vtec hype???
Old Dec 7, 2011 | 11:18 AM
  #121
RickyLee53's Avatar
RickyLee53
Originally Posted by Chip
Danw, your appraisal seems to be of N/A versus turbo (or diesel turbo) rather than vtec versus non vtec. Everything you said applies equally to all non vtec N/A engines as well, just in most cases they dont even have the go when you do rev them either!
Upto 6K there is basically naff all between a vtec and non vtec engine, then from 6K onwards the vtec wins.
Its weird that cause the engine gets massively better at high rpm it makes people not like it at low rpm, where as without that power at high rpm no one seems to mind their cars being gutless low down (ie a normal 2.0 zetec etc)
We all agree that if you want a big surge of midrange torque you need a turbo, or a lot more capacity, there is simply no way to have an N/A engine of small capacity that pulls well at low rpm, the laws of physics totally prevent it.
Exactly my point, because its good high in the RPM's people think they'r bad at low RPM's when infact they'r on par with just about everything else.
Originally Posted by DanW@FastFord
Since when?
I think you've read the statement (myth?) that Honda have never had a warranty claim on a VTEC system. It doesn't refer to the engine, just the VTEC bit! Honda engines fail like any other manufacturers engines do... well, maybe a little less commonly that some, but they're not immune to failures.
I'd say a lot less common. If you comparing the S2000 engine you need to compare it to something with the same power output per litre. The only other car is the Ferrari 458 (it's only just been matched 10 years on) I dare say there will be more Ferrari's breaking (as a percentage)
My appraisal was of the VTEC engines, and the driving characteristics of them in comparison to their competitors. I didn't know the 'rules' of the discussion was that you weren't allowed mention forced induction cars.
I don't like VTEC engines, and I was throwing my four-penneth into a conversation about them, and I stand by my comments.
Ultimately I'd much rather have an N/A where there was a more even spread of power - I've not looked at the dyno graphs but I'd wager that a Clio 182 would make more power at 2K, 3K and 4K than a Civic Type R - or at least it has driving characteristics that I prefer over the Type R.
I think you will find the 182 is down on power EVERYwhere in the RPM range.
Originally Posted by Ad4m RST
Ok I'm out on the refinement of my pub talk lol...
But still, call it a 3year warranty on standard cars that rev to 9k rpm & never fail where they're most likely to under those conditions. Completely unmatched.
Add the fact that the S2000 has higher piston speeds than an f1 car, and a haybusa it sound even better.
Originally Posted by RWD_cossie_wil
Been in an S2000, Prelude 2.2 vtec, integra type R & a civic type R... Not really anything to write home about i'm afraid, the S2000 was the biggest dissapointment, really peaky and flat delivery, even thrashing it's cunt off at 9500rpm it felt Sloooooooooooooow ..Seemed to spend it's life in 2nd and 3rd gear, and I thought the gearing was far too tall for it's power, top of 3rd gear is close to 120Mph IIRC?! I know they are great really, but I just don't like the way they drive, and the HUGE over-hype of Vtec, it really just makes a slightly higher noise with no real forward motion
The idea of vtec is to have a flat torque curve, (which is seen ideal/perfect you cannot get better) honda are closer to this than anybody else. This of course makes them make more power at the top of the RPM's, but why wouldn't you want that? If you've tuned your cossie you've tried to achieve this.
Heres a powergraph of a 1.6 turbo Honda we built. (standard engine) The power delivery is still peaky, but torque is somewhat improved.
Old Dec 7, 2011 | 11:22 AM
  #122
Chip's Avatar
Chip
*** Sierra RS Custard ***
Thats EXACTLY what I want from my engine.
My target I mentioned in my build thread was to aim for a flat curve at 200lbft, your so close to that its scarey!
Bet that is an absolutely awesomely tractable engine for a FWD car!
Old Dec 7, 2011 | 11:40 AM
  #123
RickyLee53's Avatar
RickyLee53
Thats a 1.6, you can expect 200lbft 500-1000 rpm's earlier on the b18, we also map them to "remove" some low down torque off vtec to prolong engine life. (this isn't too bad on the b18c4) as the pistons are somewhat stronger in the ringland area.
Also to all the haters, at which point does the car come on vtec?
