engine studs
Old Sep 4, 2011 | 08:09 AM
graham c's Avatar
graham c
Default engine studs
am rebuilding my engine aimming for 450 + 50-100 gas so wots best to hold the head on
short studs with metal gasket or 6 long studs and 4 mormal
Old Sep 4, 2011 | 09:07 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
what block are you using
Old Sep 4, 2011 | 09:12 AM
Jay,'s Avatar
Jay,
Sponsor
my guess a pinto
Old Sep 4, 2011 | 09:39 AM
graham c's Avatar
graham c
Old Sep 4, 2011 | 10:44 AM
JonnyBravo's Avatar
JonnyBravo
I would imagine 6 long studs would do the trick, proven time over.
Its a full rebuild though if you go down that route and I'm quite sure you will be told not to use ARP studs as they don't seem to be good for a YB block.
Old Sep 4, 2011 | 11:00 AM
graham c's Avatar
graham c
so which long studs should i use then
Old Sep 4, 2011 | 11:03 AM
LHD220Turbo's Avatar
LHD220Turbo
check reylands website
i'm sure his studs are good because you can use a standard socket on them once they are in the head
edit: 6 long studs and then genuine standard studs seems to be what most use
Old Sep 4, 2011 | 11:07 AM
LHD220Turbo
found em http://www.reyland.co.uk/Details.asp?ProductID=155
Old Sep 4, 2011 | 11:24 AM
v man's Avatar
v man
Zee Germans are coming
why not use 8 long studs and then 2 standard bolts where the water pump is
surely thats better than just useing 6 and 4 method
and lol at the arp comment
new uprated bolts are never better than old standard no matter how got they are lol
Old Sep 4, 2011 | 03:56 PM
JonnyBravo's Avatar
JonnyBravo
I think I'd rather use 10 than 8. I presume there is a good reason why most people use 6 then use stock bolts on the outer edge but I've never heard the reason.
I believe the Mountune studs are also worth considering, however I know you need take a bit of the socket in a lathe, not exactly a major drama though
Old Sep 4, 2011 | 04:01 PM
v man's Avatar
v man
is it worth the water pump modding to use 10 though
surley 8 is better than 6
maybe the way the 6 are in the middle of the block and bolts to each end pulling the head down evenly ???
Old Sep 4, 2011 | 04:05 PM
JonnyBravo's Avatar
JonnyBravo
Thats exactly what I imagine is the case, would make sense
James Porter
Oct 28, 2015 12:17 PM
atm
Sep 1, 2015 04:56 PM
GTR_STU
Aug 28, 2015 01:02 PM
IAN RS2k
Aug 18, 2015 07:51 PM
lockie
Jul 31, 2015 10:03 PM
