinnless's Avatar
You'd need to remove (or at least lower) the front crossmember BUT you will have to support the engine with a proper engine support bar because you'll have to undo the engine mounts.
Old 06-03-2012, 02:26 PM
  #46
mulla
mulla's Avatar
well today i bought a helicoil kit drilled it out tapped it out inserted helicoil,poured oil through engine washed out with diesal was surprised how much alloy came back out,inserted bolt couldnt belive it chewed up the sump plug bolt,tryed again with anorher helicoil tightened up this time then i noticed i hadnt put the washer on,anyway it was getting tight and i did not dare remove again lol,if it leaks hasnt yet i will th.ink about it when it gets rebuilt anyway put the tax disc in the window and went for a drive happy times again.thanks for all the help on here.now i need to chane the rear springs and shockers.
Old 06-03-2012, 02:37 PM
  #47
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
i wouldent wont to do it in situ on my car wouldent wont all the shit going into my sump from drilling it and tapping it!
Old 06-03-2012, 02:57 PM
  #48
Chip
*** Sierra RS Custard ***
Chip's Avatar
Fingers crossed that you got away with flushing the swarf out, and that that it doesnt leak then mate
Old 06-03-2012, 03:47 PM
  #49
mulla
mulla's Avatar
been out for a drive its ok at the moment will get it done properly when the engine gets a freshen up as there a few leaks on the engine anyway
Chas
21-09-2015 08:57 PM
da52rkn
Ford Focus Range
21-08-2015 04:41 PM
st220kyle
16
14-08-2015 06:13 AM
Bobby9779
11-08-2015 06:47 PM
CabrioTurbo
01-08-2015 11:04 AM
Quick Reply: changed the oil on my cossie now oil plug will not tighten up no threads {update }
