handling
Works and plays on track
Did you get just tracking or full alignment checked? Maybe lowering has affected camber angle. Depends how much you lowered it by for that to have much impact mind.
How much have you lowered it buy? What did you use, springs? Full coilover kit?
Was it done at a garage or at a specialist? Can't see how they couldn't at least checked the camber, even if they couldn't adjust it
It's not that they can't do anything with the camber because it's lowered, they can't do anything because it's not adjustable. If it has been lowered a lot then it will have a lot more negative camber than standard. With that in mind, a standard toe setting is not likely to be the best thing for it. The thing to do would be to try it 2 degrees in then 2 degrees out and see what effect this has.
Go to somewhere that does computer alignment. I know ATS do it out of the multiples. You at least need to know the camber angles as well as toe, to see if these are the cause.
wowk
30-03-2021 07:49 PM
