Flat shifting
Old Dec 23, 2011 | 09:54 AM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Default Flat shifting
What is it? I've seen the term used before but never knew what it meant!
Ben.
Old Dec 23, 2011 | 09:56 AM
JayCC's Avatar
JayCC
Can anyone explain double clutching? Supposed to be quicker? How?
pani_k's Avatar
pani_k
PassionFORD Member
Change gear without taking your foot off the gas
Old Dec 23, 2011 | 10:41 AM
Fil's Avatar
Fil
ELASTIC BAND
used to have a box set up, that allowed it without hitting the rev limiter,
Keep the accelerator pedel to the floor, engage the clutch, and the revs would hold at where they were, say 5000rpm, change gear and keep going.
Stops the revs dropping off through gear changes, and stresses everything out alot more
Old Dec 23, 2011 | 10:48 AM
GVK.'s Avatar
GVK.
clutch in - shift to neutral - clutch out - clutch in - shift to next gear - clutch out
double clutch and heel and toe -
http://youtu.be/0j-3xIZK-Bk
Can't see that it's quicker, essential for old cars with 'crash box' (no syncromesh)
Also on a proper flat-shift set up there will be an ignition cut so you get a back fire BANG!! during gear changes. Can be actuated by clutch switch or load cell/micro switch gubbins on gear lever.
Old Dec 23, 2011 | 10:53 AM
krypton's Avatar
krypton
Most mk2 rally cars people are fitting flat shift. It allows the gearchange to be made without lifting of the throttle usually worked from a strain guage on the gearlever which connected to an ecu. It cuts spark/fuel to take the load of the gearbox and saves driver error of not timing the throttle lift right and damaging the gearbox
Old Dec 23, 2011 | 10:57 AM
Warren's Avatar
Warren
I run flat shifting on the FFD 7 Speed box in my Escort, it has to be one of the best mods out there for track.
You just keep the foot planted and pull that leaver
I run the fuel cut only
This is what it sounds like
http://www.youtube.com/watch?v=v7J9pju3WI0
Old Dec 23, 2011 | 11:22 AM
Oranoco's Avatar
Oranoco
Double clutching is slower but needed on older boxes with no synchro mesh. Drove an old (see stone age) Bedford horse box that needed double clutching.
Heel and toe is a very useful technique I even do it in the company pool cars
Old Dec 23, 2011 | 11:31 AM
GVK.'s Avatar
GVK.
H+T sounds cool as well
http://www.youtube.com/watch?v=NDk_7...el_video_title
Old Dec 23, 2011 | 11:42 AM
GVK.'s Avatar
GVK.
Cool pedal cam from V8 Supercar
http://www.youtube.com/watch?v=qdWSyrqEnE4
Old Dec 23, 2011 | 11:52 AM
JayCC's Avatar
JayCC
Why does he tap the brake pedal with his left foot?
Old Dec 23, 2011 | 12:18 PM
GVK.'s Avatar
GVK.
So combat 'pad knock back' - when he goes over kerbs and under heavy cornering forces the pistons can get pushed back into the caliper by the disc rotor, so when he brakes he will have a long pedal (excess travel) by tapping it with the left foot on the straight before a braking zone, his brakes will be 100% when he needs them.
Old Dec 23, 2011 | 12:20 PM
Madgit's Avatar
Madgit
Works and plays on track
See what happens when you try it round a bend.
Old Dec 23, 2011 | 05:10 PM
JayCC's Avatar
JayCC
Harsh.
Old Dec 23, 2011 | 05:11 PM
JayCC's Avatar
JayCC
Thanks for explaining!
Old Dec 23, 2011 | 05:32 PM
GVK.'s Avatar
GVK.
I've had it happen on my Golf with a slack rear wheel bearing - pedal went to the floor, brown trousers!
Old Dec 23, 2011 | 07:03 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
I have it on mine the ecu cuts spark while you change gear so the foot stays planted & boost stays up. No back fires if its set up correctly.
Old Dec 23, 2011 | 07:18 PM
The Youth.'s Avatar
The Youth.
my 100E has flatshift lol
takes some getting used to keeping your foot planted expecting the revs to go through the roof and they don't!
steve
Old Dec 23, 2011 | 10:05 PM
BRIGSPORT's Avatar
BRIGSPORT
UNAUTHORISED DEVELOPMENTS
I never tire of listening to aussie v8's!
Old Dec 23, 2011 | 11:49 PM
polly_x's Avatar
polly_x
On your setup Rod how is the system triggered and how does it know when the gear change is over?
Old Dec 24, 2011 | 03:13 PM
AGAR-COSWORTH's Avatar
AGAR-COSWORTH
Redumbdancy
In the video above, the driver is double de-clutching when he's down shifting? In a box with no syncro, I always thought that you need to use double de-clutching on up shifts too?
Old Dec 24, 2011 | 03:55 PM
GVK.'s Avatar
GVK.
Yeah, I thought the same, dunno why he's doing it, video was just to demonstrate the principle.
Old Dec 24, 2011 | 04:18 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Theres a micro switch on the clutch pedal. I assume when you lift the pedal its back to normal never really thought about it.
Old Dec 25, 2011 | 09:26 AM
grazo's Avatar
grazo
You can even get a flatshifting system that not only does full throttle clutchless up gearshifts but clutchless downshifts as well with an autoblip system no need to heel & toe see www.flatshifter.com called the flatshifter Expert system i think, a friend of mine has one on his focus 4x4 cosworth rally car
graz
Old Dec 25, 2011 | 11:53 AM
Red16's Avatar
Red16
Speaking of Flatshifters, I treated myself to the Expert kit for Christmas, not fitted it yet but this is what it looks like
Can't wait to thrash the BEC with this fitted
Old Dec 26, 2011 | 09:20 AM
grazo's Avatar
grazo
Nicked this link of a Flatshifter Expert system in action
from the website www.flatshifter.com
It worked great at VIR! We won both races and we set a new track record by 1.1 seconds! (Expert system)
Feel free to use it or any of my videos for your promotion.
http://www.youtube.com/watch?v=MfoQ01ZoxcY&feature=channel_video_title
Old Dec 26, 2011 | 09:30 AM
whizzisat114's Avatar
whizzisat114
Anyone else notice the fluid running down behind the clutch pedal on the car foot pedal cam video?
Old Dec 26, 2011 | 09:52 AM
COLEYST200's Avatar
COLEYST200
Funny thing Dave i did
Old Dec 26, 2011 | 10:46 AM
krypton's Avatar
krypton
I noticed it aswell but i think its just dirt rolling back and forward
jessie_rs
62
Aug 6, 2019 09:27 PM
stevecfrst1
Sep 30, 2015 05:18 AM
KennyWelsh
Ford Focus (All Models)
Sep 13, 2015 08:28 PM
Billy_RS
Sep 13, 2015 04:17 PM