Old Dec 7, 2011 | 11:44 AM
  #124
vroomtshh's Avatar
vroomtshh
I take it you mean the car in the graph? I'm not a Vtec hater (quite the opposite in fact) but it looks to come on vtec around 5250RPM, which would be a little lower than standard
Old Dec 7, 2011 | 11:50 AM
  #125
RickyLee53's Avatar
RickyLee53
Its actually much earlier than that, however we have to try and "kerb" the torque for the reasons mentioned above, ones you get the engine spinning its not so bad. Good educated guess though.
Old Dec 7, 2011 | 11:55 AM
  #126
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
Just to add - I'm not a 'hater' in any way - I know they're great engines, they're just not for me!
Old Dec 7, 2011 | 12:47 PM
  #127
RickyLee53's Avatar
RickyLee53
Yes, I should probably say I'm not really a Honda die hard fan. I have other car's.
However there isn't really anything not to like about the engines. If you don't want them to feel peaky just don't rev them past 6, then it'll be like any other 2 litre/1.6 whatever.
Old Dec 7, 2011 | 01:54 PM
  #128
danneth's Avatar
danneth
TORQUE!
Old Dec 7, 2011 | 01:56 PM
  #129
danneth's Avatar
danneth
TORQUE!
p.s
http://www.youtube.com/watch?v=u0MyLfkd-2Q
" that way im always vtecing you "
Old Dec 7, 2011 | 02:43 PM
  #130
Chip's Avatar
Chip
If I can have 200lbft from 4k-8500, i'll be over the moon, but TBH from 5500 to 8000 would still be enough to keep it on the boil, so doesnt matter if its not quite as good as it could be.
Im thinking of using a GT3071 on it TBH, even though its way bigger than I need, I just really like the way those turbos deliver their power, and it looks like the evo setup you use would have no chance of fitting in my bay, unless you can rotate it so the inlet doesnt poke as far towards my headlight?
Will talk to you about it once the engine is in though as its no doubt you I'll be coming to for the manifold and downpipe anyway, and until its in there I really am only guessing!
Old Dec 7, 2011 | 03:46 PM
  #131
Fiesta_Jed's Avatar
Fiesta_Jed
This thread, along with some videos on youtube have got me thinking
B18/k20 mk2 fiesta ?.
I could get used to the power delivery if it meant I got that noise.
Old Dec 7, 2011 | 03:54 PM
  #132
RickyLee53's Avatar
RickyLee53
The Evo setup is the most responsive we've used to date. Something slightly cheaper with better responce is a custom Precision turbo we had done (just a jornal bearing) it would do around 480hp max but is a very nice compact turbo.
With the Td05 been twin scroll its a bit on the large side as you say. Of course, we haven't tried to keep the kit as compact as it could be because there isn't a reason to. Yours would no doubt be a custom kit so I don't suppose it'd matter really. The main reason the inlet is twisted is actually to clear the Aircon pump should customers wish to retain it.
Old Dec 7, 2011 | 03:57 PM
  #133
Guile1's Avatar
Guile1
VTEC = Brilliant technology / ultra reliable.
Everyone keeps saying VTECS have no torque, i'm not sure they actually know what torque is or how the technology works
Lots of mis information picked up from backstreet pubs being qouted about on car forums
STOP listening to everything clarkson says and do some research!
Old Dec 7, 2011 | 04:06 PM
  #134
weegaz22's Avatar
weegaz22
Whats Clarkson got to do with this?
Old Dec 7, 2011 | 04:15 PM
  #135
Chip's Avatar
Chip
Yeah that makes sense about the aircon pump, long since gone on mine, as is the power steering pump, so quite a lot more space near to the block
Old Dec 7, 2011 | 04:44 PM
  #136
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Are you going to purchase a hand bag & makeup to go with this girly Spec Chip. I thought i saw traces of eye liner at Middlesex club night .
Old Dec 7, 2011 | 05:00 PM
  #137
RS 5tu's Avatar
RS 5tu
i`m with you on that one,
i had a 5th gen prelude 2.2 vtec with cams, it really wasnt for me not that it was a bad car or bad engine it was just the mirror opposite to most of the performance cars i have had where by it felt like you had to drive it like to stole it to really get the best out of it and that didn't appeal to me.
Old Dec 7, 2011 | 05:09 PM
  #138
Paul_RS's Avatar
Paul_RS
Its a 2.0 N/A engine, revs is the ONLY way to get power out of them.
You cant compare to a turbo engine
They rev to something like 9000 rpm IIRC, for the revs they pull the power isn't that impressive.
I appreciate the engineering behind them adn i'm not going to say they are shite, but i just don't like them, to me they are all fart and no shite.
