help the f**king cossie wont start(driving me crazy!!)update
Old 16-02-2005, 10:51 AM
capri-rs
capri-rs's Avatar
Default help the f**king cossie wont start(driving me crazy!!)update
is there anyone that can help me with this?the engine cranks ok but will not fire.changed coil.ign.amp. map sensor.dizzy cap and rotor.plugs.when i carry out a break out test everything is ok.but its not!!!i can tow the car and get it to start but it wont idle properly untill it´s hot.when hot it starts ok but have a little glitch if you depress the throttle a little bit fast.pick it up slowly no problems.have checked fuel pressure and fuel pump ok.havent changed air temp,throttle pos. or phase sensor.still have that and the ecu and wiring.can anyone help me there????
wbr
Geir
Old 16-02-2005, 12:32 PM
capri-rs
capri-rs's Avatar
bttt.
wbr
Geir
Old 16-02-2005, 12:47 PM
Stu @ M Developments
PassionFords Creator
PassionFord Gold Member (Male)
Official PassionFord Trader
Administrator
Stu @ M Developments's Avatar
Air and coolant temp can do as you describe. Very unlikely to be TPS.
Old 16-02-2005, 12:58 PM
capri-rs
capri-rs's Avatar
cheers stu.i dont have the new air temp sensor yet but since the coolant sensor have the same values could i use one just to get it started??just wondering??
wbr
Geir
Old 16-02-2005, 01:01 PM
Administrator
Yes, but naturally it wont be accurate due to not being insulated from the head so dont be thrashing her around.
Old 16-02-2005, 01:04 PM
capri-rs
capri-rs's Avatar
no was just thinking of starting the f**ker.have a couple of those liying around
Old 18-02-2005, 07:15 PM
capri-rs
capri-rs's Avatar
fitted new air temp sensor.same trouble.
will soon be sold in bits if i can´t get it to work
Old 22-02-2005, 06:06 PM
capri-rs
capri-rs's Avatar
hello again.STU! is the ecu broken when you take off the vacuum pipe for the mapsensor and engine doesn´t stop??
wbr
Geir
Bailes1992
16-08-2015 07:14 PM
Adam-M
22
10-08-2015 10:46 AM
CabrioTurbo
01-08-2015 11:04 AM
Quick Reply: help the f**king cossie wont start(driving me crazy!!)update
