Custom charge cooler, who makes em? ...... update... new one 1/2 fitted already!
I need a custom made charge cooler for my 5. Who makes em?
I can think of
Pro alloy
Spec R
Pace
Thats it.
Who else is there?
I can think of
Pro alloy
Spec R
Pace
Thats it.
Who else is there?
Docking, Pace, A&H, Spec R, Forge, GRS, Radtec, ProAlloy, RSFabrications etc Pretty much anywhere that makes intercoolers will be able to make them.
No doubt there are countless more
*** Sierra RS Custard ***
I've got a home made one on my nova that seems to work well.
Garage19 off here tigged it up for me.
I used 2 4wd cossie intercoolers as the core, im sure there are various reasons why that isnt ideal, but seems to work really well so far.
Bit about how he made it here:
And this is it fitted:
Originally Posted by Garage19
As you probably know Chip has a Nova with a LET in the boot. He is also building a new 4-500 bhp lump to replace the original LET so he has asked me to knock him up a charge cooler setup using two 4x4 cossie intercoolers that he supplied.
First job was to remove the end tanks and weld the two cores together.
Then I cut and folded the two halves of the new water jacket.
The water jacket should have a capacity for 19.5 litres. It may weigh a bit (i expect he will need some weight for traction)but all that water will need some energy just to raise it even a degree or two.
The large capacity will iron the temp rises from bursts of high boost more easily. It should be perfect for running up the quarter mile.
Then the water jacket was welded up and to the cores.
This photo gives you a good indication of its size.
The PWR are compact and neat....Ive yet to read any good reviews on them though.
Quoting nonsense airflow or power figures is one thing, but it doesnt matter how much air they flow if they dont cool the stuff !!
The most important aspect of any chargecooler DIY or otherwise is having the water circulate properly and evenly through the core. Although I guess that's no different to an A2A cooler. Often end tanks are badly compromised and air doesnt flow evenly through them
Im sure they do 500bhp of airflow as claimed for the one in question, but they dont take enough heat away, nowhere near.
Be ok for a v8 with .5 bar to make 500bhp, but not a 2 litre engien with 2 bar!
Yes it will make it less efficient if you have a bit of a difference in core temp from one side to the other, but I would wager its by a few percent not by half or anything like that.
The same is true if you only put cold air over half an intercooler, they do a very good job of evening that out with internal conductance.
One problem people have chargecooler is simply not having enough cooling for the water to air half, thats an issue with the PWR kits in particular, the water radiator was nowhere near big enough, we managed to make the charge cooler work better just by adding more cooling for the water, although it was still not up to the job, I think you'd need liquid nitrogen for that, lol
We had a problem with these on 4wds just not doing the job I ended up going front mount (not the best for rock climbs) and my mate had a custom tubular one done that works very well.
We never found anything better than water for putting in the systems either.
I use an alloy ERST S1 radiator in the boot (which is fed air from ducts in the rear side windows and a Spal fan that pulls air through it) to cool the water going through the chargecooler. The rads and pumps usually supplied are nowhere near big enough or efficient enough to cool or circulate the water if you up the rad size.
On my nova I have two motorbike radiators in the front of it, with a subaru legacy pump, that seems to work well and cost next to naff all.
I have got a huge rad upfront and 2 pairs of pipe thats 12mmx5m long, so loads of water.
I have 2 pumps and did have 2 small charge coolers but one has died so ineed a new one and thought id get a proper one made.
My biggest problem is space, i dont have any.
I will email all of the listed firms to see what they say.
I can keep the one i have and get another small one or get 1 big one. Whatevers best really.
There is 1 place i can fit a big cooler easily but it would mean the pipes ran past the exhaust manifold and over the exhaust and the cooler would sit above the exhaust.
If i wrap the exhaust and fitted a nimbus heatshield under the cooler would this work? Or would the exhaust system heat it up too much?
I think it would work and make the cooler itself easier but pipe run more complicated.
I use Nimbus G2 around my chargecooler - as my engine rad pipe runs close to the unit. So far it has held the heat away from the chargecooler ok, but I have not really run the car properly with this so can't say whether this is a foolproof barrier.
That sounds promising
Heres a couple of crappy old pics i found
This shows the size of the rad,
Thats 1x12" fan and 1x10" on there so shows the size of it, the chargecooler rad is the front 1
Here you can see the exhaust run...
I was thinking of putting the cooler on the bar that runs across the spaceframe from coilover-coilover, then i can get a nice big 1 on there.
The boost pipe would have to come out the turbo and go backwards
If i could get an off the shelf cooler to fit i expect it would keep the cost down a lot
Oh My how its changed lol
Looks an acceptable place to put it to me, anywhere is going to be a compromise though.
Might be worth installing a partion that it sits inside and then try and feed that with a small fan from the outside to stop the box itself heatsoaking from the bay in general if its just above the exhaust?
I can run some cold air ducts from underneath but not above cos i wanna keep it as subtle as poss.
Where these circle holes are i have now cut the whole section out to let air out, the exhaust manifold is ceramic coated but i will wrap it, wrap the whole exhasust and get a turbo jacket to keep the under "boot" temps down lol.
Next question i suppose is, would this ebay charger be worth a try?
At this price its obviously chinese but its big and if turn 1 end cap round 180 degrees then its ready to use, i just need a few pipes.
http://item.ebay.co.uk/viewitem?item...w=400206201724
Its a lot different to the Ł750 im being quoted so far!
this is what i was thinking, its the front mount of the other 5 put in place to show what i was thinking.
also i measured my rad, its 800mmx500mmx30mm, and i have 12m of 12mm pipework so whatever that works out to be lol
also i have 2 pumps that push 150 litres per hour
oh and thanks to whoever(chip?) gave gary my number, i have bought his AH fabrications one
its a tad smaller than the cooler shown above, should work just fine
well as i said above, i got a txt from garyhurn and i bought his cooler.
its off his nova that was running 400+bhp, 2bar boost on a t34, t38 then gt30 and he recons he had good inlet temps seeing about 7-8degrees above ambient when on track.
it was made by ah fabrications and specced for 450bhp with room for more.
well im running 2bar through a t34 aswell with roughly 400bhp but my rad is about 3 times the size of his old one and its in the front of the car with nothing behind it keeping it warm, and has much more air flowing through it. also my pumps a little higher flow (150l/h vs 110 l/h)
and just incase thats not good enough ive left my old charge cooler still fitted. its a pace twinpass jobbie, about 8"x8"x8", this with the new one which is about 12"x4"x6" i should have nice cold inlet temps.
i have 2 pumps and twin inlet/outlets on the rad and 2 swirl pots, so both coolers will have thier own cold water supply.
and here it is 1/2 fitted.
i reused most of my old pipework and have to buy 2 more fittings so i will have a little more lag than before but not as much as i thought.
i should have it complete and ready for testing by the weekend as long as the bits turn up.
once it on and working and i know its good enough i will send it away to have new endcaps with different outlets for better airflow and get some mounting tabs welded on. but just wanna see it work first lol
2bar here i come
2bar here i come
Stu @ M Developments
41
21-08-2015 06:47 AM
track.focus'd
12-08-2015 05:53 PM