Drove a couple of them in the past and on a local private road with a slight incline, whilst climbing said inclide, i did find them to start to struggle a bit. Whereas the RS 2000 i had at the time (150bhp and 150lb/ft and only revs to 6600ish) wasn't effected to anywhere near the same degree by the same section of 'track' .
From my experience i'd put some of it down to how they are geared - too long IMO, but the majority to how the power is delivered.
I'd like to drive one with a higher final drive to see if that livens them up.
Old Dec 7, 2011 | 05:15 PM
  #139
Chip's Avatar
Chip
LOL!
Not going to be doing top speed runs, it will be geared to hit a speed of 140mph on the back straight at bedford, and even if I had a much longer straight that means it will be limited to just under 150mph, I want a really useable trackday car and for fwd 200lbft all through the rev range is a great place to be
Old Dec 7, 2011 | 05:24 PM
  #140
gjh's Avatar
gjh
They are good for tuning and stuff, but crap for rallying, to noisey (bad for PR), and a lack of torque (there was a vid somewhere of a mk2 doing a rally at the epynt ranges and at nearly every hill they got to (they ain't that big there by the way) and the driver was constantly having to change down a gear cause it just couldn't pull up hills, for street and tuning, get a vtec, for rallying, stick to XE or duratecs
Old Dec 7, 2011 | 05:28 PM
  #141
J1mbo's Avatar
J1mbo
B1mbo
Vtec is an amazing engine, its the muppets that own them that causes the issue
Oh and the bullshit figures that come from 'boosting' them. It's funny when my 270bhp escort can play with 350bhp vtecs LOL
Old Dec 7, 2011 | 05:31 PM
  #142
Chip's Avatar
Chip
Yeah? Well go and play with one of rickylee's 350bhp ones
LOADS of people full of shit about them im sure, but the RS Turbo is just as bad, I used to reguarly trounce "200bhp" Rs turbos back 10 years ago when I had a bog standard XE in a nova.
No make has a monopoly on dickhead owners.
Old Dec 7, 2011 | 05:32 PM
  #143
gjh's Avatar
gjh
Well said Jimbo
Old Dec 7, 2011 | 05:35 PM
  #144
J1mbo's Avatar
J1mbo
B1mbo
Have a giggle now then, it was!
Td04 at a 10.9 psi on a forged b18 in a civic coupe
Nothing in it to 130,
How it went, I had gearbox issues so up to fifth gear we were both a bit unsure of who was going, but in fifth he pulled out and both kept planted and I went long way round and he was most deffinately not coming by, might have been unto about 140 in the end actually I was running 23psi realistically 280 to be fair.
Old Dec 7, 2011 | 05:44 PM
  #145
Chip's Avatar
Chip
So you had a 2 litre engine with 23 psi and he had a 1.8 on 10.9 psi, and it was neck and neck?
I'd say he did rather well then
Old Dec 7, 2011 | 05:46 PM
  #146
J1mbo's Avatar
J1mbo
B1mbo
No, I haD a 1600cc 8v asthmatic cvh
Old Dec 7, 2011 | 05:48 PM
  #147
J1mbo's Avatar
J1mbo
B1mbo
Also, what sort of a comment is that re boost pressure. Thats like saying a 1.0l engine with 40psi might be slower or faster than a 4l with 10psi has nothing to do with what boost it runs.
Power for power his was 70 better off.
Old Dec 7, 2011 | 06:04 PM
  #148
Chip's Avatar
Chip
Its all a moot point TBH as since Mo was on here, I no longer believe anything you bullshitting escort / rs turbo drivers say about races anyway
I'd sooner trust the honda drivers than you lot.
Old Dec 7, 2011 | 06:23 PM
  #149
RWD_cossie_wil's Avatar
RWD_cossie_wil
I personally think a well tuned XE is a far better engine than most Vtecs.... Just feel much nicer to drive.
Old Dec 7, 2011 | 06:37 PM
  #150
RickyLee53's Avatar
RickyLee53
So the S2000 has 36% more RPM's and 60% more power. I don't see how that helps your arguement?
A td04 will never do 300hp never mind more. They max out at about 260 on a b series with a horrible powerband. They peak power at about 6500rpm's, (ironic for this thread)
Also there was no reason to forge at that power level.
Old Dec 7, 2011 | 06:56 PM
  #151
Chip's Avatar
Chip
He's probably dropped the CR so far its lost him power too!
Not to mention I bet it isnt mapped right, where as I would put money on Jimbo's map being perfect
Old Dec 7, 2011 | 07:05 PM
  #152
J1mbo's Avatar
J1mbo
B1mbo
Chip, are you trying to say Rickylee woUld send somethi out un mapped
It may be a td05, I dont know these turbos well
Ricky, you told him it was 350iirc and now he's running a bar of boost it should be near 400
It's high comp chip, or what I'd consider for a turbo engine not 11:1 standard but in the 9s I think. Ricky specced it all
Ps, nice get out class with mo
Old Dec 7, 2011 | 07:14 PM
  #153
RickyLee53's Avatar
RickyLee53
What car was it? Unless it was heavy? Been driven by an idiot i cannot see why it'd be slower.
Our basic turbo kit at 300hp, (I very rarely do more than 300hp on them) I advise bigger. Does around 13.0-13.3 on the quarter at 106-110mph. At 400hp they do 12.0-12.4 (proven many times over)
Edit, to say, I certainly wouldn't spec any car to be forged to run 300hp, its a complete waste of time/money.
Old Dec 7, 2011 | 07:15 PM
  #154
Mark V8's Avatar
Mark V8
Nothing against Vtecs, I just like the picture
Old Dec 7, 2011 | 07:17 PM
  #155
J1mbo's Avatar
J1mbo
B1mbo
Its rory's car Ricky. Don't get me wrong its bloody quick, but I thought it would leave me standing, I said it would be a genuine 310-320bhp as after 140 I would expect he'd be reeling me in.
It deffinately dosnt go like 350 though, it may do now it has the boost up but not the weather for taking me out in it he reckons
Old Dec 7, 2011 | 07:31 PM
  #156
RickyLee53's Avatar
RickyLee53
Black coupe? Ye they'r pretty heavy. The actuator failed at some point and it had a boost leak IIRC, hence why we changed it to run more power. I'd say your probably right, 300hp max at the time. Coupled with the heavier weight I dare say little/nothing in it. Its maxed out now from what I remember so should be a very different story now.
Old Dec 7, 2011 | 08:09 PM
  #157
J1mbo's Avatar
J1mbo
B1mbo
I hope so! He took me out about a week after he got it back roll on the good weather try and get another go in it shame I sold me engine now
Old Dec 7, 2011 | 08:33 PM
  #158
3FRD's Avatar
3FRD
I love my EP3, I bought it standard and have done a few mods now. I think they are good bang for buck and for what I've spent on performance mods I think it's pretty good power.
My mods now are-
Engine & Gearbox Mods:
DC sports Manifold
DC sports cat back
Uprated energy engine mounts
Gruppe M
Funky power lambda eliminator
Dasteq Q+ ECU remapped by Wallace Performance 236.9bhp 182 ft/lb's
DC5 Gearbox - Shorter 4th, 5th and 6th
Spoon 5.1 final drive kit
Spoon (kaaz) 1.5 way plated diff
F1 Racing Stage 4, 6 paddle clutch
Engine running on Castrol Edge 0W30 fully synthetic oil
Gearbox running on Kaaz LSD gear oil - 80w-90
Brakes & Suspension:
Tein Superstreet Coilovers with adjustable top mounts
Stop Tech 330mm front brakes with red stuff pads
Drilled and grooved rear discs with mintex pads
Rear camber arms
Fast road setup
Wheels and Tyres:
17" x 7.5" Compomotive MO5 wheels powder coated in white. DC5 offset for wider track. Conti Sports.
Body & Interior:
JDM wind deflectors
Funky power mud flaps
One off debadged front grill
Oil Temp and Water Temp in carbon holder in car
Genuine Honda Type R mats
I'll happily take anyone out a run in it to show them how good / bad it is.
I do however agree there are alot of bams own them but it's the same with most cars. I bought mines because I like it, I'm not into the whole jap scene.
Old Dec 7, 2011 | 08:57 PM
  #159
Adam.'s Avatar
Adam.
Needs Beer Tokens.....
Lag
Lag
monster torque, light the tyres up go sideways
Then you get it back under control, and you fall off the end of the torque curve and have to change gear and start all over again
I love it, its great fun, shit for actually going anywhere quickly though!
Loves it!
Old Dec 7, 2011 | 10:09 PM
  #160
ontheway's Avatar
ontheway
i <3 vtec haha the sound of my mates ek9 type r with a spoon exhaust overtaking at circa 130 mph sealed the deal !
